Old 02-26-2013, 12:28 PM   #1 (permalink)
Default Five minute, GPS boom mount
Just wanted to share my 50 Cent boom mount for my GPS test. Its just a self adhesive wire clip installed backwards.
The part designed to hold the wire is concave and will fit nicely on any round boom. You just need a bit of double sided tape around the boom so things stay locked in place once the zip tie is installed.
Then just stick the unit to the self adhesive portion of the clip. Its very solid and secure.
ID:	398228   Click image for larger version
ID:	398229   Click image for larger version
Tony
Synergy 516, Gaui R-5 Speed (RIP), Cypher Vtol Jet (RIP), Spirit FBL, Hobbywing and Scorpion Tribunus ESC, Xnova motors. The girl in my DX9 tells them all what to do
Xrayted is offline        Reply With Quote Quick reply to this message
Old 02-26-2013, 03:25 PM   #2 (permalink)
Very clever.
7hv
ckindt is offline        Reply With Quote Quick reply to this message
Old 02-27-2013, 01:55 AM   #3 (permalink)
Brilliant!!
Align 450, Align 700e, SK 720 GPS, DX8, T14SG
Wesley888 is offline        Reply With Quote Quick reply to this message
Old 02-27-2013, 03:23 AM   #4 (permalink)
Very nice, I saw this just after I had spent half an hour to cut and drill an old frame side to make a mount that bolts onto the boom clamp bolts. Would have been just as good as what I ended up with.
//Dennis.
soXos: Strike 8.1 - Strike 7.1 Light - Strike 6.1 : Goosky: RS7 - RS4 - S2 - S1
soXos DB7 nightflyer : Jeti DS-16 & DS-12
I am www.soxosaustralia.com.au | soXos helis | 1st-RC Products | EGODRIFT motors | Goosky helis | Spinblades
Thunder Fighter is offline        Reply With Quote Quick reply to this message
Old 02-27-2013, 06:21 AM   #5 (permalink)
//Dennis.
I did the same thing! It was while I was cutting a piece of plastic to fabricate something, that I realized I had a bag of 100 of these things sitting around. The concave portion fits the boom much better than the flat mount I had made.
This is only temporary for my test, but I'm sure it could be made to look much better by using a black mount and cleaning up the no slip tape on the boom.
Tony
Old 02-27-2013, 11:17 AM   #6 (permalink)
Very nice.
$7.54 for 100 in black 1" square
$6.37 for 100 in natural ( white )
http://cabletiesunlimited.com/mounts...ble-mount.html
I think I'll get some in black
LOL.... 13.90 for shipping and handling!
Mark
Dusty Shelf queens: TDR2, TDR, Protos Max, Logo 550SX, Protos 500, Jeti DS-16, etc....
mkovalcson is offline        Reply With Quote Quick reply to this message
Old 02-27-2013, 04:33 PM   #7 (permalink)
Originally Posted by mkovalcson View Post
Very nice.
Yikes! I guess you can't buy just one or a few at a time. I already had a bag of 100 so mine cost me less than a dime.......maybe 50 Cent total when you throw in the tape and tie.
Any electronics store will have them such as Frys or similar and avoid shipping, or maybe we can do a share program for anyone that only wants one.
Tony
Old 02-27-2013, 08:04 PM   #8 (permalink)
Default GPS Mount
Brilliant idea, thanks for sharing. Are you using the 19 or 25mm mount. Thanks
blobo is offline        Reply With Quote Quick reply to this message
Old 03-01-2013, 01:50 PM   #9 (permalink)
Default I was so close, but didn't see it
Great Idea, I was close
mbutler6063 is offline        Reply With Quote Quick reply to this message
Old 03-01-2013, 02:16 PM   #10 (permalink)
As close to 1" as possible. 19 is a bit small, 25mm or a little bigger is ideal.
Mark
Old 03-01-2013, 02:42 PM   #11 (permalink)
Correct. Mine covers pretty much the entire back of flat part of the unit.
Tony
Old 03-01-2013, 06:18 PM   #12 (permalink)
There we go!
I now have 99 custom SK-GPS mounts left
Mark
Old 03-01-2013, 06:29 PM   #13 (permalink)
Nice!
Tony
Old 03-11-2013, 08:00 PM   #14 (permalink)
In my case I would like to boom mount the GPS but I think my sk-720 is to far away. My controller is mounted under my canopy, how long is the cable that links the two? I think I am about 12 to 15 inches away.
thielecg is offline        Reply With Quote Quick reply to this message
Old 03-11-2013, 08:25 PM   #15 (permalink)
I can't remember, but I think it's about 15".
Old 03-11-2013, 10:24 PM   #16 (permalink)
I am looking to mount the GPS unit on my trex 700, any ideas?
Old 11-19-2015, 02:59 PM   #17 (permalink)
Awesome, I was wondering what I was going to do to mount the GPS unit on my 550.
This solution looks much easier and just a tidy.
Necroscope is offline        Reply With Quote Quick reply to this message
Old 11-19-2015, 03:37 PM   #18 (permalink)
Doesn't the SK720BL need to know the distance from the main mast?
And, on mine, the maximum distance was I could enter in the user interface was145mm aft (-145mm).
On my 600E, I could not go any further than the back of the frame.
Old 11-19-2015, 03:40 PM   #19 (permalink)
If you have the KDE or Lynx main mast bearing with the X-frame between the top and bottom mounts, use gyro mount tape to attach the GPS to the X-frame.
Old 11-19-2015, 03:58 PM   #20 (permalink)
Yes it does. Ive never noticed the distance issue, but I just tried using the software, and it appears that 125 CM is the max that can be input in either direction Not sure if there is some sort of real limit from a function standpoint, or if this is just a meaningless limit in the interface programming thinking no one would ever need more?
That's 50 inches, so how is your GPS mounting over 4 feet away from your main shaft on a 600 unless its mounted to your tail fin? The only thing I can think of is you are thinking its MM when its scaled for CM
Tony
