Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > X7
X7 Discussion and support of the Gaui X7
Old 11-19-2014, 10:53 AM   #21 (permalink)
Got a problem with the new upgrade gear, there are no cut outs in the gear and it fouls the frame at the back. I guess I will need to dremel the gear a bit. Don't think I can shim the gear down anymore or crown gear mesh will be too loose.
Yuppyflyer is offline        Reply With Quote Quick reply to this message
Old 11-19-2014, 01:12 PM   #22 (permalink)
You can shim between the croun and the gear - need to take apart and have the specific shim for the slot there.
But im not sure you will have enough to solve it? Hmmm
2 X X7 | Scorpion 4525 Ultimate 4+6T YY / Xnove 4530 525 | scorpion Tribunus 200II ESC | Edge 713 | Logo 690SX | Pyro 440 7+8T YY | Castle 120HV | X3 | 4S | HW 50A V2 ESC | Scorpion 2221 2050KV 9T D | SK540 / Brain2 | Mks
omerco is offline        Reply With Quote Quick reply to this message
Old 11-19-2014, 02:52 PM   #23 (permalink)
Pretty sure there is a thick shim that goes inbetween the main gear and crown gear. When you took it apart, did you forget to put it back ?
GAUI NX7 - GAUI X7 - GAUI X5 - GAUI NX4 - GAUI GX4 - GAUI X4 II - GAUI X3 - GAUI X2 - All on VBar 5.3 Pro
Team GAUI USA / Empire Hobby / Scorpion Power Systems / Optipower Batteries / Cyclone Blades / Savox / YS Engines / VP PowerMaster / JR
Matt Nasca is offline        Reply With Quote Quick reply to this message
Old 11-19-2014, 04:49 PM   #24 (permalink)
Nope the shim is in there.
Old 11-19-2014, 04:58 PM   #25 (permalink)
Hmm, I'm not sure then. That's very strange it doesn't fit.
Old 11-19-2014, 05:23 PM   #26 (permalink)
Do you guys know the part # is for that shim that goes in between the crown and main gear?
I just check mine and it has the shim but not the thick one.
I cannot seem to find it. This is the only thing I could find.
http://www.anythingheli.com/gaui-x7-...washer-217413/
cRash_landing is offline        Reply With Quote Quick reply to this message
Old 11-19-2014, 05:32 PM   #27 (permalink)
I've dremelled a very small amount off the gear so it clears now, going to try it like that and see if it's ok. The shim supplied on this new unit was not very thick, but not sure much more could be added.
Old 11-19-2014, 05:46 PM   #28 (permalink)
I have found this at Gaui's website, Although it's for the NX7.
http://www.gaui.com.tw/product/nx7-s...grade-for-nx7/
From the picture it has the thicker shims.
I did not dremel mine, I just let the bolt do the work.
Old 11-19-2014, 05:51 PM   #29 (permalink)
I got this a while back so I could ditch my main shaft collar. I believe it came with one of the 'thick' shims.
Jeti DS14us -- TT e700 -- 6s Logo600se UL -- Logo600-3d -- Logo500 UL -- Charge Case
prototype3a is offline        Reply With Quote Quick reply to this message
Old 11-19-2014, 05:58 PM   #30 (permalink)
I got mine with 2 thin shims.
And the thick washers is Ø15.1x Ø18×2 Washer x1 and it is not included in my OWB.
Old 11-20-2014, 01:58 AM   #31 (permalink)
http://www.gaui.com.tw/product/x7-se...pgrade_for_x7/
This is the X7 one I got as part of the upgrade with the gear which shows just a thin shim 0.1mm.
Old 11-20-2014, 03:39 AM   #32 (permalink)
Old 11-20-2014, 12:05 PM   #33 (permalink)
I have 2 Gaui X2 with upgraded OWB. On both the shim between the main and crown gear is very thin and there is no slop so I dont think its possible to add more shims.
Could it be that the lower bearing block is turned upside down or switched with one of the other bearing blocks on the main shaft?
This is indeed very strange....
Member of Team Gaui Denmark
pxpep is offline        Reply With Quote Quick reply to this message
Old 11-21-2014, 01:18 PM   #34 (permalink)
Dremelled some clearance and all seemed smooth on a test flight today.
Old 03-04-2015, 08:10 PM   #35 (permalink)
So is the newest version the one with the threaded insert? This version doesn't need the set screw mod?
Old 03-08-2015, 12:57 PM   #36 (permalink)
The newer version has the three pin and set screw. I upgraded mine and it has it.
http://www.anythingheli.com/gaui-mai...n-gaui-x7-nx7/
Old 03-08-2015, 01:17 PM   #37 (permalink)
The newest has a threaded hub and without the pins. mine is the same as yours with the 3 pins and they released another after it.
Old 03-08-2015, 03:37 PM   #38 (permalink)
So if I order from Prestige I should get the threaded insert?
Old 03-08-2015, 03:52 PM   #39 (permalink)
You need to check that with them and see which version they have...
Old 06-16-2015, 09:19 AM   #40 (permalink)
I wonder how Gaui is going to figure out how to soak us for more money. This is the third "upgrade" for this.................
Heli's I have:
Goblin 500 (Vbar Neo), Gaui X5(Vbar Neo), X7(Vbar Neo), Innova 600 Night heli (Vbar Neo Vbar Vcontrol
I'm the not so newbheliusr as I have been here a while. But I like this name.
newbheliusr is offline        Reply With Quote Quick reply to this message
