Old 02-07-2012, 07:11 AM   #1661 (permalink)
Interesting idea...has merit
JR9303 / JR9503 / Futaba10CHP
Old 02-08-2012, 07:19 AM   #1662 (permalink)
Default Shocks
Originally Posted by nightflyr View Post
Major hardware completed on the second unit, paint dried...
Just awaiting the new gear set....
Hi nightflyr,
Are those springs on the landing gear? Is that the "new gear"?
I was thinking of something special for landing gear as well, perhaps some relatively flexible carbofibre ones reinforced with some buggy-type shock absorbers to arrest/dampen the springiness. Maybe it's been tried?
best regards!
salience is offline        Reply With Quote Quick reply to this message
Old 02-08-2012, 08:04 AM   #1663 (permalink)
Hi nightflyr,
Are those springs on the landing gear? Yes Is that the "new gear"? No, I meant the main drive gear set
best regards!
I make my own landing gear, no need for shock absorbers unless you plan on slamming into the ground.
Old 02-11-2012, 06:47 PM   #1664 (permalink)
Well with lousy weather on hand and being stuck @ work with the HVAC crew, decided to try a different idea for a set of landing gear.
30 minutes of torching and bending, and another hour for painting and drying in the oven.
Tested them up to 80 lbs, static load so a 14 lb helicopter will prove no issue to them.
Old 02-12-2012, 12:07 AM   #1665 (permalink)
Man that is clean Rich, very nicely done
When the people find that they can vote themselves money, that will herald the end of the republic.
~Benjamin Franklin ~
Navigator53 is offline        Reply With Quote Quick reply to this message
Old 02-12-2012, 05:38 AM   #1666 (permalink)
Thanks Mel
Old 02-12-2012, 07:00 AM   #1667 (permalink)
Night, is it steel tubing that you've used or you're actually setup to weld aluminum in your heli workshop???
Jerry
jperkosk is offline        Reply With Quote Quick reply to this message
Old 02-12-2012, 07:47 AM   #1668 (permalink)
Actually, that is left over high pressure aluminum tubing I used to install the compressor air system @ work.
I didn't weld it, the landing pipes are pinned in case of damaged so that they can be replaced.
Old 02-19-2012, 02:19 PM   #1669 (permalink)
Ok kiddies....
It is time to see how much the 900E can get off the ground and fly around safely...
Forged a 28 lb lead weight...
Suspended it from the helicopter with minimum of swinging..
And for the glory...
[ame]http://www.youtube.com/watch?v=rTuFSzRe-ho[/ame]
Old 02-19-2012, 03:34 PM   #1670 (permalink)
mhoebrec is offline        Reply With Quote Quick reply to this message
Old 02-19-2012, 06:59 PM   #1671 (permalink)
29lbs !!!
That's enough for a studio-quality video rig !!!
Jerry
Old 02-20-2012, 10:41 AM   #1672 (permalink)
That is just too cool Rich
Didn't even look like it broke a sweat either
Is that with a Castle ice HV80?
How many amps are you pulling to be able to do that?
Old 02-20-2012, 04:21 PM   #1673 (permalink)
ICE2HV80 was pulling 40A @ 80*F ..the cooling fans are doing their job well
Old 02-21-2012, 04:51 AM   #1674 (permalink)
I look at the photo and that chain-link fence between you and... I wonder what the neighbor thinks of this - does he ever venture into his back yard when you are testing what might be construed to be machinery of war capability?!?!
That gear looks robust to say the least! I've been slowly constructing my own custom landing gear, with buggy shock absorbers to dampen hard landings. I'll post a photo over in TREX600 pics when done.
Old 02-21-2012, 04:58 AM   #1675 (permalink)
Never test when people are any where around...
The landing gear was tested to 37 Kg so it can withstand pretty much anything I can put to it
Old 02-21-2012, 01:06 PM   #1676 (permalink)
For sure. From the photos you could suspect that a really hard landing might loose the Hero and crack or even smash other parts of the bird whilst the landing gear remained intact! The side-frames look quite delicate.
Old 02-21-2012, 01:45 PM   #1677 (permalink)
Never judge a book by the cover..
Those lower side frames are double thickness and laminated together
Old 02-21-2012, 03:54 PM   #1678 (permalink)
I am no teacher but Nightflyr always did his homework
Blade400
pril250 is offline        Reply With Quote Quick reply to this message
Old 02-21-2012, 07:09 PM   #1679 (permalink)
Way to go, Night!
MQX Quad,Align 550E/NazaH/GPS,Align450 Pro/CPII, Flame Wheel F450 Quad NazaM/GPS/GoPro3, Blade 350 QX/ GoPro3
Never lend money. It causes amnesia.
Stumblebee is offline        Reply With Quote Quick reply to this message
Old 02-23-2012, 01:32 AM   #1680 (permalink)
Deleted double post.
When in doubt, easyify & over-simplificate.
Superhornet is offline        Reply With Quote Quick reply to this message
