Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > X5
X5 Discussion and support of the Gaui X5
Old 08-07-2016, 02:55 PM   #1 (permalink)
Default Rekit? Different heli?
Well, I stripped the torque tube gears again and this time couldn't get it down intact. I guess once with a piro flipping save and auto down with no damage is all I get lol. It's pretty extensive, including broken frames at their front, but I might be able to patch that together.
Anyone else having trouble with the front torque tube gears?
Would you guys rebuild? Update to V2? Rekit? Rekit to a V2? Try a different 500?
ID:	665390   Click image for larger version
"If at first you don't succeed, skydiving is not for you."
GAUI NX7, TREX 600N, Goblin 570, Gaui X3L, DX7G2, AMA#970963 Citizen 420
907Heli is offline        Reply With Quote Quick reply to this message
Old 08-07-2016, 03:51 PM   #2 (permalink)
My gears just keep going and going.
My best quess is that there is somethinh wrong with the way they are meshed.
I have to say, getting it just right is a struggle. I Always buy a bunch of gears and seek the pair which feel the smoothest.
For setting the mesh, I remove the main gear. Have the boom tight but loos enough to slide it. Then, while spinning the tail I slide the boom in and out untill I find the sweet spot... And it's a heck of a small spot...
In your case, I would rekit to a X5 formula and beat that sucker again...
Gaui X3 HW 50A V3 OMG H1/H2 Servo's BL450MX Mini-V (M.I.A.)
Gaui X5 FES Polaris BEC BLS451/251 Silverline V-Bar Formula Swash/Head
JR Forza 700 Scorp 160A opto + 4525 520 JR NX8925/SLG01 Vbar Neo
JR XG14 PL8 v2
mverhorst is offline        Reply With Quote Quick reply to this message
Old 08-07-2016, 04:23 PM   #3 (permalink)
It's real easy, just use a piece of the 3M tape backing. Slide the tail tight against it in between gears and then tighten the boom. There, you're done and have proper gear mesh. I've flown numerous flights and even on my 12S build and have never stripped a gear.
With the damage to your bird, I'd either buy another from the site or get a new V2 if they're out yet. The cost to repair yours would probably equal a new bird.
XL V2, Soxos 7.1L - Previous: Kraken 580, Nimbus, Protos 380, Kraken 700, Diabolo 700, Oxy 5/2, Logo 600 / 550SX, Protos 700, Synergy 516, Velos 880, Gaui X7 / X5, Goblin 380, Blade 120SR/180SR/ mcpx BL/300X/450XL, Align 700X/150/Leap 3D
gtruk is offline        Reply With Quote Quick reply to this message
Old 08-07-2016, 05:22 PM   #4 (permalink)
This....
salrica is offline        Reply With Quote Quick reply to this message
Old 08-09-2016, 11:19 AM   #5 (permalink)
formerly koi-fish
Can you show a quick pic? I'm having trouble visualizing it
/ 180cfx, 300x, X3,X4-II, Protos 380, Chase 360, x5, Logo 480, Gob 380, Gob 500, Gob 570, Warp 360, 450x, forza 450/450ex, T-Rex 600 Dom, Logo 600, DX9, 1973 Ford f100, Traxxas Summit/Bronco/Bandit/X-Maxx
"Everyone wanted his soul, all he gave them was a smile" - Steve Marriott
Diogenes is offline        Reply With Quote Quick reply to this message
Old 08-09-2016, 12:13 PM   #6 (permalink)
Unfortunately on vacation at the moment. It's the red backing from the 3M tape. I forget the number, but what most people use to stick on their gyro's. I put a piece of the 3M tape backing in between the gears and push the tail into it. Tighten the screws and you're done. Once tight, just rotate the blades so the tape backing pushes out and you should have the perfect backlash for the torque tube gears. I learned this trick from Nelsonisms a while back. I've never had an issue and have gone through three motors to my current XNova running on 12S. Never stripped a gear and spinning at 2,800 RPM.
Old 08-10-2016, 12:01 AM   #7 (permalink)
I've had three in flight failures of the front TT gears. I've tried both the methods described above, but this is the only method that works for me:
X5 TT mesh setting (2 min 54 sec)
Bear in mind you might have to perform this test with several pairs of gears, as you'll find some new ones with high spots and low spots.
FOR NO FREE APE DIES
Gaui X3/Gaui X5/Goblin 570 KSE/Goblin 630C/Thunder Tiger Raptor 50
Citizen 717
ian.newson is offline        Reply With Quote Quick reply to this message
Old 08-10-2016, 07:53 AM   #8 (permalink)
formerly koi-fish
Ok, I think I get it, but you use the entire piece, grey part and all?
Old 08-10-2016, 09:26 AM   #9 (permalink)
Go here and see post #25:
https://www.helifreak.com/showthread...=576749&page=2
Old 08-10-2016, 11:00 AM   #10 (permalink)
I just do as in the vid, just a bit of play and check in in a couple spots..works for maingear/pinions too, just have to find the high spot and set mesh at that spot.. nice vid as well..
tonys-heli is offline        Reply With Quote Quick reply to this message
Old 08-10-2016, 01:19 PM   #11 (permalink)
formerly koi-fish
Thanks, that told me what I needed to know
