Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > 120 SR
120 SR Blade (eFlite) 120 SR Helicopters Information and Help
Old 09-03-2012, 03:23 PM   #41 (permalink)
I use these settings...
Below are my settings for SR 120 on my DX6i.
Please keep in mind that these settings are done to my liking and might not be as good for you as they are for me
SETUP LIST
Model Type: HELI
Model Name: SR120HEL
Reverse: All Normal
Swash Type: 1 SERVO 90°
Thro-Cut: INH
D/R Combi: D/R SW: FM
Timer: SWITCH: INHIBIT
Range Check: INH
Power Setting: B US 247
ADJUST LIST
D/R&Expo: - Flight mode Switch on "0" (Low rates)
Aile 0 80% +20%
Elev 0 80% +20%
Rudd 0 80% +20%
D/R&Expo: - Flight mode Switch on "1" (High rates)
Aile 1 100% -20%
Elev 1 100% -40%
Rudd 1 100% -15%
Travel Adj:
All on 125%
Sub Trim:
All on 0
GYRO:
INH
THRO CUR:
NORM POS
POS L 0.0%
POS 2 15%
POS 3 50%
POS 4 60%
POS H 75%
STUNT POS
POS L 0.0%
POS 2 30%
POS 3 50%
POS 4 75%
POS H 100%
PITCH CUR:
Leave alone, unused.
SWASH MIX:
INH
MIX1:
INH
MIX2:
INH
REVO MIX:
Al on 0%
Now when your Flight Mode switch is on "0" your heli will be docile and throttle quite soft, good for indoors or for newbie mates, when you will switch to "1" everything should be twitchy,faster and more responsive. I'd play with the Expo % and Throttle curve to find your perfect balance in both Low and High rates.
I am happy with these settings as now the SR120 flies as fast as it can and feels like a big heli. Waiting for swashplate mods ..
Syma S107-Syma S109-Syma X8C-Syma X8G-Syma X5HC-Syma X5HW-Mini Orion-ProtoX-Syma X5C-1
USAF RETIRED 1968-1988 Vietnam Veteran
Pfloyd is offline        Reply With Quote Quick reply to this message
Old 09-05-2012, 02:48 PM   #42 (permalink)
Originally Posted by Pfloyd View Post
Travel Adj:
All on 125%
You can set your travel adjust to 125%? What does that offer and is it bad on the servos?
FlipFlops365 is offline        Reply With Quote Quick reply to this message
Old 09-07-2012, 09:21 AM   #43 (permalink)
Hi Heli Bones (or others)
Is your setup on DX6 compatible with DX8
Or do i have to correct anything ?
The new heliguy. Tvixen
Thanks in advance
Tvixen is offline        Reply With Quote Quick reply to this message
Old 09-23-2012, 06:59 AM   #44 (permalink)
Default "increasing motor power" function
Hello.
I hope, the part of my settings will helpful for somebody. What's do it?
The setting provide "increasing motor power" in a moment changing a direction your heli !
The "increasing motor power" function switch "on" and "off" by AIL D/R switcher. Compare helicopter how flying with or without the function. I hope you will enjoy by behaviour heli.
MIX 1
AILE -> THRO ACT
RATE D +125% U +125%
SW AIL D/R TRIM ACT
MIX 2
ELEV -> THRO ACT
SW AIL D/R TRIM ACT
P.S. Sorry for my bad English
andrk05 is offline        Reply With Quote Quick reply to this message
Old 09-23-2012, 11:40 AM   #45 (permalink)
Default Settings DX7S
I'm looking for a setup for my DX7S with my 120SR.
Thx.
nebukadzir is offline        Reply With Quote Quick reply to this message
Old 09-30-2012, 07:05 AM   #46 (permalink)
I've been using your exact setup for about a month now. Before I was just using some simple setup. I like how the duel rates are setup. Though in flightmode 1 holy cow it is twitchy....but in a good way. She almost acts like a collective pitch sometimes.
Bladerunner81 is offline        Reply With Quote Quick reply to this message
Old 11-05-2012, 09:03 PM   #47 (permalink)
ITravel Adj: All on 125%.
I just purchased a 120SR and was looking for DX6i settings and came across this. It is my understanding that a servo has a throw/rotation tolerance from 1%-125% If you set your throws to the maximum allowable value, you WILL overdrive your servos.
I learned this in off road racing so I believe that the same applies to helis since were talking about servos.
Increasing the throw will improve performance but at an added cost.
Just a thought
ProjektONE is offline        Reply With Quote Quick reply to this message
Old 11-06-2012, 08:11 AM   #48 (permalink)
Just a thought
This is a widely debated topic among Heli Forums I've visited. Many folks will say they run at 125% with no ill affects at all and others will say it could damage the servos. I do have a couple of my small Blade Helis set at 125% and have checked travel and see no ill affects, but who knows. Can't remember if my 120SR is set at 125% or not.
Joshua ~Proverbs 3:5-6
DX6i, DX5e, NQX, NCPX, Armattan V-Tail 355, Hubsan Qaud, ProtoX, Many Planes
jdr00ejr is offline        Reply With Quote Quick reply to this message
Old 11-06-2012, 02:41 PM   #49 (permalink)
Originally Posted by Heli Bones View Post
Why would you set it up in ACRO?
I have the msr and the 120 sr set to HELI.
Agreed. I prefer HELI for my 120SR. I believe the ACRO setting doesn't allow for Swash Mix, for instance. I have my swash mix set to increase left aileron with forward pitch to automatically correct for the increase in lift generated by the forward-moving blades.
Squenards is offline        Reply With Quote Quick reply to this message
Old 12-27-2012, 07:19 PM   #50 (permalink)
SETUP LIST
Model Type: HELI
Reverse: All Normal
Thro-Cut: INH
Range Check: INH
ADJUST LIST
Aile 0 80% +20%
Elev 0 80% +20%
Rudd 0 80% +20%
Aile 1 100% -20%
Elev 1 100% -40%
Rudd 1 100% -15%
Travel Adj:
All on 125%
Sub Trim:
All on 0
GYRO:
INH
THRO CUR:
NORM POS
POS L 0.0%
POS 2 15%
POS 3 50%
POS 4 60%
POS H 75%
STUNT POS
POS L 0.0%
POS 2 30%
POS 3 50%
POS 4 75%
POS H 100%
PITCH CUR:
SWASH MIX:
INH
MIX1:
INH
MIX2:
INH
REVO MIX:
Al on 0%
I just tried these settings out and they are great, the throttle curve is nice on 0 and the heli is very docile. I'm interested to try the 1 settings outside..
NjHeli is offline        Reply With Quote Quick reply to this message
Old 08-08-2016, 10:57 AM   #51 (permalink)
Default Using ACRO as setting
As was suggested, I tried just setting up my 120sr as a new model and as acro. No other settings and my 120 flew without any issues. I was having issues with it prior to this but now she flies and hovers very good. I am total noob who made the mistake of buying collective pitch helis instead of FPs. Quite an expensive mistake. So I'm stepping back down to FPs in order to properly develop my skills, especially orientation!
mcpx v2, mcpx BL, 120 sr, msr, Walkera Master CP, Blade 450 3d, Esky Belt cp, srx200, Blade Apache AH-64, syma 800g, syma s107g, Walkera 4F200LM...
Exrayz is offline        Reply With Quote Quick reply to this message
