MSH Brain FBL Unit MSH Brain Support Forum |
01-28-2015, 10:57 PM | #61 (permalink) | |
So yes, the setup is not changed. But the governor is almost completely re-written to fully optimize it. As mentioned earlier, you will want to increase the collective pre-comp to a much higher value now to get the most out of the gov. something in the 30 range works well on my setups. It you use the auto bailout, the ramp up rate has been changed. Try a value of 80-90. |
01-29-2015, 03:01 AM | #62 (permalink) |
I have 3 brains, all of them with the blutooth module, after the update none of them is able to be programmed (name change or pin code) with the brain applikation (connected with usb).
The application hangs for about 1min and is not responding, and after about 1min it will work again, but the blutooth is not programmed. I saw that there was some bug right now that may affect this, just wanted to let you guys know.
Goblin 570 - vBar Neo | Trex 700 V3 - vBar Silverline | Trex 500 DFC Pro - vBar Mini | vBar Control |
01-29-2015, 03:16 AM | #63 (permalink) |
Hello, we are currently working on a fix, it'll be out in the next couple of hours.
Sorry for the inconvenience. Corrado
www.msheli.com |
01-29-2015, 03:23 AM | #64 (permalink) |
Ok, problem solved.
Please update firmware again even if you already are on 1.3.050. For some unknown reason the file got corrupted while charging it on the update server. All the people that will update from now and on will have no prob. Please let us know if the fix is working for you. Corrado
www.msheli.com |
01-29-2015, 04:46 AM | #65 (permalink) | |
//Jonas
01-29-2015, 05:26 AM | #66 (permalink) |
Mine works great
Just come back from the first flight with my 450 heli.
Did it like this. - Save the old ikon-file with the old Software to get a file without the new Parameter. - Start new Software - Update Brain/IKON - Load the old File from your Computer - Go to Basic Settings and choose again Modelsize and Flight style in all 3 Banks - Reload tho old Model-file from Computer. -> So you have now your old configuration with all Parameters and Setups mixed with the Default values of the new Parameters. Save as new Model-File and test it. Very easy Prozess without loosing your personal settings. Then increase pitch pump because it works good, for me 20-25 is ok. I decrease the tail dynamic from 50 to 30 at belt driven heli but i think i will increase it again to 50. Now i have to Setup my other bigger Helis with IKON Governor to be update. Thank you for the new Firmware. Here in Germany it's cold and windy but this is no reason to delay the update. Regards Marco |
01-29-2015, 05:35 AM | #67 (permalink) |
Ok, so i downloaded the setupfile again, removed the brain software, reinstalled, started up and connected with usb, selected to upload new firmware, was asked to save current config, did that and pressed ok, software showed firmware version and i press ok, nothing happens, unit does not reboot or anything, firmware window just close.
Still bluetooth problems
01-29-2015, 05:38 AM | #68 (permalink) |
Can you update firmware with USB? After updating you'll be able to use BT with no prob again.
Corrado
www.msheli.com |
01-29-2015, 05:44 AM | #69 (permalink) |
I am trying to update with usb, i updated yesterday without any problems, im now trying to update again after the bugfix that was posted today
01-29-2015, 06:11 AM | #70 (permalink) |
I mean direct USB not remote usb port.
Corrado
www.msheli.com |
01-29-2015, 06:14 AM | #71 (permalink) |
Yes im using the usb cable, bluetooth is working fine also, it´s when you are trying to program the bluetooth device (name and pin) the application hangs and wont program, this worked fine before the latest firmware.
And i was thinking that this might have something to do with the bugs you found and posted a buggfix here in this thread today, but i cannot in some way reinstall the firmware.
01-29-2015, 06:19 AM | #72 (permalink) |
Now i think i understand. You are on latest firmware (the one we just released with serial fixed) and everything works except the programmation of the BT name and pin, correct?
If that is the case we will check now and let you know. What BT module are you using? Corrado
www.msheli.com |
01-29-2015, 06:33 AM | #73 (permalink) | |
Bluetooth modules im running is: http://www.rchobby.se/sv/tillbehor/2...-acc-0018.html
01-29-2015, 06:38 AM | #74 (permalink) |
You need to update with today firmware using direct usb. After you do that it will work again.
We just tested again here and everything works in pin and name settings on BT. Do the following: 1 - Remove BT device from your unit 2 - Connect pc to unit with direct USB 3 - Update firmware on unit again (firmware will show with same 1.3.050 name but update anyway) On yesterday's firmware there was a serial comunication problem, that is why serial doesn't work correctly. Corrado
www.msheli.com |
01-29-2015, 06:48 AM | #75 (permalink) | |
Ok, i will try again, that is what i did, after i pressed the "OK" button on the firmware update windows (the one that shows version) nothing happens, it just go away and im back in the application, no progress bar or anything, no reboot. Just a question, when you in the menu select to update firmware, is it checking version against the installed software or is it checking online to your servers?
01-29-2015, 06:53 AM | #76 (permalink) |
When the firmware Windows pops up make sure you click on the firmware number THAN press ok, otherwise it will just return to the app without updating.
Corrado
www.msheli.com |
01-29-2015, 06:58 AM | #77 (permalink) |
AAhhhhhh, thats the problem then, thx for clearing that out
01-29-2015, 07:03 AM | #78 (permalink) |
please let us know if everything works again.
corrado
www.msheli.com |
01-29-2015, 07:13 AM | #79 (permalink) | |
I have posted this on all my social media sites, thanks for correcting so fast guys!
Synergy Factory Specialist / Rail Blades / Team Scorpion |
