Old 12-25-2014, 12:23 PM   #1 (permalink)
Default Micro Beast problem
Hope someone knows the answer to this one
Ok Micro beast and AR8000 in a Trex 700e CC 160 hv Edge
When I turn on RX all ambers light and status light starts red blue purple and back to red
then amber on A and B
Then it runs up and down each bank of ambers back and forth for 6 cycles a thru g then h thru n
On 7th pass it stays a thru g
Status stays red
Will do this for several minutes the status blinks 5 times
Any Ideas ?
Radio DX18 DX9 Helis M/A 60's x3, GMP competitors X3 , Legend 1, Schluters x2,Shuttle plus 1,Trex 450 x2,Blade 450x 1,120 SR x2,Nano 1,MCPX V2 1, MSRX 1 MQX 2 Trex 700E's,600N,500E,600E,550E 250 x3. Yes I need HELP :
Old Dog is offline        Reply With Quote Quick reply to this message
Old 12-26-2014, 01:49 PM   #2 (permalink)
Hi,
this means the device could not calibrate sensor rest positions. In this particular case (Status LED error code = blinking 5 times) the Y-axis sensor seems to move all the time. This can have different reasons:
- huge temperature drift
- heli moved all the time during init
- power supply unstable
- mechnical pressure to the sensor (plastic lid of the device touching the sensor)
- or simply a damaged or bad sensor due to mechanical force or bad storage
Power supply: Remove all servo connections. Does it start up then?
Temperature: Does it start up inside the house after letting the unit acclimatize for some time?
Movement: Was the heli standing firm on the ground. No wind gust and nobody trampling around.
Pressure to the sensor: Did you use zip ties to tighten down the unit to the heli? You mustn't do this! Did you ever open the plastic lid and/or tightened the screws of the lid.
Bad sensor: Was the unit new, bought second hand or was it lying around in the chest for some time?
best regards from Germany
Stefan
BEASTX r&d Team
freakware.com
Frenchdress is offline        Reply With Quote Quick reply to this message
Old 12-26-2014, 08:22 PM   #3 (permalink)
Has been sitting for awhile, Got it from a friend who swears it was never in a crash and it worked when he stopped using it. I do trust him on that. It's crazy the other two I got from him look used but work perfect and one of those has been in a few dirt naps. It was on the bench not mounted in a heli when I found it not working, I wanted to set it first then install.
Old 12-26-2014, 08:39 PM   #4 (permalink)
If it wasn't on the heli, maybe it was too free to move around, and failed to calibrate the sensors as descibed above. If you were trying to hold it for example it would never work.
Maybe a fan or radio on the bench, or the ESC fan, vibrating the worktop, or any source of vibration.
Regards, Sutty
Old 12-26-2014, 08:43 PM   #5 (permalink)
Will try an experiment, I'll mount it and retry it now. Thanks
Old 12-26-2014, 08:54 PM   #6 (permalink)
Nope, Still does the same thing. Mounted it on a 300 x I have sitting without a FBL unit. I work at a LHS and talked to tech support he said I could send it in to HH but he said they might have to send it out ? Anybody know who they would send it to ?
Old 12-27-2014, 10:15 AM   #7 (permalink)
The AR7200BX is aSpectrum product, which is part of the HH "empire".
I can't tell where you are at in the world (one of the benefits of an obscure location tag!), but I suppose this would be to their shop that works on Spectrum equipment.
ahahn is offline        Reply With Quote Quick reply to this message
Old 12-27-2014, 05:33 PM   #8 (permalink)
Thought that was a real place, near Pittsburgh.
Regards, Sutty
Old 12-27-2014, 10:28 PM   #9 (permalink)
Not a 7200bx it's the micro beast. Tech said since it's not the 7200 it would need sent out ? LOL My location yes north of pittsburgh Pa. You know the armpit of Pa.
Old 12-29-2014, 06:27 AM   #10 (permalink)
Hi,
HorizonHobby is the contact for BEASTX products in the US, too. Not only for Spektrum.
Stefan
BEASTX r&d Team
freakware.com
Old 12-29-2014, 05:02 PM   #11 (permalink)
Thanks will get to them asap
