Newbies: Tips and Information Section of HF, specifically for Passing along info to newcomers to the hobby. Setup, tweaking, orientation practice, etc. |
08-15-2009, 08:27 PM | #601 (permalink) | |
My first two flights went well, I've been grounded for two weeks since, trying to fix the tail gear while I wait for this part : http://www.helidirect.com/trex-compl...set-p-1103.hdx I bought two other kits, both tail gears were loose right off the bat in the kits. I tried this fix with loctite, but haven't had it work yet (probably partly becuase I've been too impatient to wait more than 24 hours to wait for it to cure http://www.hk450.com/tail-gear/ |
08-15-2009, 08:47 PM | #602 (permalink) | |
I received the stock HS-1216T-84, but cannot find any red or green threadlocker here to attach the small pulley. |
08-15-2009, 09:25 PM | #603 (permalink) | |
As for the 10t, do you mean it wasn't fitting onto the belt for you ? |
08-16-2009, 05:31 AM | #604 (permalink) | |
It will likely fit, but with a smaller pulley, the tail rotor will turn slower. The one-tooth difference might be a moot point, but since I have the stock part, I did not want to experiment. Now I have to wait until Monday to find some threadlocker |
08-16-2009, 05:38 AM | #605 (permalink) |
My stock tail drive spun freely so I bought the Align equivalent. This arrived with the tail drive pulley separate in the packaging. I noticed there was some gluey stuff on the shaft so fitted the pulley and applied a little heat for a few seconds with my Zippo. 30 minutes later I couldn't budge it and to date it flies fine
Cheers, Bugster |
08-18-2009, 09:14 AM | #606 (permalink) |
Apparently in the most recent shipping kits, the tail drive gear has now been corrected.
My "locktite fix" is now working anyway, |
08-18-2009, 10:43 AM | #607 (permalink) | |
I also gave the HK part that I replaced a semi-torture test and it will not fail. Mike, I think you are right about the newer kits having the good tail drives. |
08-20-2009, 01:22 PM | #608 (permalink) |
Also be aware that there are more and more clones of the trex 450.
I ordered this clone 450 V2 SE one with a carbon frame for only USD $59.99 Not sure if its a Copter X clone or not. https://www.helifreak.com/showthread.php?t=156118 Also Xheli, has a full Carbon Frame kit for 29.00. http://www.xheli.com/exi-31002a.html My Hk's are flying well after the tail gear fix. Just be aware that the HK head uses a 3mm feathering shaft, and not the SE v2's 4mm feathering shaft. Also check out ebay for parts, I ran across this site and order a BUNCH of parts. http://stores.shop.ebay.com/vignypeg...34Q2ec0Q2em322
New Toys, Logo 600SE, Futaba 18MZ Align 450 Pro V2, Mini-v Pantera 55, Pantera XE Elec Trex 600 ESP, Gaui 425 Last edited by edhall; 08-20-2009 at 01:27 PM.. Reason: Added links |
08-20-2009, 04:32 PM | #609 (permalink) |
Hi All,
My 2nd heli (Copter-X 450) is fitted with a Turnigy Plush 40 ESC and Turnigy 2836-3700 Motor from Hobbycity. In the programming menu for timing I get a choice of 'Low', 'Medium', or 'High' timing for the motor. Does anyone have any thoughts on which one I should be using or any info on what difference the timing makes? E.G. more revs & less torque etc.?
"It is said that the big thing on top is a rotor - it's not it's a cooling fan for the pilot. We know this is true because if it stops spinning you can actually watch the pilot sweat." |
08-21-2009, 10:51 AM | #610 (permalink) |
Cheap fleet My efforts
Cheap Seats GOOD VALUES
Like most of us I have to budget and scrimp to support the addiction of RC Helicopters. This thread seems to be a good place to make my observations and opinions known. Costs of various "cheap Seats" and sources for the products. 450 Class Machines: Heli Direct HDX450se v3 179.99 , 325 Pro carbon blades 14.22 , INO-Lab D202MG servos 34.99(3) . HDX 3552 Brushless MTR 19.99, Volcano 30A W/BEC 17.95, Futaba Rcvr 99.99 GRAND RC Logitech Gyro/Wservo 108.00 XHELI TG450SE 139.99, Blades as above 14.22, EXI 9G servos w/MG 9.00(3), Alpha 400 Mtr 3500KV 17.95, ESC as Above 17.95, GRAND RC Tele bee Gyro 29.00 These 450's while not Brand Named are Fibre glass framed, with all aluminum CNC Heads, Tails, full bearings. Add in cost of xmtr batteries and charger, Xmtr $100, Batteries 22.99EA, Charger 55.00 (Call it 190$) and you can get a respectable limited 3d capable 450 sized Heli for between 373 dollars and 525 dollars with the majority of parts trex compatable. A different approach would be for a 500 class machine. (This kit was a pleseant surprise) XHeli EXI 500CF Carbon framed (TREX500 Clone) EXI 500 CF Kit 139.00 425 carbon blades 49.00 volcano 60A ESC/BEC 34.95 GRAND RC Futaba 9257 servos 59.99 (4) Align Brushless 500L 59.95 Logitech 2100 Gyro 75.00 Futaba rcvr 99.99 Double up on the batteries same xmtr same charger and costs would be 700 plus 220 for the bat,chrgr,xmtr These numbers reflect the Cheap fleet I've put together. They also represent Helis that will not require much in the way of uprades for the mechanics anyway.
OLD Dude--New TUDE Flying without chemicals!! |
08-23-2009, 11:20 AM | #611 (permalink) |
http://www.hobbycity.com/hobbycity/s...idProduct=9299
I just ran across this 40A ESC and for only 8.99. It supposedly has 2A Bec ouput, but that might be a little to low depending on your servos. It has an external heat sink. Has anyone tried this one?
New Toys, Logo 600SE, Futaba 18MZ Align 450 Pro V2, Mini-v Pantera 55, Pantera XE Elec Trex 600 ESP, Gaui 425 |
08-23-2009, 12:33 PM | #612 (permalink) |
Man, that's cheap. The reviews on the HK site seem to be good for it too. It's impressive how prices on this hobby, especially the 450 stuff, keep dropping. I just got back from the park putting five batteries through my two birds and had a blast. Even the battery prices are way down. I paid about as much for those 5 zippy batteries as you would have paid for one battery not very long ago. I don't know about everyone else, but I'm having fun now.
AMA # 111032 Your confidence level is directly proportional to the length of time since your last crash. |
08-25-2009, 07:32 PM | #613 (permalink) |
I have just gone though the mental experience of letting go of the 450's.
I bought a Pantera 50 nitro, and a 600ESP, so now the 450's dont seem so important. I am sure I will crash a lot, but now I am free to have fun with the 450's as the parts on Ebay are just cheap and cheaper. I finally feel free to learn and crash. It's a great feeling!
08-25-2009, 10:32 PM | #614 (permalink) |
I know you don't want to re-kit that 600!
Eventhough the 450 cloans are really dirt cheap to the point of almost being disposable and the fact I have two flying at once and another kit and a pile of spare parts on hand, I still can't get over need to keep these things in one piece. Crashing one still hurts.
08-27-2009, 09:33 PM | #615 (permalink) |
Wonder if this canopy will fit.
http://hobbycity.com/hobbycity/store...idProduct=9310 |
08-27-2009, 09:34 PM | #616 (permalink) |
Delete post please, i acidentally double posted
--Pvt |
08-27-2009, 10:19 PM | #617 (permalink) | |
D W Gwinn AMA #895632 Axe Ez, Axe CP, Blade MCX, HDX 450SEv3, HK-450, HC-500 |
08-27-2009, 10:46 PM | #618 (permalink) |
I think the tail issue is a non event, I have a couple of early and later kits...
None of mine were as fragile as people on here claim - but I used files to really roughen the shaft and create something to hold onto before using studlock (loctite) and no more problems (well ... except for tail strikes .. hehe they seem to bugger tail gears) |
08-28-2009, 07:27 AM | #619 (permalink) |
I just received one of the new kits and the tail drive gear seems to be solid on this one. I had problems with the earlier one I had received several months ago. HK has aparently fixed the problem.
Just for your information, they are now providing a one piece landing skid molded out of plastic, instead of the built-up landing skid. Everything else appears to be the same. |
08-29-2009, 11:21 PM | #620 (permalink) | |
