Go Back   HeliFreak > R/C Electronics Support > HobbyWing ESC's
HobbyWing ESC's HobbyWing ESC Support
Old 10-04-2015, 08:00 PM   #1 (permalink)
Default Governor gain on HW 100?
Is there a way to adjust the gov gain on the HW 100's! My tail on my 380 is "ever so slightly" kicking out on tic tocs and punch outs... I've tried to remove it buy no luck.... I remember my tail was kicking out a little bit on my Blade 550x a while ago while using a Castle 120hv and I dialed it out with the Castle software using the gov gain parameters in the Castle Link software..... Does the same hold true on the HobbyWing's?
Goblin 380, Goblin 500, Goblin 630
gmiller0 is offline        Reply With Quote Quick reply to this message
Old 10-05-2015, 06:54 PM   #2 (permalink)
Unfortunately there is no way to adjust the gov gain on any of the V3 escs. Try adjusting your collective pitch compensation in your fly system.
Hobbywing US factory team pilot BK Servo Spartan RCTeam LynxTeam OXY Team Xnova I get high by getting LOW!!
DarkSyd3D is offline        Reply With Quote Quick reply to this message
Old 10-05-2015, 08:42 PM   #3 (permalink)
Thanks man... I've tried that...another guy I know had the same issue and he changed to the Ikon's gov mode using the adapter cable for the external gov out to the Ikon and it went away... I haven't tried that yet as I LOVE the gov on the HobbyWing and it's really not THAT big of a kick..... I think it may be that the HobbyWing fights to keep the constant headspeed at all costs and the gain is preset to a higher internal value....... So, I may try the external Ikon gov and report back soon....
Old 10-05-2015, 09:49 PM   #4 (permalink)
Good luck dude
Old 10-06-2015, 10:57 PM   #5 (permalink)
FBL gov is far superior to a esc gov because it knows all of your stick inputs and can act biased on the input you are giving. Grab a rpm sensor and take advantage of all the development Alex and others have put into that iKON gov. Play around with precomp as well if it still isn't to your liking.
Team MSH USA - Cyclone Blades
MSH Prôtos 380 Brain 2
MSH Prôtos Max V2 Brain
vtown nick is offline        Reply With Quote Quick reply to this message
Old 10-06-2015, 11:10 PM   #6 (permalink)
I used the Ikon Gov on my trex and imo it wasn't much different than the castle gov with getting back to proper HS after an overspeed. Even after the last update, didn't feel any different.
Old 10-06-2015, 11:18 PM   #7 (permalink)
Yea, totally doesn't play well with overspeeds
Component 700e smackdown (4 min 1 sec)
Goblin 570 maiden (3 min 44 sec)
Old 10-07-2015, 01:29 AM   #8 (permalink)
I've seen those overspeeds in person and they're no joke.
The way Castle ESC's handle overspeeds IS a joke. It chops throttle, so if you load the head up right after the overspeed the heli will BOG like it has shut down.
The Brain governor seems to hold throttle output for a second when the OWB unlocks. So what happens if you settle into a hover, is that the rotor stays at a higher RPM that setpoint for JUST a second. However, if you overspeed it and load the head right back up, the Brain governor gets right back into its groove and holds headspeed just fine.
I suspect any bogging after an overspeed on the Brain is a tuning issue. Just like I suspect that if the Castle governor had more tuning options, we could cure its bad tendencies. But the fact is, Castle doesn't offer this. Brain does. For me, FBL governor is the only way to go.
Old 10-07-2015, 06:24 AM   #9 (permalink)
Component 700e smackdown - YouTube
Goblin 570 maiden - YouTube
It would be foolish to expect anything less from any heli coming from one of the guys that helped develope the algorithms for the ikon.
Not an average pilot by any means and even alex will tell you there was a huge number of flights to get that working the way it does.
Once again Nick, don't get my words twisted. I said the Ikon gov didn't work for me. It MAY have had I wanted to focus time on tuning but I'd rather focus my time on flying and progressing. For me personally, I prefer products that fit my flying style with as little tuning as possible until I progress to the point where something needs to be tweeked.
It does seem the Ikon gov works well on 450 size machines with little to no tweeking so maybe it will work for him.
But I can tell you that none of my helis bog or miss a single beat on the HW gov.
