Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > Blade 230S
Blade 230S Blade 230S Helicopters Information and Help
Old 03-11-2017, 12:22 PM   #1 (permalink)
Default Flight and take off advice
Hi all. Been out today with my 230s. Found on spool up in stability mode the heli wants to tip over. I'm almost flying it before it's off the ground. Is this normal and is there any way of correcting this other than on the sticks.also returning to land the Heli gently lowers until it suddenly drops without warning needing more collective??? Any advice appreciated thanks
Leedodd is offline        Reply With Quote Quick reply to this message
Old 03-11-2017, 01:01 PM   #2 (permalink)
This seems to be recurring topic as of late..lol
First things first, every small Blade/E-Flite heli I've ever flown tends to tilt on lift off. Chances are your 230s is acting normal. The flight system doesn't know how to act on the ground, it's a ''flight system'' after all..lol Vibrations, ground effect, friction from the skids, etcetera, etcetera.
Now with that being said, I've done a few tests today to see how ''my 230s'' would act.
I've found, for the most part, taking off in stability mode seems to be the most ''stable''
A nice slow throttle up, a little cyclic input, will usually get it in the air pretty uneventfully.
Now that's not to say you can't do it other ways. You can take off in agility 1 or 2, but it can get out of hand quickly if you're not used to it.
I found, with ''my 230s'' that taking off in agility 1 or 2 can be smooth as butter, or more like a pissed off hornet..lol It depends on the amount of pitch I give it during spool up.
I'm pretty used to how mine acts, so it's no longer an issue in any mode. You will get there too.
T-Rex 250 450x 300x 180CFX MCPX-BL B400 130X MCPX 230S NANO-CPX NANO-CPS MSRX 120 SR MSR MCX
IF IT CAN'T BE FIXED WITH DENTAL FLOSS, THEN IT CAN'T BE FIXED..LOL
Liduno is online now        Reply With Quote Quick reply to this message
Old 03-11-2017, 01:09 PM   #3 (permalink)
I take off in stability mode and mine likes to tip left . i just counter it with right collective and throttle up. as soon as its in the air the as3x kicks in .
I usually land in iu1 and use throttle hold a foot or so above the ground, but iv'e not noticed any sudden drops sry .
Align 470LP, ALZRC 450Rigid ,ALZRC D380,Oxy2FE,Blade 230s,Blade 180cfx,XK-K110
Spazztl is offline        Reply With Quote Quick reply to this message
Old 03-11-2017, 01:12 PM   #4 (permalink)
Sometimes sudden drops can be from wind, or simply just lowering the throttle too much. Much like taking off, landing seems more stable in stability mode. It can be done in all modes once you're used to how it flies.
Old 03-11-2017, 01:15 PM   #5 (permalink)
Just read through the other post on hear about the same problem. I'll just correct it an take off a bit quicker. Sudden drops are a bit of a pain though.
Old 03-11-2017, 01:20 PM   #6 (permalink)
I've managed to do a few flips now and hover in iu1 for about 15secs a time. At height at the moment so it's difficult to tell when your level unless heli moves . Getting used to it now as spending a lot of time on the sim
Old 03-11-2017, 01:26 PM   #7 (permalink)
Much cheaper to crash on the sim.
Old 03-11-2017, 01:27 PM   #8 (permalink)
Inverted hover that is ha
Old 03-11-2017, 01:57 PM   #9 (permalink)
Too cold, too wet (see my location!)
toys2cars2toys is offline        Reply With Quote Quick reply to this message
Old 03-11-2017, 03:54 PM   #10 (permalink)
on the inverted hovering . I'm working on tail in inverted at the moment , Adrenaline pur! The 230 really shines at learning new things
Old 03-11-2017, 04:51 PM   #11 (permalink)
I'm mearly 7 packs in with my 230s which is the first cp heli I've successfully(I'll save my embarrassing head first jump to a blade 450 stories for later) flown. Mine tips any random direction on takeoff in stability mode, but it's usually before it gets up to takeoff speed. The tail kicks hard right also during wind up. Some tail guidance on the stick solves that easy enough. A little collective to keep it level and a smooth, quick increase on the throttle stick once it's up to speed gets it off the ground without event. Half an inch off the ground and it's smooth as glass though. I've had zero issues on landing in stability mode. Calm, smooth and precise.
I've not tried takeoff/ landing in agility 1 or 2. I did do a side roll at a couple hundred feet in 1. I needed quite a bit of that altitude buffer to complete it, about 3x what I would have guessed. Higher rates or agility 2 probably would have helped, but it was a baby step for me. Definitely give yourself lots of space/ altitude doing new maneuvers, that's my recommendation. I'll go crazy on the SIM, but it's a lot more stressful and harder in real life early on anyways...lol
N8KC is offline        Reply With Quote Quick reply to this message
Old 03-12-2017, 01:09 AM   #12 (permalink)
Weathers a bit better today so I'll b off out again today. Nice to see some one else in Cumbria flying. Thaught I mite be the only one. Any one no of any clubs in Cumbria for helis
Old 03-12-2017, 07:01 AM   #13 (permalink)
Climb to the top of Blencathra and take off from Sharp edge. Then it won't matter which way it tilts.
wab223 is offline        Reply With Quote Quick reply to this message
Old 03-12-2017, 07:53 AM   #14 (permalink)
Blade 230 S take off options (2 min 38 sec)
Team Scorpion Team Boca Bearing Team Revolectrix
Check out my Heli Pilot Shirts https://teespring.com/stores/rc-heli-pilot-shirtsMy Youtube channel
http://www.youtube.com/user/JJInvert...n?feature=mhee
d12bn is offline        Reply With Quote Quick reply to this message
Old 03-12-2017, 08:54 AM   #15 (permalink)
If you watch his thumb, he makes corrections on every lift off.
Old 03-12-2017, 10:27 AM   #16 (permalink)
Default Crashed 230
Out today. Takeoffs are getting easyr now.went inverted hover and the light gust of wind pushed heli to close to me and the ground for my likeing. Instead of staying nose in I tried to rotate it to tail in. Not enough time and crashed into a small stream. Battery gone speed controller gone reciver gone. My fault for trying things I'm not really ready for ha. New 230 is out the box ready for right side up hovers and turns only
Old 03-12-2017, 11:15 AM   #17 (permalink)
I'm gonna guess you were flying at or close to eye level? Try to fly 3 mistakes high..lol
Old 03-12-2017, 12:33 PM   #18 (permalink)
Would have been about 20 ft . I'm going to be hovering and flying normally for a while. And definitely higher ha . At least I have a lot of spares. how many helis and crashes will I end up with. A lot I'm thinking ha. Really good fun flying though
Old 03-12-2017, 12:35 PM   #19 (permalink)
How high is 3 mistakes
Old 03-12-2017, 12:56 PM   #20 (permalink)
Its just means give yourself ample time to recover.
Its a good suggestion and impossible at the same time.
Your confusing me because you are going inverted and yet you sound like you are new to CP helis?
