RealFlight Flight Sim All versions of RealFlight Sim |
03-09-2008, 11:42 AM | #1 (permalink) |
Align T-Rex 500 Model
Hey guys-
The T-Rex 500 Model is available! Collective Designs has been hard at work on this model since we first posted the "teaser" shots. Anyways, enough talking, go get the model! Click HERE to get to the base model. Make sure to get the colorschemes too! Edited: Thanks mods! Last edited by ChrisH; 03-11-2008 at 05:34 PM.. |
03-09-2008, 12:53 PM | #2 (permalink) |
Woot... I'm anticipated this one for a while. Thank you. I'll grab it and test it out
David Trex500 CF 3x5425MG, 1xAlign650, Kontronik 80LV, Vbar 4.0 Logo 600 3xBLS451, 1xBLS251, Kontronik 80HV, 10S, Vbar 5.0 Pro |
03-11-2008, 03:57 AM | #3 (permalink) |
Flies just great, thanks guys!!
03-11-2008, 01:32 PM | #4 (permalink) |
Team Taco CEO
Great Job guys, it's the only model I fly now when I load G4.
Kevin Don't Taco My Pack, Bro! , Why crash when you can POUND it! |
03-11-2008, 03:41 PM | #5 (permalink) |
Thanks to our fellow Helifreaks who helped make this possible.
Finless, Fireup and Jason Chow's feedback was most helpful in getting the right feel for the bird. We appreciate your collaboration. Frank... |
03-15-2008, 03:32 PM | #6 (permalink) |
how can i get a program that edits, design your own paint scheme, for G4
03-21-2008, 09:18 PM | #8 (permalink) |
What a zippy little joy! Thanx so much! My new training tool and so much fun to fly! BUT, tail is a bit too sensitive. How can I adjust that?
Not one of us is as smart or knowledgeable as all of us bonding together. Brett |
05-31-2008, 08:02 PM | #10 (permalink) |
Sorry to dig up an old thread:
Is this model better than the one in Expansion Pack 5?
She felt like someone of an ambiguous age that even neilg would approve of... |
06-24-2008, 05:16 PM | #13 (permalink) |
We created it to look and feel as closely as possible to our own Trex500s.
We had great input and feedback from some of our fellow helifreaks to achieve that. Having said that, and as stated in your other thread: My real-life heli will fly somewhat different from your heli due to the fact that we may be using different power systems, pinions, throttle/pitch curves, expo or dual rate. Way too many variables to consider. What we give to you is a good solid baseline that you can use to adjust the Simulator model to fly exactly like your own. Don't be afraid to modify and tweak what you get. Now, as far as the Expansion Pack: That is an "officially blessed" model by JK according to Kyna. (https://www.helifreak.com/showthread.php?t=68698 See Post#6) But: you get to pay about $29 and need G4 for that kind of endorsement. That's my opinion of course, I do not speak for my CDT teammates. |
06-24-2008, 06:05 PM | #14 (permalink) |
Another CDT teammate here ...
Two of the most important things to "get right" for a good simulator model are the pitch curves and power system. Both of these are easily adjustable in the simulator to make the helicopter feel more like your real-life bird. With that said, the "CDT Trex500" is set up with a 6S battery and 13-tooth pinion. Of course, if you run a 5S setup in real life, the Trex500 in the simulator will feel more powerful and nimble. As far as editing the models ... just go up to the Aircraft menu, and then hit Edit Aircraft. Make sure "Advanced Properties" are also turned on (also in one of the menus above). From there, just play around with the values in each category to tune it to your liking. Hope this helped! |
06-24-2008, 10:43 PM | #15 (permalink) |
I've been editing the CDT to emulate a 6S A123 model. I keep getting a tail "wiggle" while cruising around... how do I stop this while maintaining the 2300 rpm head speed (I do not want to lower the head speed, or change the blade size from 425mm)?
06-25-2008, 01:55 AM | #16 (permalink) |
Hard to say with just that description. I'd lower the gyro gain as a starting point, and see if that fixes it.
Gyro gain is located under the "Electronics" category, and then "Heading Hold Gyro". Lower the value for the "Heading Hold Gain". |
07-17-2008, 04:24 PM | #17 (permalink) |
silly question
Hi
sorry for this silly queation but,,,,,,,, I have just loaded g4 ( was a XTR lad) and have tried to load this model but no joy ??? can some one please talk me through what i am ment to do??? i have the file and unziped it but then it all goes wrong?? Help Please Cheers JJ |
07-17-2008, 05:25 PM | #18 (permalink) |
Well, you don't unzip it. Save it in its original form as a .g3x file to a location you can find later. Use the "import" function from the Simulation menu to import it into the simulator. Quick note, you want to import the _EA file first, this is the (Entire Aircraft), later you can import any Variants (_AV) or Colorschemes (_CS). Good Luck, Frank... |
07-27-2008, 04:05 PM | #19 (permalink) |
WOW great heli. My hats off to you guys.Thanks Any chance of the Yellow /Black blades?
Cheers, Glenn Outrage Fusion 50 FBL SK720 12s Xera 4025-560,Kon.HV 80 ,JR8717,OR 9088 on 6v TP 6s 65c 3300's Trex 700CHP FBL SK720 MX510,Kon HV 80, JR 8717,OR 9188, 6v, TP 6s 45c 4400's |
07-28-2008, 12:57 PM | #20 (permalink) | |
However, there is a black blade with yellow tips (I think it's the MD500 scale blades), and the Align white CF blades. |
