Go Back   HeliFreak > R/C Helicopter Support > Kasama Helicopters and Upgrades
Kasama Helicopters and Upgrades Kasama Srimok 90 Helicopters and Upgrades Discussion
Old 06-12-2013, 03:49 AM   #1 (permalink)
Default Main gear crown sliding down on one way bearing on FAIFA
Hi all !
I'm very happy with my Srimok FAIFA but yesterday i've had a little problem :
The aluminium main gear case slide down on the one way bearing (2 mm)...
So the main gear crown (with the main gear case) is down and touch on is down side the frame !!!
Do you have seen that before ?
I don't know how the one way bearing is block in the main gear case, mine was assembled by kasama.
I will disassemble them end reassemble, but must i use loctite 638 or 648 or other ?
Helisud
helisud is offline        Reply With Quote Quick reply to this message
Old 06-12-2013, 03:52 AM   #2 (permalink)
HF MR Support
Can you post some close up pics?
Lynh
TommyBear is offline        Reply With Quote Quick reply to this message
Old 06-12-2013, 01:53 PM   #3 (permalink)
Yes
ID:	427908   Click image for larger version
ID:	427909   Click image for larger version
ID:	427910   Click image for larger version
Old 06-12-2013, 06:45 PM   #4 (permalink)
First time I see or hear of this happening.
I guess you'll need to disassemble the main gear case, pop the OW bearing completely out, clean the surfaces and apply some bearing retaining compound (648 I beleive it is) then push the bearing back in.
Should not be too difficul.
Zbawer is offline        Reply With Quote Quick reply to this message
Old 06-13-2013, 01:50 AM   #5 (permalink)
Thanks !
That what i was thinking to do. But i was thinking too maybe that the OW bearing was forced in the main gear case (hot main case--cold OWB). In a brand new kit OWB is already installed in the main gear case so don't know how they mount it !
It's a strange issue cause my FAIFA run very smooth without vibration (Vbar vibration analyser confirm that) in flight, all was well.
It's not a so big problem but i did not think it could happen !
Helisud
Old 06-15-2013, 05:08 AM   #6 (permalink)
The response of Gavin from Kasama :
"Hi Stephan,
This can happen sometimes but I don't see it often. Caused by slightly oversize housing internal diameter. You can use Locktite 609 green colour ( retaining compound for bearings ) Try and wick some in between the bearing and the case. Then tap it back in with a hammer. Not a big problem but if the case is hot after a flight it means it is slipping.
Kindest Regards
Gavin Broadbent "
Old 06-15-2013, 09:56 PM   #7 (permalink)
The bearings are normally mounted into the hub with a press so I guess the hub was machined a tad oversize - we're talking hundredths of a mm here so I think Gavin's advice is good - you even use green Loctite as these bearings never break and the chances of having to remove one in the future are negligible.
John
Old 06-16-2013, 02:38 PM   #8 (permalink)
Thanks John !
I've used Loctite 603 (i had it in my loctite stock) which is similar than 609 to remount the OWB with a press yesterday and Srimok fly well today !
I love it !
Helisud
Old 05-03-2014, 02:24 AM   #9 (permalink)
Thanx for this thread! The same thing happend to my main gear hub as well. Now i know why the main gear is rubbing on the beavel gear bearing block!!
Will try to loktite it in today!
Helis:; Kasama Srimok ECO - V-Bar; Kasama Faifa LRH V-Bar; Voodoo700; Trex700N; Radio: MX-20 Hott
Stallion is offline        Reply With Quote Quick reply to this message
