Old 08-27-2011, 09:42 PM   #21 (permalink)
It worked. Thanks!
JoeR is offline        Reply With Quote Quick reply to this message
Old 08-27-2011, 09:42 PM   #22 (permalink)
Any port other than the sys port can supply power.
fastflyer20 is online now        Reply With Quote Quick reply to this message
Old 08-27-2011, 09:42 PM   #23 (permalink)
Member
Originally Posted by JoeR View Post
It worked. Thanks!
Good deal.
Old 08-29-2011, 04:36 PM   #24 (permalink)
i was surprised by how easy it was to update. The only thing i had to do was restart my computer after it found the driver for the usb programmer. Then run the updater.
XLPower Specter V2 - Rotorflight - ELRS
OMP M2 Explore - Rotorflight - ELRS
TX: Fr-Sky X9 Lite S / RM Pocket - EdgeTX - ELRS
P.I.Engineer is offline        Reply With Quote Quick reply to this message
Old 08-31-2011, 09:40 PM   #25 (permalink)
Originally Posted by Helico-pteron View Post
You WILL need to re-set up after installing this update.
I got a DX8 a few weeks ago and instantly put all my planks on it since they are easy to setup. But...............I've been still taking my DX7 to the field for the 450pro and fusion 50 which both use MB. I've been too lazy to re-program them on the new radio.
Well it looks like the MB is getting updated to v3 and going on the DX8 finally since you have to re-set up after the update!
HugoCraft is offline        Reply With Quote Quick reply to this message
Old 09-07-2011, 04:29 PM   #26 (permalink)
Just updated to V2 on the BeastX and it was fairly simple, but I found the BeastX version a bit hard to read.
This is for Windows
1. Download the updater and 2.0 software(.zip).
2. Install the updater.
3. Goto: Start/All Programs/BeastX/Install Driver and follow instructions
4. Open Device Manager(Start/Right click My Computer/Properties/Hardware Tab/Device Manager Button), plug in the USB dongle. It should appear as follows:
5.Open the 2.0 firmware zip file and double click the BeastApp icon, select "open file", the updater will automatically open with the 2.0 file inserted into the "Update File" field.
6. Connect lead from USB dongle to BeastX SYS port paying attention to polarity.
7. Remove main blades from the blade holder and open them if they are folded. **After the unit has been updated it will initialize whether it sees a Tx signal or not.** Power on the BeastX, you do not need to wait for initialization, the updater only needs power to the unit to update.
8. Click the "Refresh" tab in the updater window. You will see the current version of your BeastX unit appear in the bottom field.
9. Click the "Start Update" tab. Are you sure? Yes
10. You have now updated your BeastX. Enjoy!
Great instruction !! My MB is still in the box - not install to my 450 Pro yet. Can I update the firmware to V3 using your instruction ? Do I need extra power to MB or USB dongle provide power to MB's SYS port ?
Thanks,
Nano CPx, Hirobo Quark
250 SE, Pro Upper Frame, Talon25, KDE, KST215, DS95i, Mini Vbar
450 Pro (6s), KDE, Lynx, Tarot, RJX, YEP40, KST215 & 515, SK540
465 (6s), Align DFC, HW50AV3, KST315 & 8910A+, SK720BE
lcc014 is offline        Reply With Quote Quick reply to this message
Old 09-07-2011, 08:15 PM   #27 (permalink)
Member
Thanks,
The USB interface does not provide power. It must be supplied in one of the servo ports.
Old 09-08-2011, 08:29 AM   #28 (permalink)
Thanks. Can I use a 4.8V receiver battery and plug it into one of the servo ports ?
Old 09-08-2011, 01:34 PM   #29 (permalink)
Yes
Old 09-08-2011, 01:44 PM   #30 (permalink)
Originally Posted by fastflyer20 View Post
Yes
Thanks so much.
Old 09-13-2011, 04:58 AM   #31 (permalink)
I must be a complete computer operator moron.... 90 minutes now trying to find the updater software at beastx to install so I can run the v3 software. Never used the usb interface before. I crammed it into my laptop and it finally got some drivers to make it happy through windows but no base program that I can find to run the v3 update or interface from.....
"It's not the crash so much as the sudden stop"
Compass 7HV, Compass 6HV, TRex450Pro, bunch of other junk in boxes ... Team Flybar Team Tail-In wannabe....
sarpilot is offline        Reply With Quote Quick reply to this message
Old 09-13-2011, 10:40 AM   #32 (permalink)
Well they don't make it simple.
You need to download and install the installer and have it recognize the USB first BEASTX Update Bundle WIN
Then you need to down load one of the files from the top of the page, that is the actual V3 software. I used
the third file from the top of the page - BeastApp with the .upd extension.
Use the install directions from the BeastX web site.
Hope this helps
Old 09-13-2011, 02:25 PM   #33 (permalink)
I found the v3 software and have it downloaded but cannot find the updater software anywhere... what tab is it under? thx....
Old 09-13-2011, 03:05 PM   #34 (permalink)
Same page, one of the icons lower on the page labeled "BEASTX Update Bundle WIN" if you are using Windows.
Old 09-13-2011, 05:28 PM   #35 (permalink)
ok gotcha thx..... Ill give it a whirl when I get home....
Old 09-14-2011, 12:43 PM   #36 (permalink)
Has anyone had any problem with the BEASTX Update Bundle WIN not having a driver for Win Server 2008 64bit? It shows up in the device manager, but no driver installed.
Gaui X5 FES, Scorpion 910kv, Gaui GS-501, Gaui GS-502, BeastX, R6208SB
Gaui X7 FES, Scorpion HKIII-4035-500, Torq BL9180, Savox SB272-MG, Mini vBar, R7008SB
18MZ
chadew is offline        Reply With Quote Quick reply to this message
Old 09-14-2011, 08:03 PM   #37 (permalink)
you should be able to manually install the one for win7 64bit.. but i cant imagine it is common. Why are you using server 08 for a desktop (or a server to update a beastx)?
desertstalker is offline        Reply With Quote Quick reply to this message
Old 09-15-2011, 06:50 AM   #38 (permalink)
I did finally get it to work. I had to get a driver from here. http://www.silabs.com/products/mcu/P...CPDrivers.aspx Once that was installed it worked perfect.
I use Server 08 because it runs faster on older PC's with less ram. My laptop is kinda old and slow and Win 7 just boggs it down.
18MZ
Old 09-20-2011, 12:47 PM   #39 (permalink)
it says hardware version 1.1 on mine. application version 3.0.0 and data version 6.1.
is this all correct? i bought mine beastX before version 2 came out.
stay frosty
dx7
trex700 - 91H - hatori sb20fh2 - beastX+ds650 - 3xds610 - sgpro - ar7100r
eimbot is offline        Reply With Quote Quick reply to this message
Old 09-20-2011, 09:14 PM   #40 (permalink)
Fear the Spork!!
that's correct. you are on version 3. when you initialize the MB the A and B light should come on.
Trex 450L, OMP M2, Futaba 14SG
Spork01 is offline        Reply With Quote Quick reply to this message
