| 450 Class Electric Helicopters 450 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
this is ma first 6Ch heli, ive done wot i can to adjust setting etc... but for sum reason it wishes to spin out of control, when i attempt lift off how can i stop this? ill be adding a Vid if needed, PS i bought this heli off a friend i dont even know wot gyro it is
Does the gyro have a label with a name or model number on it?
Have you watched any of the Finless Heli Skills and Setup 101 videos?
Warp 360 Spartan Vortex VX1 |
#3 |
the Gyro i hav i got it with no label
, well ive watch sum of the vidz that has to do with radio programming, i follow wot he said my Radio is totally Diff btw (T6EHP-E)here is a vid of ma problem and a view of wot my components are http://www.youtube.com/watch?v=aVU5l...ature=youtu.be Last edited by taxiwarez; 05-22-2012 at 12:46 AM.. |
#4 | |
turn on the gyro and and allow it to initialise in heading hold mode and try this for me put the heli in front of you so that the tail if facing you. if you move the tail to the left the pitch slider should move to the right. if you move the tail to the right the pitch slider should move to the left. Im assuming you heli tail is doing the opposite of what I have mentioned and therfore you will need to reverse the gyro direction. |
#5 |
this is a good video on setting up a tail gyro if you go to 4mins 20 sec of the video it talsk about tail direction. This will explain the right direction the tail should go when giving left and right stick input. |
#6 |
I can't help, sorry (just buying my first 450). But please be careful. Spooling it up in the house, right next to you, especially when some things may not be set up quite right (so it might do something unexpected) can be dangerous. The blades will definitely cut you if you let them, even the tail rotor can be dangerous.
Tarot 450 Pro FBL. ZYX, Blade 450 X tail grips, 6S, Ice Lite 50, DS92A+ cyclics, DS215MG tail. BL Blade mCP X (HP05S, XP7A, dual coreless tail), mSR (sold), DX6i |
#7 |
The tail is easy to setup.
Gyro correction direction is as follows. Power on the TX, power on the heli. Note the leading edge of the tail blades. With the boom facing you, grab the tail, move the tail to the right. The leading edge of the tail blades will point to the left. If they do not, reverse the gyro, in the gyro, not the TX. Rudder stick on TX. When you push the rudder stick to the right, the leading edge of the tail blades will point left. the reason this is, is because you are "flying the nose" of the heli. Rudder stick right, nose right, tail left. If this is not the case, reverse the rudder channel on the TX. If you have any other questions, PM me. |
#8 |
your radio look basic but can you go into the rudder channel on your radio and reverse the channel direction?
If so this will change the direction of the tail. |
#9 |
Not if it's spinning out of control on lift off. That will not fix that.
#10 |
i just totaled it, gonna hav to rebuild it again
![]() ![]() Can sum1 Pm me sum popular electronics for this 450 |
#11 |
get this for your gyro. Easy to set u and just works great every time
http://www.spartanrc.com/store/produ...0&bestseller=Y get this for the tail servo http://www.hobbyking.com/hobbyking/s...sec_2_4kg.html get this for your three cyclic servos. They are very reliable and handle crashing well http://www.hobbyking.com/hobbyking/s...g_0_14sec.html |
#12 |
Excellent suggestions for hardware.
Heli's I've had:MCX2, MSR, HB FP V2, Blade SR, 120SR, Trex 250, Trex 450 sport, MCPX, Heli's I have: Trex 450 pro FBL BeastX (Clone Mostly Align), Gaui X5(SK540), X7(Vbar) |
#13 |
Is the gyro on its side?
#14 |
#15 |
I had another look at your video and definately looks like you mounted the gyeo on its side and not sitting flat right side up
I cant believe i never picked up on this. you need to lay the gyro flat right side up for it to work properly |
#16 |
Without knowing the brand, it's hard to say if that is right or not. Some gyros, like some of the Exceed and Esky ones are meant to be mounted on their side like that. What that video looks like is the gyro is in rate mode instead of HH. That is also what the red LED usually means, but again, without knowing the brand, that may not be the case. Usually if the gyro is reversed it will piro much faster than that, but it is unknown if any correction was being given by the op at the time.
Trex 450 Pro V2 Trex 450 Sport V2 Esky Belt CPX Blade mCP X |
#17 | |
I have not really heard of gyros that mount sideways Its probably better he upgrades to something familiar to everyone |
#18 |
Are you sure your tail spins in right direction? Sounds like not and Ira a common misstake 4 Us beginners. Should go,hm backwards.
#19 | |
Also, sorry about your main blades and boom strike.
