Old 08-22-2015, 04:20 PM   #21 (permalink)
Anyone tried the new sensors from Spektrum yet; for the flight packs or the Rx pack.
If so I presume you had to change the EC3 connectors and did you have a stick pack?
.......still learning!
Blade m SR/ m CPx/ nano CPx/ E Sky Belt CP V2
Align Trex 600 EFL PRO/Trex 600 DFC
Spektrum DX8/AR800/3GX with satellites
surferman is offline        Reply With Quote Quick reply to this message
Old 08-23-2015, 12:46 AM   #22 (permalink)
I am also interested in that one... and been waiting for a long time ))))
Oxy 2X-VertWarp 360Blade 450XBlade 450X NightflyerGoblin 500 ♦ 2 X mCPX v2 ♦ night fly mQXLadyMQXnano QXnano QX FPVInductrixDX8 G1
Coco66 is offline        Reply With Quote Quick reply to this message
Old 08-23-2015, 04:06 AM   #23 (permalink)
I believe they are still on preorder. Voltage is working well for me.
Too many helis & Too many planks
Lots of DX radios & A couple Futaba 72mhz radios
AMA member & Full scale plank driver
HELIFREAK !!!
aerocal is offline        Reply With Quote Quick reply to this message
Old 08-23-2015, 03:07 PM   #24 (permalink)
DPW
Default 35$ Volt Temp Amp Dx9 Setup
Originally Posted by jean-michael View Post
Hi guys. I would like to use telemetry on the dx9 to see the voltage per cell and consumed mah. Is it possible?
Thank!!
Dx9 or Dx8
and
Telemetry Station Orange $14.67
Current Sensor for Orange Telemetry ..$15.15
Voltage & Temperature Sensor for Orange Telemetry..$4.74
and a Rx and you have a temp volt amp telemetry system for any bird.
For setup see Customer files
Align450L / 470/150 DFC/Blade stuff
DJI/AR Drone
DPW is offline        Reply With Quote Quick reply to this message
Old 08-23-2015, 03:13 PM   #25 (permalink)
Originally Posted by Dipweed View Post
Dx9 or Dx8
and
Yeah. Still, the OP wants consumed mAh.
Old 08-23-2015, 08:57 PM   #26 (permalink)
DPW
Red face V=IR
V=IR
You have everything
Now
You can have rate or use or consumption over time in a chart thru telemetry data (T data).
Real time
or
On the fly
Ya Sure
As the T data is updated rates can be calculated and charted faster than the eye can see.
Last
How you want to see the T data via line or bar or pie chart is a simple MS excel function
DJI/AR Drone
Old 08-24-2015, 06:18 AM   #27 (permalink)
V=IR
You have everything
Now
Real time
or
On the fly
Ya Sure
Last
Lost. Did not understand what you mean at all )))))
I meant that the OP wants to be able to monitor the mAh used in real time so that his TX can alarm him that it's time to land since the pack is getting discharged.
Old 08-25-2015, 09:54 AM   #28 (permalink)
Default SPMA9605
are they available in any store yet
| Kraken 700 : Neo | Atom 6HV : Evo | Raw 580 : Neo | vbct |
ragge1 is online now        Reply With Quote Quick reply to this message
Old 08-25-2015, 10:20 AM   #29 (permalink)
Presumably you can order direct form horizon.
http://www.horizonhobby.com/aircraft...ensor-spma9605
They haven't released a manual yet, and they haven't mentioned how to solder the connections right to the board in order to handle high amps.
My castle logs are showing spikes into the 220A range, with averages around 80-100A. I don't think a little EC3 is designed to handle that.
Fauropitotto is offline        Reply With Quote Quick reply to this message
Old 08-25-2015, 01:49 PM   #30 (permalink)
problem I can't register as Norway is not in the list of countries , so got to wait when they come to other rc stores hopefully in the EU ( soon )
Old 08-25-2015, 04:38 PM   #31 (permalink)
Maybe you want to try here? Says they have it in stock:
http://www.der-schweighofer.de/artik...azitaetssensor
Or here:
http://www.d-edition.de/Spektrum-Air...etssensor.html
Or here:
http://www.hobbycenter.es/compra-fac...gy-sensor.html
Old 08-25-2015, 04:47 PM   #32 (permalink)
thanks
Old 08-25-2015, 04:49 PM   #33 (permalink)
Not sure it's true, though )))))
Old 08-25-2015, 05:15 PM   #34 (permalink)
they didn't have them in stock
Old 09-01-2015, 03:11 PM   #35 (permalink)
http://www.wheelspinmodels.co.uk/i/244441/
rotormasher is offline        Reply With Quote Quick reply to this message
Old 09-01-2015, 03:43 PM   #36 (permalink)
Originally Posted by rotormasher View Post
Out of stock
Old 09-03-2015, 01:34 AM   #37 (permalink)
Just received an email saying it's available here:
http://www.mhm-modellbau.de//part-SP..._term=SPMA9605
Old 09-03-2015, 02:14 AM   #38 (permalink)
I wanted to try one of these too but I thought It was a stand alone unit. Turns out you still need a receiver, tm1000, and this? I run satellites so I guess I'm out of luck. I am also a bit disappointed that you need to daisy chain all these options to the tm1000. Feels like spectrum is behind the times when it comes to telemetry.
fazy is offline        Reply With Quote Quick reply to this message
Old 09-03-2015, 02:35 AM   #39 (permalink)
You don't need a receiver, the TM1000 does its part by itself.
Old 09-03-2015, 02:53 AM   #40 (permalink)
Hey, Coco, que paso....
EEngineer is offline        Reply With Quote Quick reply to this message
