| Multi Rotor Helicopters Multi Rotor Helicopters Info and Support - Tandem, Quadcopters, Tricopters, Octocopters, and Hexacopters |
I want to mount my Naza Compass on the top plate right in the center. Think that will be ok? I know some of you guys have mounted them to an arm , how far out? On top of the ESC? Just dont want too much noise
Thanks |
You are right in thinking to keep noise at a minimum.
iwould never mount iy on top, or near An esc. Anything with high voltage, esc, vu, or distribution is going to generate a lot of noise. Fortunately, DJI gps is one of the best I have tested, ( only 3 tested ). I seems to work pretty well when necessity dictates placing it close to something it shouldn't be next to. Give it a test, see how well it works there. If it doesn't get a good lock, or doesn't get all the sat s, move it out to an arm.
Avant Aurora 90n,Trex 600E Pro, HC500, HDX450sev4, Trex 250se, mCP-X & mSR, Mosquito, X/A Hexa/WKM/FPV, 450 Flame Wheel,Gaui 330X |
#3 |
Mine is mounted on the arm at the main frame so I can still get the the screws. My battery is in the center at least until the new parts show up.
#4 |
Mine is mounted smack dab in the middle of the top plate without the shaft.
2 inches away from it I have the Skylark antenna. Both lock in and stay in but then my esc's are down below in the bottom plate.
When the people find that they can vote themselves money, that will herald the end of the republic. ~Benjamin Franklin ~ To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#5 |
On my DJI, I mount the GPS on one of the side tabs. Sometimes I like to fly with dual lipos. Mounting the GPS on a side tab allows me to strap one lipo on the top deck and the other under the belly.
MQX Quad,Align 550E/NazaH/GPS,Align450 Pro/CPII, Flame Wheel F450 Quad NazaM/GPS/GoPro2 Never lend money. It causes amnesia. |
#6 |
Thanks Guys. Im mounting it in the center, top plate like Mel's
