Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > mSR
mSR Blade (eFlite) Micro SR Helicopters Information and Help
Old 01-10-2015, 08:12 PM   #1 (permalink)
Question MSR yaws and slides fast in one direction
hi,
Newbie here.
Bought this MSR used about 2 years ago, haven't played with it in awhile. Played with it couple days ago seemed fine, then crashed broke tail motor. Replaced tail motor assembly(E-Flight brand) and the fin.
Now it will yaw and slide left really quick or fast, as compared to going right. It will also wanna move in a big circle on its own sometimes.
I tried adjustments on the controller and no reaction.
any help would be greatly appreciated.
mrekimf is offline        Reply With Quote Quick reply to this message
Old 01-10-2015, 09:50 PM   #2 (permalink)
Check to see if the guide pin on the swashplate hasn't moved in its position between the guide post on the frame,
Syma S107-Syma S109-Syma X8C-Syma X8G-Syma X5HC-Syma X5HW-Mini Orion-ProtoX-Syma X5C-1
USAF RETIRED 1968-1988 Vietnam Veteran
Pfloyd is offline        Reply With Quote Quick reply to this message
Old 01-10-2015, 10:31 PM   #3 (permalink)
If you are referring to item in yellow, it sits as it shows it the pic. But I can move it up and down almost from bottom to top.(pin sitting in guide), don't know if that's normal?
Old 01-11-2015, 01:33 AM   #4 (permalink)
It should only move a little bit. Are all your linkages hooked up? swashplate to flybar, flybar to blade grips?
Old 01-11-2015, 01:59 AM   #5 (permalink)
yup, everything is connected. Maybe swashplate is wore out?
Old 01-11-2015, 09:57 AM   #6 (permalink)
Swashplate is known to separate. That is what that little red tool is for,
E Flite Blade MSR Using SwashPlate Alignment Tool (2 min 58 sec)
Old 01-11-2015, 11:27 AM   #7 (permalink)
yup already did that.
Old 01-11-2015, 04:44 PM   #8 (permalink)
Did you put the rotor on backward or have the plug to the 5n1 in wrong?
Old 01-11-2015, 07:26 PM   #9 (permalink)
I did not put it on backward, but possible I plugged it in wrong. Let me check and reverse it and see what happens.
Old 01-11-2015, 08:08 PM   #10 (permalink)
its plugged in correctly, really out of control when plug it in other way.
Old 01-11-2015, 08:28 PM   #11 (permalink)
One last thing that I can think of. Sometimes in a crash, the feathering shafts comes out of the blade grips. Check that. Also, can you upload a pic of it with the canopy off?
Old 01-11-2015, 09:21 PM   #12 (permalink)
not sure what you mean but heres some pics. I also just broke the plastic body mounts, think they were weak from crashes?
ID:	562220   Click image for larger version
ID:	562221   Click image for larger version
Old 01-11-2015, 09:30 PM   #13 (permalink)
Try rebinding it. I see nothing out of order.
Old 01-12-2015, 09:55 AM   #14 (permalink)
The broken body mount is your trouble. Mine did the same thing.
It must let the frame flex causing the fly away.
ToXic U4ia is offline        Reply With Quote Quick reply to this message
Old 01-12-2015, 01:07 PM   #15 (permalink)
Are you referring to a canopy post. If so, that won't cause the problem. Worse case scenario is a crack 5n1 board or a bad FET. Everything looks normal in the pictures. One more thing, when you initialize the MSR, is it on a flat LEVEL surface and what radio are you using?
