Old 06-15-2015, 05:47 PM   #1 (permalink)
Default terot 450v2 tail moves to right i when punch thottle
ID:	591166I have terot 450 v2 with sbar work fine then crashed had to redo setup
cant figer the manul sas senser mounting direction /uphead/uptail/downhead/downtail the fbl is behind the head the normal place on 450 so what do I chose
rodneymueller is offline        Reply With Quote Quick reply to this message
Old 06-16-2015, 05:06 PM   #2 (permalink)
sounds like it would be up head.
NanoCPX,180CFX, Tarot 450 Pro V2, Raptor E550, Phoenix sim, DX6i, Taranis
JerseySgt is offline        Reply With Quote Quick reply to this message
Old 06-16-2015, 07:43 PM   #3 (permalink)
Default up head
up head wont that be were the battery is ?
Old 06-16-2015, 07:52 PM   #4 (permalink)
It's up head. The sensor is face up and the front of the unit is facing the head (front) of the heli. Whether the sensor is mounted in front or behind the rotorhead doesn't matter.
prismatic is offline        Reply With Quote Quick reply to this message
Old 06-16-2015, 08:17 PM   #5 (permalink)
tride uphead seser is tilting the same way the hely is tilting not oppsite
Old 06-16-2015, 08:27 PM   #6 (permalink)
Try moving the swash with your cyclic stick. Is it moving correct?
You might need to reverse the aileron/pitch servos in the radio.
Old 06-19-2015, 02:14 PM   #7 (permalink)
Default got it flying again
had to redo the setup on gyroClick image for larger version
ID:	591762 so now when I punch throttle tail drifts to right till im off throttle
Old 07-28-2015, 06:47 AM   #8 (permalink)
Can you add some tail precomp? Idk that fbl system but if I were to do a relative hard punch out on the collective and the tail kicked a bit to the right, adding tail precomp fixed this issue.
Goblin 380 (Spirit), X3 (VBAR), DX9
(I.Y.A.O.Y.A.S.)
alyon187 is offline        Reply With Quote Quick reply to this message
Old 08-02-2015, 06:49 AM   #9 (permalink)
1. Make sure the linkage is not binding anywhere and restricting/retarding tail collective movement.
2. Make sure the tail gain is as high as it can be without causing tail wag.
2. Increase rotor speed to increase tail rotor effectiveness. (you may have to reduce tail gain when you increase rotor speed.)
For reference, my Pro with a Dominator motor needs 2900 RPM to get enough tail rotor thrust to handle a collective punch. With a smaller motor I was able to drop the RPM below 2800 RPM.
YMMV
Regards,
Roger
Roger Fowler is offline        Reply With Quote Quick reply to this message
