Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > BCX/CX2/CX3
BCX/CX2/CX3 Blade (eFlite) CX, CX2 and CX3 Helicopters Information and Help
Old 06-12-2014, 11:55 PM   #1 (permalink)
Default Binding CX2 to DX6i?
Hey guys
Friend of mine cleaned out his old heli stuff and threw a CX2 police at me. It came as an RTF but he lost the transmitter.
It is possible to fly this with my dx6i? What sort of settings do I need to program? Thanks in advance!!!
Braddock54 is offline        Reply With Quote Quick reply to this message
Old 06-13-2014, 10:33 AM   #2 (permalink)
Default Sure can
And that little CX2 will actually fly a whole lot better hooked up to the DX6I than it did with the original radio that came with it....
Unfortunately - it's been several years since I played with that set up and don't remember any specifics...
Maybe try to research further in these CX2 threads ? ?
MSR, CX2, MCPX-V1,130X,450X, MD500, Trex500CF, Trex500GF, Protos 500C stretch, DX7 !
The difference between genius and stupidity is genius has limits
blade-man is offline        Reply With Quote Quick reply to this message
Old 06-13-2014, 09:28 PM   #3 (permalink)
Yea tried it all and did find a write up on how to do it.
I can't seem to get the Rx to blink before binding. It just stays solid. I have the bind plug in and the 3 in 1 disconnected. The battery is charged.
Any ideas?
Old 06-13-2014, 10:44 PM   #4 (permalink)
Okay now I get a flashing red on the receiver....still won't bind.
Old 06-16-2014, 10:03 AM   #5 (permalink)
Default Okay Braddock -
Here we go :
Borrowed a buddies spare DX6I for a day and relived old memories binding my CX2 to it.. It surprised me that it all came back to me as I started messing with it
__Create a new model in your Dx6I
__Make sure all toggle switches on the radio are in the "up" position
__Go to the set up list and change model type to "Acro" ( yes - your CX2 is going to
fly in "airplane mode" )
__Go to the "reverse menu" - reverse AILE, ELEV AND RUDD - leave the others in
normal
__In the "wing tail mix" menu - set all values to "INH" in they aren't already ( they
should default to this )
__In the "sub trim" menu - set THRO to negative 100 ( 100 with a down arrow )
__Exit all menus and turn the radio off...
__Bind the heli to the radio as per the instruction book ( assuming you have one ? )
__Check to ensure servos are moving in the correct direction prior to lift off ( should be
if all is original )
__ Take it easy and be careful on first flight - more than likely the tail is going to twitch
( or wag ) like crazy. This is pretty much the norm when switching to the DX6I and
can be adjusted out with the Gyro gain pot
This got mine in the air and flying like a champ - please let me know how you make out with it ?
Roger aka / blade-man
Old 07-25-2014, 08:24 AM   #6 (permalink)
Default Binding to CX2
OK Had the same problem with a newly rebuilt CX2. I have a new DX6 (black one) and wanted to bind it. plugged in the battery and got a blinking red light. Went to turn on the TX and go to the bind menu and tried 4 times to get it to bind and it would not.
SO HERE IS WHAT I DID AND IT WORKED:
Unplugged the battery. Turned of the TX. Put the bind plug in the RX on channel 6.
connected the battery. Got a red light blinking. Turn on the TX. Went to the bind menu and selected BIND. Light on the heli went to green with 4 slow flashes then solid. Took out the bind plug. Turned off the heli. Turned off the TX. Turned on the TX and then plugged the battery into the heli. WORKED!!!
CX2 now works fine. After you get it to bind make sure you always unplug the lipo if you are making adjustment to the 3-n-1. Also make sure that when you plug the battery into the heli it is sitting on level surface and watch the flashing green light turn to solid green before moving.
rcflyertim is offline        Reply With Quote Quick reply to this message
Old 08-04-2014, 11:51 AM   #7 (permalink)
That worked guys thanks a lot. Sure requires a lot of elevator input to get it off the ground though.
Old 01-25-2015, 09:47 AM   #8 (permalink)
Hey guys, I know it's been a long time since this post has been changed, sorry to revive it.
I followed the steps from blade-man and I just cannot find the "sub trim" menu on my DX6i!! After the "reverse" menu I have "Thro cut" with -INH or -ACT options... What am I missing?
Mokal is offline        Reply With Quote Quick reply to this message
Old 01-28-2015, 03:46 PM   #9 (permalink)
Sorry for the confusion, I guess I was quite a newbie a week ago: I found "sub trim" under the main menu for my model, I must have been looking under "adjust list" submenu earlier.
