Old 03-21-2009, 10:14 AM   #1 (permalink)
Question Surging power?
Just got mine together after a serious rebuild. I notice that the power is surging, resulting in the tail moving of course, but you can hear the RPM surge. I crashed and was a bit slow to hit TH. Is it possilbe the ESC is bad? What are the symptoms of a bad ESC, other than watching it smoking!?
Too many helis, too little time. Spektrum DX8
Trex 100, 250 DFC, 450 DFC pro, 550 V2 DFC
All FBL running AR7200BX
ryem3 is offline        Reply With Quote Quick reply to this message
Old 03-21-2009, 10:28 AM   #2 (permalink)
that happens when the batteries go below a certain voltage. Make sure your batteries are fully charged.
T-rex 250 Super Combo w/ hs-65mg's
Blade cp pro: spectrum receiver, BL main, DD tail, Gyro
www.bladecpupgrades.co.nr
Blade cx2
E-flite 4-site
helidude3 is offline        Reply With Quote Quick reply to this message
Old 03-21-2009, 04:44 PM   #3 (permalink)
I know. It totally seems like the ESC voltage cut off. But I have it on the middle cutoff setting and I've been running at that level for a while. Put 8 fresh packs through it, so it isn't the pack voltage. Could be that the cutoff is malfunctioning. I might try to reprogram it anyway.
Old 03-21-2009, 06:17 PM   #4 (permalink)
if its not that, then it is a bad esc. It seems like many of them go bad.
Blade cx2
E-flite 4-site
Old 03-21-2009, 09:20 PM   #5 (permalink)
This might be a dumb suggestion, but I had to redo my pitch curves after a rehaul because I ended up with a different feel after adding some things to the situation (16 tooth pinion, metal tail slider). At first it had the feeling of surging, but really I think the pitch curves were too dramatic with a different head spead.
devmode is offline        Reply With Quote Quick reply to this message
Old 03-22-2009, 03:58 PM   #6 (permalink)
Make sure you're not in gov mode.
gravydrive is offline        Reply With Quote Quick reply to this message
Old 03-22-2009, 08:11 PM   #7 (permalink)
Wrong! Switched it to governor mode and it runs well. Seems that the voltage cutoff is not working at the right level. Tried it at high, mid and even the third setting. Still kept cutting off. Switched it to governor mode and now it flies well. In fact, the governor mode seems pretty powerful. Not sure if this will have much of an impact on flight times, but it responds well to pitch inputs. Guess the ESC is bad. And this sucker is expensive - $40. I saw on another thread that someone is selling motors and ESCs for $40. Painful.
