Old 07-21-2015, 03:22 PM   #1 (permalink)
Default Trex 500 Gear Alignment
I installed the I2RC Boom Mount and the alignment is off. The old mount was OK. Any ideas on what the challenge is and how to fix it?
Thanks HF!
P 700 EVO, XLP Nimbus 550, P 380 EVO, Futaba ,YGE-T, neXt and Heli-X
Loud, sudden noises in a helicopter, WILL get your undivided attention
mlp3028 is offline        Reply With Quote Quick reply to this message
Old 07-21-2015, 06:27 PM   #2 (permalink)
fly it
Kap'n Krunch is offline        Reply With Quote Quick reply to this message
Old 07-22-2015, 07:19 AM   #3 (permalink)
I checked mine last night, and the gears are lined up. Did you use any shims in that gear?
*Spartan Vortex VX1e*
Old 07-22-2015, 05:23 PM   #4 (permalink)
Now looking for shims in the CNC Boom Mount.
Old 07-22-2015, 05:24 PM   #5 (permalink)
I did not use any shims
Old 07-23-2015, 10:39 AM   #6 (permalink)
Did you use the spacer between your OWB and main gear?
Old 07-23-2015, 10:47 AM   #7 (permalink)
meh....don't worry...its fine...just go fly it..
I have had Trex500s for years and years and only a few times, did the lower gears actually aligned well with the tail gears...even with the original gears and all! It's a hit and miss with them helis.
One thing I have noticed, it's actually getting worse with the newer models they come up.
The most recent Trex 500L its so bad it's scray....you should see how bad it is .it still flies good...don't worry
Kind regards
Alex
PS, no I do not forget to install shims, spacers and what not...they are simply badly sized!
Alex M K is offline        Reply With Quote Quick reply to this message
Old 07-23-2015, 05:52 PM   #8 (permalink)
Kind regards
Alex
same on my 500 and 550
Old 07-23-2015, 06:07 PM   #9 (permalink)
BTW...this is my 500L, when it was brand new, with stock gears ...see how bad it is?
Has hundreds of flights...now runs a 90Amp Kobi at 3200 / 3300RPM HS, BK servos, Scorpion 1600KV motor, Spartan FBL 8.2V and nothing happens to it...just fly it...
Kind regards
Alex
Old 07-24-2015, 03:00 AM   #10 (permalink)
The missalignement is not bad at all and is typical for the 500. Mine esp has it with all original parts.
Mateyhv is offline        Reply With Quote Quick reply to this message
Old 07-24-2015, 10:28 AM   #11 (permalink)
Smile Thanks folks!
Thanks to all for the assurances that the mis-alignment can be a normal thing and I can fly.
I contacted Bob at I2RC and he said the CNC boom mount "should" also have a couple of washers in the bottom of the vertical gear/shaft in a normal setup.
I am going to check that also. I'll report what I find.
Old 07-25-2015, 05:09 PM   #12 (permalink)
Smile
Today I pulled the main gear apart and the washer is in there, thanks!
Old 08-05-2015, 09:28 PM   #13 (permalink)
Post
Well, these are small dish washers that sit back-to-back on the tail rotor gear in the CNC Boom Mount. Bob from I2RC was kind enough to provide a few and it made the difference. There seems to be a vertical pre-load provided by the double convex washers lifting the gear set and providing the alignment.
Old 08-06-2015, 08:54 AM   #14 (permalink)
The i2 boom block should have come with two small "spring washers" that go below the tail drive gear if i remember correctly. I havn't disassembled mine in a while but can check tonight when i get home. Pretty sure my gear lines up correctly.
Either way, you look like you'll be fine as is.
Does the tail drive gear move up and down?
*LINKS*
* G700c BRAIN2 * T-rex 500 *308DUO *450x #429
Relisys190 is offline        Reply With Quote Quick reply to this message
Old 08-06-2015, 08:55 AM   #15 (permalink)
Looks like you got it. Enjoy the boom block, it's a work of art!
*LINKS*
Old 08-06-2015, 04:45 PM   #16 (permalink)
Smile
Thanks, it is a good looking addition. Looks like gear changes may be easier also. Thanks for the help HF
