550 Class Electric Helicopters 550 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
08-01-2010, 04:05 PM | #1 (permalink) |
550 Shopping list
Are you guys able to fit the 6s 5000mah HK packs on your 550s? I'm looking to order everything for a 550 setup this week but have seen the frame spacing is 47mm but the HK packs all have a minimum dimension of 49mm or 50mm. In the images I've seen it seems the battery is pushed back between the frames a little bit, I'm assuming this is where the pack needs to sit for a proper CG.
Thanks in advance for your help. |
08-01-2010, 04:25 PM | #2 (permalink) |
My Rhino 4900mAh 25C fits between the frames but doesn't really need to for good COG.
My Zippy 5000mAh 25C does not fit between the frames and gets good COG about 1/4" below that part of the frame.
Jonathan Livingston Helicopter Blade 400: E-flite 420H/35X ESC, AR6100e, HS65HB x 3, G401B/DS290G. (Ret.) CopterX 450AE V2: 430XL/35X ESC, AR6100, HS65HB x 3, LTG2100T/HSG-5084MG. T-Rex 550E V1 Classic Flybar: 600MX/BL70G, AR6200, DS610 x 3, Quark/DS650, 16t/520mm blades. |
08-01-2010, 05:15 PM | #3 (permalink) |
Thanks Wolfpackin, I really appreciate the help. I just ordered the 550 combo from my LHS today. Based on the posts of yours I've read it seems your happy with the 550, any input for me as I get ready to build mine?
08-01-2010, 05:22 PM | #4 (permalink) |
PM on the way...
08-01-2010, 05:40 PM | #5 (permalink) |
turnigy 6s 5000 40-50c work great.
they do not need to go in between the frames. |
