Go Back   HeliFreak > R/C Helicopter Support > 700 Class Nitro Helicopters
700 Class Nitro Helicopters 700 Class Nitro Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 10-28-2014, 01:51 AM   #1 (permalink)
Default helpp
i have a 700 align heli and the 2 bolts that are in the head stripped how can i remove the allen key bolts
Andrew2010 is offline        Reply With Quote Quick reply to this message
Old 10-28-2014, 05:44 AM   #2 (permalink)
Which two bolts?
= Rb43 =
Rob43 is offline        Reply With Quote Quick reply to this message
Old 10-28-2014, 08:43 AM   #3 (permalink)
Default bolts
as rob said ,which two ,theres a few ways to easily remove stripped fastners.
if your not in a hurry,some reg jb weld applied in the shcs and push the allen wrench in and let it set overnight(works for fastners with not a lot of accsess
7HV,Trex 700N,Suzi Janis 800,500 DFC ,NX4 Warp,all on HC3SX, 230s
mmracecars is offline        Reply With Quote Quick reply to this message
Old 10-28-2014, 12:41 PM   #4 (permalink)
the bolts in the main head where u need 2 allen wrenches to loosen it
Old 10-28-2014, 02:26 PM   #5 (permalink)
if your wrenches still have some bite, you could place the head in an oven set to 300F for a short time to loosen the threadlock, and try again to loosen them.
You will need to comlpetely degrease that screw head and wrench to get the joint to bond when using the JB weld..
If mmracecars suggestion doesn't work... I would probably cut spindle between the grip and head.
For future, if cap screws don't start to move with reasonable effort, it's always best to try some heat before stripping or breaking off the tip in the socket.
= Rb43 =
Old 10-28-2014, 02:56 PM   #6 (permalink)
thanx for the sugestions and tips i will probally cut it
Old 10-28-2014, 10:16 PM   #7 (permalink)
Good luck.
= Rb43 =
Old 10-28-2014, 10:21 PM   #8 (permalink)
might try ad maybe drill it first.
Old 10-29-2014, 05:28 PM   #9 (permalink)
k the drill aint working so ima try and cut the feathering shaft
Old 10-29-2014, 09:16 PM   #10 (permalink)
Lynx makes some very nice spindle bolts. Might want to look into a set before putting it back together.
marc8090 is offline        Reply With Quote Quick reply to this message
Old 10-29-2014, 09:27 PM   #11 (permalink)
funny u should metion that hahaha i just orderd 2
Old 10-30-2014, 10:36 AM   #12 (permalink)
I have those too. Beastly. Allows a bigger wrench for more leverage.
= Rb43 =
Old 10-30-2014, 05:16 PM   #13 (permalink)
ohh so thats why they are $15 lol for 2
Old 11-01-2014, 09:48 AM   #14 (permalink)
Were you successful at cutting the spindle?
= Rb43 =
Old 11-01-2014, 04:22 PM   #15 (permalink)
mm kinda hahaha i used a sawsal and accidently cut the rotor housing. least i have a spare
Old 11-02-2014, 12:15 PM   #16 (permalink)
OUch.
= Rb43 =
Old 12-01-2014, 11:59 PM   #17 (permalink)
Same problem here.
I managed by drilling the socket head, because I knew I would have replaced all the bearings. In this case also the spindle was spoiled, of course.
Riccardo
Synergy E5 / Protos Max V2 / Goblin Black Nitro 700 / Vbar Control
Airbass is offline        Reply With Quote Quick reply to this message
Old 12-10-2014, 08:37 AM   #18 (permalink)
hate when that happens
Old 12-18-2014, 10:57 AM   #19 (permalink)
Ya, I'm gona have to get creative with mine. I have a FB andf FBL head here that I can't loosen the feathering shaft bolts. Both are in great shape, just cant get apart for Thrust bearing lube/damper change
Dan Pesonen
mCX2, nCPX, mCP X, Blade 400, MSH PRÔTOS, T-700N
"Tri-Flow"
banditpowdercoat is offline        Reply With Quote Quick reply to this message
Old 01-13-2015, 02:44 PM   #20 (permalink)
mmm yaa i upgraded the head bolts so they wont strip as easily
