JR Helicopters JR Forza, Vibe and Vigor Helicopters Discussion |
04-06-2016, 10:04 PM | #1 (permalink) |
jr propo 450
I have a forza 450 and I am using a ar7200bx.This heli spin no matter what I do. Can someone help me get this thing set up? I am really going mad, been trying to get this thing to work for two weeks now. Please help.
04-07-2016, 01:23 AM | #2 (permalink) |
Ever setup a (FBL) heli before?
Looks like something needs reversing or your tail isn't driven properly...
Gaui X3 HW 50A V3 OMG H1/H2 Servo's BL450MX Mini-V (M.I.A.) Gaui X5 FES Polaris BEC BLS451/251 Silverline V-Bar Formula Swash/Head JR Forza 700 Scorp 160A opto + 4525 520 JR NX8925/SLG01 Vbar Neo JR XG14 PL8 v2 |
04-07-2016, 05:21 AM | #3 (permalink) |
jr forza
I have setup many blade heli's with success. This is my first jr heli. I have tried reversing the tx and tried the ar7200bx no fix. When I hold the tail blades and spin the main,there is no slipping and the blades spin counter clock wise.
04-07-2016, 07:01 AM | #4 (permalink) |
Have to agree with Mverhorst here. Brand of Heli has nothing to do with it. I am betting you have a correction reversed somewhere or the FBL is not accepting the change in setting for some reason. As long as the belt is tight and it is turning the right way and blades are on the right direction the Heli should be ok no matter who's it is.
Team Jr Americas |
04-07-2016, 08:18 AM | #5 (permalink) |
jr forza
I am spooling up with the blades off, could this be the problem. I usally do this to see if the tail holds. Thanks for helping me.
04-07-2016, 12:42 PM | #6 (permalink) |
The tail should hold without main blades.
I still think someting needs reversing. Does the tail slider move when you rotate the heli by hand (DO NOT SPOOL IT UP)? And which way does it go?
04-10-2016, 10:23 PM | #7 (permalink) |
When you are checking tail gyro correction- the trailing edge of the blades should move towards the direction the tail is moving.
R/C Outlaw (and proud of it) since February 20, 2016 |
05-08-2016, 08:52 AM | #8 (permalink) |
i kinda had the same problem with my black angel.
check and make shure your belt is on correctly , not that it's double twisted inside the tube.
Align 470LP, ALZRC 450Rigid ,ALZRC D380,Oxy2FE,Blade 230s,Blade 180cfx,XK-K110 |
