Go Back   HeliFreak > R/C Helicopter Support > SAB Goblin 630/700/770
SAB Goblin 630/700/770 SAB Heli Division 630/700/770 - Goblin Helicopters Factory Support
Old 11-03-2011, 01:39 AM   #81 (permalink)
Originally Posted by helicraze View Post
Can we have some more official pics???
We are preparing new website, manuals, spare parts list, videos, blogs .....
See you soon will be online, new website where they can stay up to date
Goblin Helicopters
goblinhelicopter is offline        Reply With Quote Quick reply to this message
Old 11-03-2011, 06:24 AM   #82 (permalink)
Originally Posted by goblinhelicopter View Post
If the unit flybarless consists of a single party (as miniVbar, BeastX, SK720 .....) you put on a support that has never appeared in the images
Follow this thread, soon will insert pictures of this support.
Will this support be included in the kit or is it a separately purchased item?
Lynx Team Pilot
Colonny5 is offline        Reply With Quote Quick reply to this message
Old 11-03-2011, 07:45 AM   #83 (permalink)
Does the heli need an anti static cables like in the LOGO?
Thanks,
Ron
ronefrat is offline        Reply With Quote Quick reply to this message
Old 11-03-2011, 12:19 PM   #84 (permalink)
Will you include the SAB swash plate leveller that you spoke of in the kit?
G.
TDR3DRigid Mikado V-Bar 5.1
Futaba8FG S-Bus
g-bru is offline        Reply With Quote Quick reply to this message
Old 11-03-2011, 01:18 PM   #85 (permalink)
Yes, in the kit the support flybarless single unit is included.
The Goblin is made of aluminum and carbon.
The pulleys are made of aluminum.
These materials are conductors.
The two tail pulleys are the same electrical potential.
You can not create electrostatic discharge.
No, the leveling of the swashplate is not included.
Goblin Helicopters
Old 11-06-2011, 07:37 AM   #86 (permalink)
Hi guys,
The area for ESC, is defined by an aluminum base that can act as a heat sink.
The size is about 58 x 100 x 35. Is not 100% rectangular.
Goblin Helicopters.
The images illustrate the mounting of three famous ESC in the Goblin.
Kontronik Jive 120
Scorpion 130A
Castle Creations ICE 160A
ID:	265041   Click image for larger version
ID:	265042   Click image for larger version
Goblin Helicopters
Old 11-06-2011, 08:08 AM   #87 (permalink)
Thanks for the photos, I was just about to post a question on this. Looking at the photo with the scorpion ESC does it have the modified battery position you mentioned in the other thread to make room for packs up to 64mm? Is the modification made by re-drilling or slotting the holes for the alloy rods under the carbon battery plate?
I am hoping that I can use packs that are 64mm with the Hawk 120HV (Robby Roxxy) or maybe the CC ICE2 120HV depending on the room available. Can you confirm that there is room for either of these setups so I can purchase packs please.
//Dennis.
soXos: Strike 8.1 - Strike 7.1 Light - Strike 6.1 : Goosky: RS7 - RS4 - S2 - S1
soXos DB7 nightflyer : Jeti DS-16 & DS-12
I am www.soxosaustralia.com.au | soXos helis | 1st-RC Products | EGODRIFT motors | Goosky helis | Spinblades
Thunder Fighter is offline        Reply With Quote Quick reply to this message
Old 11-06-2011, 08:58 AM   #88 (permalink)
//Dennis.
This info is critical to me as well. Also is it possible to just mount the ESC on the side of the frames?
OnTheSnap is offline        Reply With Quote Quick reply to this message
Old 11-06-2011, 01:05 PM   #89 (permalink)
Kind of an offbeat question but what are the means for transportation? Do you have to remove the blades or is there some kind of holder supplied with the kit
McCollister911 is offline        Reply With Quote Quick reply to this message
Old 11-07-2011, 12:23 AM   #90 (permalink)
//Dennis.
The previous photos were with the standard position. (maximum height 60 mm batteries)
The attack bore with the position 64 mm
The CC 160 ICE can be used.
Goblin Helicopters
Old 11-07-2011, 12:32 AM   #91 (permalink)
For transportation no need to disassemble the blades.
In the kit there is a blade holder.
Goblin Helicopters
Old 11-07-2011, 03:50 AM   #92 (permalink)
Isn't that a Jive 100LV in the pic...not a 120hv? 120hv would be bigger than the 100lv im assuming but would still fit...
Nikon D4/Sony Fs700/Cinestar 8/8FG super/Dx8
Twister773 is offline        Reply With Quote Quick reply to this message
Old 11-07-2011, 07:52 AM   #93 (permalink)
Sao
I'm curious as to how the tail boom is constructed.
Is it a one piece mandrel layup or is it made in two halves like a clamshell?
Goblin 500 V-Bar, Goblin 380 V-Bar,T-Rex 500 V-Bar Align Cobra Fuz, E-Flite Blade 180CFX, TBS Gemini FPV, CYE Stingray FPV, some planks.
Sao is offline        Reply With Quote Quick reply to this message
Old 11-07-2011, 10:04 AM   #94 (permalink)
120HV has the same footprint as 100+, only about 1/4th inch thicker (6 mm, according to specs, to be exact) . Non-issue, according to pics.
Cheers,
Rok
Impunitus is offline        Reply With Quote Quick reply to this message
Old 11-07-2011, 02:38 PM   #95 (permalink)
Sorry for the mistake.
Attack two photos where you mounted the 120HV.
In the second image you can see the position of any 2S batteries.
ID:	265318   Click image for larger version
Goblin Helicopters
Old 11-07-2011, 11:19 PM   #96 (permalink)
i have a scorpion 4525-520LE waiting and it has 38mm long shaft... from those pics it seems that the shaft is too long to fit when batteries are installed... but still Tareq fly with that motor??? is Tareq's motor modified or...?
Tohtori R is offline        Reply With Quote Quick reply to this message
Old 11-08-2011, 04:51 AM   #97 (permalink)
You can always cut the shaft with a dremel if needed. Not a big deal.
Old 11-08-2011, 06:40 AM   #98 (permalink)
what is the service life of the belts for replacement.
Magneto is offline        Reply With Quote Quick reply to this message
Old 11-08-2011, 10:31 PM   #99 (permalink)
How strong is the area around the esc? With the 700e I crushed many batteries during crashes and bad autos. I would hate to have to buy a new esc after every bad auto.
NO FLYBARS
504Rone is offline        Reply With Quote Quick reply to this message
Old 11-09-2011, 12:16 AM   #100 (permalink)
Mr. GoblinHelicopter,
What's the tallest motor that can be used in the heli? From the pics, it looks like the scorpion 4525 almost touches the top of the canopy already.
Thanks!
chuongtd is offline        Reply With Quote Quick reply to this message
