Old 05-11-2012, 11:16 PM   #1
HeliFixer
Default 500E Pro Paddle Question With Pics!
I would prefer to tame cyclic response down a little bit so I bought some KBDD paddles.
I bought them by hole size and they are considerable larger
The original Align paddles are 8 grams.
The replacement KBDD are 16 grams
Is this too lager of a jump in weight and size?
Any idea how much response I will lose... I guess there is only one way to find out, but rain has prevented real testing
Pic below
T-Rex 450 Pro V2 FB
550 Clone/Align Mutt
HeliFixer is offline        Reply With Quote
Old 05-12-2012, 09:35 AM   #2
Mateyhv
That may tame somewhat the cyclic but you could have achieved the same by changing dual rates and expo configuration on you TX coupled with a lower cyclic travel.
However those 600 paddles are an interesting trial for the 500.
Mateyhv is offline        Reply With Quote
Old 05-12-2012, 10:40 AM   #3
HeliFixer
I like that "interesting trial" I may do it just so I know but I bet I put the Align back on.
I was concentrating so hard on being sure the shaft size was right I didn't pay attention to the paddle size
Thanks! - still a little moist but It should dry off a bit here in a few thanks again!
- S
T-Rex 450 Pro V2 FB
Old 05-12-2012, 10:45 AM   #4
sarmeneau
they should work, just make sure you put them in the front hole and check how warm the power system gets. your going to push a lot of air with the bigger paddles also check to see how warm your cyclic servos get, they will have to work harder to move with so much more surface area.
Trex 500 ESP DFC FBL
BLADE 130X
GOBLIN 630 CC 120HV, Scorp 4225 610Kv, Outrage servos, Skookum SK720BE on order
sarmeneau is offline        Reply With Quote
Old 05-12-2012, 10:49 AM   #5
HeliFixer
OH yea good point thank you!
I'm not hard core yet but still good thing to watch.
Thanks! - S
T-Rex 450 Pro V2 FB
Old 05-12-2012, 11:20 AM   #6
ddj74
Heavier paddles to my knowledge gives more stability but makes it a little less agile / responsive.
T-REX 700 DFC v3, AR7200BX, ICE2 160HV,DC-UP MARK II
MKS HBL950 & MKS HBL980, GRYPHON EXTREME REGULATOR
POWERED BY THUNDER POWER LIPO'S
ddj74 is offline        Reply With Quote
Old 05-12-2012, 03:19 PM   #7
Mateyhv
+1 thats the theory!
However I dont think those paddles will be harder on the cyclic servos, any FBL sistem is much harder than that.
Old 05-12-2012, 03:31 PM   #8
Blayd
Actually, KBDD paddles are really made to enhance the response of the heli, better performance....and even though they are heavier, they're better design may negate the added weight with better response then the stockers.....Make sure you use the front hole.
Adding weights to the flybar would have worked better to slow its response down quite a bit, and again as Matey said.. you may have been able to slow your response rates down using expo and D/R, leaving you room to slowly work your way to less expo and D/R as you gain experience.
Trex700N2E
Trex500ESPTT(PRO head and Tail )
Trex500ESP (Belted)
HC500SE All flying Spartan, CC100A, CC20APro, Hitec 5245MG, Futaba 9257, Walkera Devo 8S, KBDD, i2!
Blayd is offline        Reply With Quote
