Go Back   HeliFreak > R/C Electronics Support > YGE
YGE YGE ESC Support and Discussion
Old 12-28-2015, 08:10 PM   #1 (permalink)
Default Settings on 90 lv with 480 extreme logo
Does anyone have the settings for this combo? I know mikado released a complete kit with this esc. I am looking at buying each of these items separately so was wondering what the settings would be.
DaweMD is offline        Reply With Quote Quick reply to this message
Old 12-31-2015, 11:25 PM   #2 (permalink)
what fbl and what motor
you should look into it...........
crf69 is offline        Reply With Quote Quick reply to this message
Old 01-02-2016, 11:48 PM   #3 (permalink)
So I decided to keep my 400se and set it up with this esc. The 90 lv I bought separately from rotor quest. I was looking at using it with either a fullsize blue vbar or the mini vbar blue. The motor is the one from the logo motor kit. Scorpion HK4015-1070.
Old 01-02-2016, 11:50 PM   #4 (permalink)
I also bought the programming card with it as well
Old 01-03-2016, 12:05 AM   #5 (permalink)
Default Instructions with yge
Here is what came with it
Old 01-03-2016, 12:06 AM   #6 (permalink)
Default Here is what came with it
Page 2
Old 01-03-2016, 12:07 AM   #7 (permalink)
This I find a little confusing in setup as I am used to doing everything by computer with the castle ones I have used before.
I am also guessing I will have to do the throttle learning as well?
Old 01-03-2016, 12:10 AM   #8 (permalink)
Default Instructions from prof card
Page 1
Old 01-03-2016, 12:11 AM   #9 (permalink)
Default Instructions from programming card
Page 2
Old 01-03-2016, 12:15 AM   #10 (permalink)
I should also add I am running spectrum radio dx9 as well.
Old 01-03-2016, 12:41 AM   #11 (permalink)
Plan on using the vbar governor
Old 01-05-2016, 12:30 AM   #12 (permalink)
Timing 18
PWM 8-12, start with 10
To set the esc for ext gov do the following, exactly:
heli middle
gov off 3x (press enter 3 times)
plane middle
You will hear a series of tones after plane middle, not a single tone
Startup power I use 2% but some motors don't like it. Use 4% or auto
On the YGE LV esc's the orange wire on the slave lead is where the RPM signal comes from for FBL govs. If you have a MINI VBAR you must remove the orange wire from the connector and put it into a connector housing by itself and plug it into the top pin of the RX A port. If you plug the other two wires into the RX A port, say goodbye to your mini vbar. On a LV the other two wires carry voltage from the bec.
On a HV YGE you need to either buy, or make a special cable.
Heli's I have:
Goblin 500 (Vbar Neo), Gaui X5(Vbar Neo), X7(Vbar Neo), Innova 600 Night heli (Vbar Neo Vbar Vcontrol
I'm the not so newbheliusr as I have been here a while. But I like this name.
newbheliusr is offline        Reply With Quote Quick reply to this message
Old 01-05-2016, 12:51 AM   #13 (permalink)
Thank you sir
Old 01-05-2016, 01:38 AM   #14 (permalink)
What does increasing or decreasing the Pwm settings do? Is it related to power? You will have to forgive my ignorance as I am more of a nitro / gas guy.
Old 01-05-2016, 08:59 PM   #15 (permalink)
I can only tell you the effect, now what it's actually doing. HIgher PWM can give more power, but can also heat the ESC up. I've found too low of a pwm and you lose a lot of power.
Heli's I have:
Old 01-06-2016, 12:45 AM   #16 (permalink)
Thanks again
