Go Back   HeliFreak > R/C Helicopter Support > Synergy Model Helicopters
Synergy Model Helicopters Synergy Model Helicopters Support
Old 10-05-2014, 03:46 PM   #1 (permalink)
Default Gear chatter on an E7SE
I just bought and set up a used E7SE. I equipped it with an Xera 4530-500 motor with a 13 tooth pinion, Castle edge 120 hv, torque 9180 cyclic, torque 9188 tail and AR7200BX gyro. I am running 12S with rail 716 mains and rail 106 tails at about 1950 head speed.
I'm hearing what sounds like gear chatter when using left rudder in a turn or when unloading the disc. If i increase collective or input right rudder, the noise goes away. I have adjusted the governor and tail gains down and up with no change in the noise. I have changed both spur gears and both bevel gears at the front transmission. The rear bevel gears look good.
Has anyone had this problem? Any suggestions where to look? Thank you Leon
MA Graphlte 46, MA 98 SE, MA IonX2, 2 Whiplash EX, Synergy E7SE
boomstrike5 is offline        Reply With Quote Quick reply to this message
Old 10-05-2014, 06:03 PM   #2 (permalink)
Any signs of wear on the gear or rubbing inside the canopy?
Have some video you can share that might help us diagnose?
Jeff_Barrett is offline        Reply With Quote Quick reply to this message
Old 10-06-2014, 08:03 AM   #3 (permalink)
check tail output shaft, and tail rotor hub also.
Gasser Mike
Team KDE Direct, TRM Power, Byron Fuels, MKS Servos
LoveToFly1 is offline        Reply With Quote Quick reply to this message
Old 10-06-2014, 08:05 AM   #4 (permalink)
I had about the same problem last year, the bevel transmission gears were worn out.
halfcab is online now        Reply With Quote Quick reply to this message
Old 10-06-2014, 04:10 PM   #5 (permalink)
how many flights?
Gasser Mike
Old 11-02-2014, 04:01 PM   #6 (permalink)
Sorry it's been a while, just been trying different things and just flying. I tried lowering my gov gain in steps down to 8 with no change in the noise. I replaced the crown gears in the front transmission and rear tail box, still had, what i thought, was to much play between the gears. I bought some shims and shimmed the gears until i got all the play out of the gears and they still ran smooth. I flew the heli today 4 times and the noise was gone, even with the gov gain set at 15 on the Castle esc. I even changed the esc, not because of the noise, but because the esc was running about 190 deg on a flight. I put in an edge 160 with a fan and the temp is down to about 120 deg. Thank you guys for the help.
Leon
Old 11-03-2014, 06:09 AM   #7 (permalink)
Did you take any pics of your gears being shimmed? I'd like to see that.
Grimmy is offline        Reply With Quote Quick reply to this message
Old 11-03-2014, 06:46 PM   #8 (permalink)
I did not take any pictures, sorry. Leon
Old 11-05-2014, 01:32 PM   #9 (permalink)
Howdy leon you can get those 6mm shims from synergy. They go on your tail shaft inside the box between the gear and the frame so the gears engage a little more. This scenario happened on my N7 with probably 300 flights but it's something that can happen out of the box. It will not fail like this but it will make a little noise.
Synergy 4eva
ChapaWolf is offline        Reply With Quote Quick reply to this message
Old 11-05-2014, 06:24 PM   #10 (permalink)
I got my shims from Amain. I did both front and rear gears. The front gear took 5 mm shims and the rear took 6 mm shims. I bought the kyosho shims, they came in three different thicknesses, .1 mm, .2 mm and .3 mm in one package.
Old 11-05-2014, 07:08 PM   #11 (permalink)
Just give that POS to me
And get a new one
:-D
kayakboy69 is offline        Reply With Quote Quick reply to this message
