Go Back   HeliFreak > R/C Helicopter Support > Thunder Tiger 30/50
Thunder Tiger 30/50 Raptor 30, Raptor 50 Helicopters
Old 03-19-2012, 06:35 AM   #1 (permalink)
Default Too the pros, Roll rate, blades?
Hi all,
I’ve used a few different blades and I find some to be much more responsive than others especially in the roll. If I’m looking for a good stable heli that can perform fast 3D with good roll rate, what blades would you recommend, what length and blade width? If I’m running a OS 55 motor would 620mm be better than 600mm?
How much degrees are you getting on left and right ailerons (cyclic) ?
I’m running light weight paddles.
Thanks,
Tristin is offline        Reply With Quote Quick reply to this message
Old 03-19-2012, 11:24 AM   #2 (permalink)
are they the green/blue paddles? the white are not as light.
rcflier1 is offline        Reply With Quote Quick reply to this message
Old 03-19-2012, 02:41 PM   #3 (permalink)
The 600 will be faster than the 620 blades and use the light raptor paddles.
helicopter1 is offline        Reply With Quote Quick reply to this message
Old 03-20-2012, 02:53 AM   #4 (permalink)
I have used both 600 and 620. 600 is way faster. I use Stick Bangers and NHP Agressor600 on both my helis. The NHP are really light but the cord is not as wide as the stick bangers. You will get both locally or through UK or USA sites
Roll rate is quick, but I took off the Raptor black paddles and put on a set of TREX 600 paddles. It made a huge difference. I have a set of Align White paddles on order (mainly because I like to see the white disk while doing some maneuvers).
fultonr is offline        Reply With Quote Quick reply to this message
Old 03-20-2012, 02:54 AM   #5 (permalink)
I should have said that I used the 620 for learning to auto. They are way easier as they have lots more lift.
Old 03-20-2012, 10:59 AM   #6 (permalink)
I currently use 600mm SAB carbon main blades nut I feel my previous CY carbon 600mm where much better, as they where wider by about 6mm, much better roll rate....
Old 03-22-2012, 11:09 AM   #7 (permalink)
i just replaced the head with the titan x50 head and blue paddles. now i,m really rolling........
Old 03-25-2012, 05:26 AM   #8 (permalink)
Hi People, Hope you all having a good restfull sunday,
Can this head fit a raptor 50 Titan, as im looking at converting my current head to metal and want to go FBL.
http://www.rcgroups.com/forums/showthread.php?t=1535107
Thanks.
Old 03-25-2012, 07:10 AM   #9 (permalink)
yep, thats the one............
Old 03-25-2012, 08:49 AM   #10 (permalink)
Are the swashes on the R50 Titan and X50 the same as the X50 swash looks a bit different, hence im concerned that this FBL head wont fit?
Old 03-25-2012, 10:19 AM   #11 (permalink)
Tristin, Most 600 FBL heads have 10mm mounting holes and will fit on any 10mm Main Shaft. The Raptor 30 and 50 have 10mm Main Shafts.
Titan x50 FBL, R50 Titan SE FBL, R50 V2, R30 V2 , Trex500, T-Rex 450x2, mCPx X2,
tr911 is offline        Reply With Quote Quick reply to this message
Old 03-25-2012, 10:20 AM   #12 (permalink)
I the x50 has a cPPM swash and the Raptor 30 and 50 are Mechanical (non-ccpm).
The head you have will work you have to use your swash plate though, and there is a metal alloy swash for the 30/50, I just purchased one.
