Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > X5
X5 Discussion and support of the Gaui X5
Like Tree7Likes
Old 10-18-2011, 10:39 AM   #21 (permalink)
i am using DYMOND ZP-5000 6S (22,2V) 45 C (134 x 47 x 64mm 762g).
i have not fence, so dont know if it fits.
Cheers,
Jaspis
jaspis is offline        Reply With Quote Quick reply to this message
Old 10-18-2011, 05:07 PM   #22 (permalink)
added to the top jaspis
Gaui 200 •Gaui 550 •Gaui X5
BeastX Castle Scorpion Hyperion Spektrum JR
The Front Porch, Nexgens Lounge
nexgen is offline        Reply With Quote Quick reply to this message
Old 10-19-2011, 05:04 PM   #23 (permalink)
You gotta ask permission before posting, sorry
Last edited by fusionsx00; 10-22-2011 at 11:53 PM.. Reason: i hurt geffect feelsings:)
fusionsx00 is offline        Reply With Quote Quick reply to this message
Old 10-22-2011, 06:56 AM   #24 (permalink)
Originally Posted by fusionsx00 View Post
So does anyone run thunderpower?
I'm trading my voltz in, and giving the propower g6's
But not sure what size to get ?
TP4400-6SPP65 4400mAh 6-Cell/6S 22.2V 12C 65C 130C 46 x 47 x 155
TP4400-6SPP65L 4400mAh 6-Cell/6S 22.2V 12C 65C 130C 715 24 x 50 x 310 Long Configuration
TP3850-6SPP65 3850mAh 6-Cell/6S 22.2V 12C 65C 130C 49 x 44 x 136
TP3850-6SPP65L 3850mAh 6-Cell/6S 22.2V 12C 65C 130C 25 x 47 x 272 Long Configuration
I know long is probably not gona work, but my dam droid 2 copy and paste sucks
Please create a new thread if you are making queries about a battery.. This thread is only for adding batteries to the database.
Geffect is offline        Reply With Quote Quick reply to this message
Old 10-22-2011, 09:41 PM   #25 (permalink)
Well delete it then,
Some battery data base, is this only for battery you choose?
Or any that work for the x5????
Old 10-22-2011, 09:58 PM   #26 (permalink)
If you want this thread to just be a battery general discussion got for it.. My intention was to consolidate a list of batteries that are confirmed to fit with the X5, rather than have numerous discussions about which battery might or might not fit..
I not a moderator so i cant delete it, otherwise i would have deleted it..
Old 10-22-2011, 11:51 PM   #27 (permalink)
Here let me,
You know it was just a simple question.
Jesus man, ill remember not to post in your threads
Old 10-23-2011, 12:22 AM   #28 (permalink)
Here let me,
I was just making a simple request to keep the thread easy to read for new owners to find an accurate list of what DOES fit.
Perhaps next time use the search function:
https://www.helifreak.com/showthread...highlight=4400
Old 10-31-2011, 08:51 AM   #29 (permalink)
TP 3800/45C
work just fine with a fence; no interference anywhere
X5 flybar
caveat: if you are running Savox servos (suckers are heavy) you will be tail down CG.
Cheers, Roger
Mikado Logo 10 3D (retired), Blade McPX, Trex 20SE v.1(retired) , Trex 450 SE v.2, Gaui X5 flybar
lasllcap is offline        Reply With Quote Quick reply to this message
Old 10-31-2011, 05:37 PM   #30 (permalink)
Default 4k Nanos 45c do fit with no fence
No modification to canopy or heli. Just mounts really close to the motor. Too far away and Canopy won't fit. It has been the only battery I've used since I got my X5. Confirm it!
X5-12s/Yep120/KDE600-530/FullSizeVbar/belt/550mm
180cfx-ServoSaverMod/TorqueTubeClutch/CarbonBlades, DX7se
My son Enzo - X5, 180cfx, DX7se
ccnada is offline        Reply With Quote Quick reply to this message
Old 11-01-2011, 04:53 PM   #31 (permalink)
I cant edit my original post anymore as its past the time/no. edits before it gets locked.
The mods i.e. nexgen will have to update the list with the new batteries.
Old 11-03-2011, 11:31 PM   #32 (permalink)
im on it
Old 11-21-2011, 04:05 AM   #33 (permalink)
How about “rating” the packs considering value for money/performance/practicality...
This should spark some debate… I’ve done some sniffing through RC forums, and it seems though the Voltz packs are the best choice for the X5. They are light, they fit and does the job pretty well so far. I would like to get some feedback on packs that have been used for > 100 cycles. Manufactures’ claims flat discharge rates, and it might be true, but is the same story after 100 cycles?
Turbonator is offline        Reply With Quote Quick reply to this message
Old 11-22-2011, 03:59 AM   #34 (permalink)
Originally Posted by Geffect View Post
Turnigy 4000mah/20C.....................148 x 49 x 40...............650g (Tight fit)
Actually this battery (and probably 30C / 40C versions also since they are same size) fits very nicely with battery fence when wires are on the top and narrower side of battery is on the battery plate.
I couldn't put canopy on when wires were down and wider side was on the battery plate.
njs77 is offline        Reply With Quote Quick reply to this message
Old 11-25-2011, 06:53 AM   #35 (permalink)
Has anybody flown the X5 with Spyder 6S 4000MAH 30C packs? I just ordered a couple of packs but I've never even seen anybody mention Spyder batteries in this forum.
M1abrams is offline        Reply With Quote Quick reply to this message
Old 11-25-2011, 10:40 AM   #36 (permalink)
I have one of these packs for my X5, good power, never comes down warm. I charge mine at 3C no issues at all.
Synergy Factory Specialist / Rail Blades / Team Scorpion
Chris Sexton is offline        Reply With Quote Quick reply to this message
Old 11-25-2011, 02:53 PM   #37 (permalink)
Cool, thank you!
Old 11-28-2011, 10:26 PM   #38 (permalink)
sounds like we should add the spyder 4000
whippo is offline        Reply With Quote Quick reply to this message
Old 11-29-2011, 02:12 AM   #39 (permalink)
Kypom 4200mah/35C are currently listed in the unconfirmed section, these definitely fit with battery fence.
Im pretty sure these are made in the same factory as Voltz, going by the size and weight.
Old 11-29-2011, 07:20 AM   #40 (permalink)
I guess I should note that I have the battery fence and the Spider 4000mAh pack fits perfectly and CG is spot on.
