Old 01-22-2015, 07:45 PM   #1 (permalink)
Default Stretch guys: 350 vs 360
I'm running 350mm mains right now, with 62mm tails. I was thinking about trying 360s next, but I'm worried about clearance. Anyone running 360s with bigger tails?
Picture isn't looking promising.
Old 01-23-2015, 02:26 PM   #2 (permalink)
I run align 360s no problem. These are by far my favorite blades!!!!
I have tested
SAB
Lynx
Edge
Radix
Diabolo 700 2018 /. Henseleit TDF, TDR 800
TT E700, Align Trex 700L v2, Oxy 5 Meg, Nitroxy, 4 max, Oxy 3.
Kontronik, Spirit, Futaba
Lynx Heli field rep. lynxheli.com
wstuart is offline        Reply With Quote Quick reply to this message
Old 01-23-2015, 03:18 PM   #3 (permalink)
I have tested
SAB
Lynx
Edge
Radix
what size tail blades are you using ?
I am running RJX 360's with Edge 60SE with no problems in over a hundred flights, but it is cutting it pretty close, those extra 2mm may be too much.
"Beater" Mini Prôtos stretch 6S : Scorpion 2520-1360kv, Edge 353SE
"Princess" Goblin 570 stretch 12S : Xnova 4025-560kv, Cyclone 615
FrSky Taranis - Heli-X 5 - MKS, YGE, SK540 - Yamaha XJ6F
Aryemis is offline        Reply With Quote Quick reply to this message
Old 01-23-2015, 04:25 PM   #4 (permalink)
Well if they hit...those two mm will get cleared up pretty quick haha. Im thinking I might be able to buy a little more room by going back to to stock tensioner, and running the minimum number of teeth up front. Then the tail will move back a bit
Old 01-24-2015, 12:23 AM   #5 (permalink)
Yes those are the tail blades I am running. I just looked at it and you guys are right - it is cutting it super close. I have never had an issue with tails and mains clashing though and I've been running this setup for almost a year
Old 01-25-2015, 07:27 AM   #6 (permalink)
I've been using the lynx tensionner for 20 flights or so, still no issues, I need it anyway else the belt tends to slip on the pinion with the torque from the scorpion 2520-1360kv.
I am running the minimum number of teeth up front though, to have the tail moved back as much as possible.
Old 01-25-2015, 10:23 AM   #7 (permalink)
I find the Lynx tensioner a bit "bigger" than the stock one. I used to be around the middle of the adjustment front and back. Now I move the motor about 1mm, and the tail is still around the middle.
Old 01-29-2015, 06:25 AM   #8 (permalink)
was using the rjx 363mm blades with 65mm tail blades with the high rotor head, the blades overlap but there were no issues even on low rpm 2500HS
affiliated with my wallet.
BLHeli with locator beacon now!
honkytown is offline        Reply With Quote Quick reply to this message
Old 01-29-2015, 11:21 AM   #9 (permalink)
I use 61mm kbbd tails and rjx vector 360s on the low head with no issues at any head speed, 2300-3200.
Protos Max Leggero 700, Logo 600SE, Blade 230s
DX9
flint723 is offline        Reply With Quote Quick reply to this message
