Go Back   HeliFreak > R/C Electronics Support > Align 3G FBL System > Align 3GX FBL System
Align 3GX FBL System Align 3GX FBL Flybarless System Software and Hardware Support
Old 09-01-2013, 10:45 PM   #41 (permalink)
Too much verbal diarrhea in this thread...
The flight isn't complete until the blades stop turning...
[Trex 600N, V-Bar] [Trex 450ProV2, 3Gx] [Trex 470LM Microbeast Plus]
squibcakes is offline        Reply With Quote Quick reply to this message
Old 09-02-2013, 06:16 AM   #42 (permalink)
Some people need to get a room! I just want to hear about V4.0 please
Align 700L TOP Spartan Vortex VX1n
Align 550DFC V3 Spartan Vortex VX1n (the dogs nuts!)
Blade 180CFX
Futaba 8FG
JAG1 is offline        Reply With Quote Quick reply to this message
Old 09-02-2013, 07:46 AM   #43 (permalink)
Deleted
Align 450Pro 3GX, 500ESP/DFC 3GX, 500L, 550 DFC MicroBeast , Velocity 50 Vbar OS55 HZ-R, D380 DFC D420, G500 Sport Microbeast, All HW V4,
X5 stretch 220 Flame Emax Bullet Force V2 VTX
bad007 is offline        Reply With Quote Quick reply to this message
Old 09-02-2013, 02:07 PM   #44 (permalink)
Sorry to all, we did wander off a bit! ?, Should have gone PM. But still a master class in Flybarless ?.
Waiting for the wind to drop to try revised setup with the V4.0. Though it looked that promising I've updated my 3GXs.
Trex :- 450SE V2 retired, 250SC retired, 450 PRO fbled Airwolfed, 500 ESP fbled Airwolfed, 250DFC, 450DFC, 500DFC, 800DFC. M690l, MR25P - Futaba/Align. Blade :- 4003D retired,CX2, MQX, 350QX v3 - spektrum. 4503D, 450X - spektrum/Savox.
jimmanyk is offline        Reply With Quote Quick reply to this message
Old 09-02-2013, 02:38 PM   #45 (permalink)
Had the 450 out for some hovers with 4.0. So far it feels more locked in than earlier versions. I'm liking it so far.
T-Rex 700 Dominator vx1e, Goblin 570 vx1e, T-Rex 600N DFC vx1e, Jeti Ds-14
NSFlyer12 is offline        Reply With Quote Quick reply to this message
Old 09-02-2013, 09:13 PM   #46 (permalink)
guys you are way over the top the 3gx is very simple i cant believe what i am reading you are starting to freak me out.
KISS please
Dino
Dino Spadaccini Team Capt Align Factory Team USA / Team Futaba
Dino Spadaccini is offline        Reply With Quote Quick reply to this message
Old 09-02-2013, 09:27 PM   #47 (permalink)
Default 3GX V4.0
Originally Posted by martin_ View Post
Once the set-up of the unit is done, you can do/change anything you want in your TX (pitch curve, throttle curve, DR, expo) the unit will never know. However you must leave end point & swash afr intact.
Correct.... Never change endpoints after you have completed setup... Very bad
Goblin 700 Ikon 560ult cc160hv
Scale Bell 222 T700, Agusta A109 Grand 700
Blue Thunder 700 RCHN #365
G500,E5 12s,600np dfc, t500 dfc beater
Jackass1277 is offline        Reply With Quote Quick reply to this message
Old 09-03-2013, 12:22 AM   #48 (permalink)
Originally Posted by Dino Spadaccini View Post
4.0 is tested and developed by Jamie Robertson
Dang it.
I was hoping it would be the worlds most interesting man.
Maybe 5.0 will be better.
Ultraviolet is offline        Reply With Quote Quick reply to this message
Old 09-03-2013, 04:08 AM   #49 (permalink)
Looks to be officially released.
http://www.align.com.tw/alignhtml/3g...3gx_update.php
Old 09-03-2013, 04:32 AM   #50 (permalink)
I've posted this in the other 3Gx thread (How is 3GX V4.0 performing for you?) but thought I'd post here also as there seems to be more 'traffic'....................
Guys/Gals,
For those of you wanting to change to DSMX (with 2 sats) and may have just skipped through the 3GX 4.0 wizard, just be aware of the slight change to the binding process to select either DSM2/DSMX protocol as follows:-
  • Obviously. select DSMX in your Tx > install bind plug.
  • If wanting to select DSMX -while holding the SET button down (Referred to as Bottom in the wizard) power up the 3gx.
  • Lights on the sats will fast flash- release set button.
  • Remove Bind Plug and continue with Tx bind/failsafe process.
  • You should now have DSMX wording on the top right of your LED screen in your Tx if done correctly(DX8)
I also noted some slight Cyclic 'jumping/twitching' with 4.0 while powered up but I also had some 'twitching' on the throttle engaging the motor every so slightly
No big deal, as it was so slight but un-nerving all the same.
Please feel free to add any info etc or indeed if you have found any other quirks.
Test flight tomorrow, weather dependent.
Bonkievan is offline        Reply With Quote Quick reply to this message
Old 09-03-2013, 07:30 AM   #51 (permalink)
They also mention bluetooth again with a "soon to be released Bluetooth connectivity kit" and smartphone apps. Not holding my breath but would like to see it happen.
ktm520 is offline        Reply With Quote Quick reply to this message
Old 09-03-2013, 10:11 AM   #52 (permalink)
That's been there since the 3GX was released... it's been a little over 2 years now...
TRex 250 DFC | TRex 250 DFC (Scale)
2 @ TRex 450 DFC | TRex 450 Pro 3G (Scale)
TRex 550 DFC
DX8 + Telemetery on all
JoeW is offline        Reply With Quote Quick reply to this message
Old 09-08-2013, 12:37 PM   #53 (permalink)
Arrow V4.0 nice try - but I don´t like it
Hi,
in the Moment 3GX Firmware V4.0 is that bad I´ll Change it tomorrow back from V4.0 to V3.1. I´ve tail wag with 2,400 rounds per Minute and a very instable tail after rudder movements. Furthermore on the ground the tail slider moves back into middle direction after a left or right rudder move and moving back of rudder stick in neutral position. This is a typical behavior in normal gyro mode but not in Heading hold. Probably I´ve other Problems with my T-Rex but the behavior of tail slider in V3.1 was more than expected in Heading hold than in new release 4.0
Ronny
PKZTyphoon²3D|GRAUPNER MX16HoTT+Spek|nCPx BL|ALIGN Rex450Pro DFC3GX V3.1|THUNDER TIGER E700 Raptor JLog2.6
ElektroTrainerS is offline        Reply With Quote Quick reply to this message
Old 09-08-2013, 12:56 PM   #54 (permalink)
Default 3GX ver 4.0 dsmx satellite support
I read on the align site that ver 4.0 has dsmx satellite support. Has anyone updated and rebind to see if it defaults to dsmx instead of dsm-2? It would make it more secure.
Blade 450 3D (X2), Align T-rex 450L Dominator 3gx, Blade 500X 3gx, Align T-rex 550E V2 3gx, Align T-rex 600 pro DFC 3gx, Align T-rex 700E DFC 3gx, Phoenix sim, DX6i, DX8
mknj is offline        Reply With Quote Quick reply to this message
Old 09-08-2013, 01:14 PM   #55 (permalink)
Yes 3GX is now dsmx compatible but you do need to follow the new procedure listed above when binding.
I test flew V4 today for the first time on my 450 Pro and personally I loved it. Very stable, very responsive, better overall feel, especially when making hard collective changes.
I didn't notice any issues with tail wag, tilting or power draw using same settings I used on V3.1 apart from slightly different gain settings in the software.
It gets a big thumbs up from me anyway.
Blade 130 X, TRex 150DFC,
TRex 450Pro V2 3GX,
T-Rex 500L Dominator (GPro)
DX8
Dogcow is offline        Reply With Quote Quick reply to this message
Old 09-08-2013, 02:43 PM   #56 (permalink)
Question
Hi Dogcow,
because You like V4.0 would you check please the behavior I´ve described above? In Heading Hold and on the ground my tail slider moves always back from left/ right Limit to the middle Position and I think that´s not normal. Better said that´s the expected behavior in normal mode
Ronny
Old 09-08-2013, 03:34 PM   #57 (permalink)
Default 3GX V4.0
Originally Posted by ElektroTrainerS View Post
Hi Dogcow,
I'm not really sure what your problem/issue is, but my tail has never been better or more stable than in V4. If you are asking about mechanically on the bench then it behaves the same as when it was on V3.1, it shouldn't do anything noticeably different on the bench from V3 or V4 unless I'm missing something?
My guess is that your issue with the tail is not related to 3GX V4 but possibly something in the mechanical setup that maybe V3 managed to hide and is more noticeable in V4? The rudder gain settings have been altered and redone by Align in V4, for me it works but not for everyone, some have needed to tweak their gain settings to get the tail to behave, all I did was use similar settings to the ones I used in V3.1 and that seemed to work.
Sent using Tapatalk
TRex 450Pro V2 3GX,
DX8
Old 09-08-2013, 04:17 PM   #58 (permalink)
Hi Dogcow,
On the bench, motor disconnected. Experiment with normal and iu FMs and see if the slider moves with the pitch. I had the same thing happen after an update, the slider would go to one side and as I moved the throttle it traveled with it and then went back to center position. Had to start from scratch with a reload of the firmware, rebind and go threw setup again.
Old 09-09-2013, 02:55 AM   #59 (permalink)
I've had a servo twitching issue since V3.0, rolling back to 2.1 or unplugging the second dsmx satellite always fixed the problem. I tried V4.0 and i get the same twitch. Then i tried something a little different, i unplugged the 3gx from the computer and guess what... twitching gone !!! Plug the computer back in and the twitch comes back. At least now i can confidently use the new firmware.
Prinsen is offline        Reply With Quote Quick reply to this message
Old 09-09-2013, 11:15 AM   #60 (permalink)
Post
Hi,
thank You both for Your helpful answers. I´ve deinstalled the 3GX V4.0 Software via Windows 8.1 System control. After restart of my Computer I´ve downloaded the 3GX V3.1 Software and installed it. Than I´ve switched my Receiver on, connected my Rex via 3GX-USB Interface with my Computer, powered on the Rex, started 3GX V3.1 Software and voilà... the tail slider has moved in heading hold mode as expected (without any tail servo twitching). Thought by myself: do it the same way with V4.0. So I´ve deinstalled 3GX V3.1 Software via System control, restarted the Computer, downloaded V4.0 again from ALIGN Homepage etc. and... the tail slider moves as expected in Heading hold without moving back into middle Position after turning the rudder stick back to neutral Position. I´ll do my check flights within the next days, but I´m afraid, that Í´m happy now with V4.0
Ronny
