JR and Spektrum Radios and Electronics JR and Spektrum Radios, Gyros, Servos, Etc. |
10-16-2009, 12:53 AM | #1 (permalink) |
AR6200 ( remote rx Flashes)
So I know that if both the Rx, ( main and the Remote flash)
There is a power failure and system rebooted and reconnected. BUT what does it mean when only the Remote Rx on the AR6200 Flashes ? I've seen this now on two AR6200.. one on a plane.. where Rx are Isolated from any wires ect.. and one on a Heli .. Any one know.. ?? Thanks.. |
10-19-2009, 02:45 PM | #2 (permalink) |
Typically this would be an issue with the connector cable to the remote. Another possibility is a spark hitting the remote antenna, which can happen on some setups of belt driven heli tails.
T-Rex 700N, 600NP, 450v2 w/Pro head, 250SE - Blade mCP-X, mCX, mSR x 2, Parkzone F4U Corsair: All on DX7se |
10-20-2009, 02:51 PM | #3 (permalink) |
Thanks..
Sonic,
Thanks for your reply, I don't have to much room on the air frame, But found a spot let see if that helps. I did have the Remote Rx - mounted on the outside of the fail boom, on the frame. Got is as far as possible now way from the boom .. Let see if that helps.. Thanks again.. |
10-20-2009, 08:14 PM | #4 (permalink) |
It could be that the voltage dropped enough for the sat to reboot, but not the main.
Since they are different pieces of equipment, they can have different low voltage cutoffs. When I tested mine, some pairs had as much as a 0.1 volt cutoff difference.
Terry AMA#47402, IRCHA # 3395 Blade CP "Pro", Trex 450SE, PiccoZ, Quick of Japan EP8v2 EX, Hurricane 550, Hurricane 200, JR Vibe 50, Blade mCX, Bergen Intrepid Gasser, Pantera 50, Blade mSR, Novus CP |
10-21-2009, 10:32 AM | #5 (permalink) |
Have you simulated it on the bench?
Make sure they both flash, you might just have mismatched firmware. |
10-24-2009, 08:47 PM | #6 (permalink) | |
I feel this is a current issue, everything is fine until the voltage on the Receiver pack drops slightly. I have an upgraded BEC on it's way to replace the stock and I'll let you know the outcome.
T-Rex 600e – 12's – Full KDE upgrade – elogger – Spider gear – Align 610 cyclic's, 650/401 tail – CY 600 main 95 tail – CC HV85 – Scorpion 4025-630/6mm shaft - boca bearings - 700 main gear T-Rex 450SE – 430x – Align BL35X ESC – 401/S9650 tail – Hitec HS-65HB – Custom canopy – elogger – AR6200 – 3S1P 2250mAh 30C Trainer AMA Member - 937052 |
10-27-2009, 06:02 PM | #7 (permalink) |
I did replace the stock BEC (keeping the stock rx battery) and my problem went away. I'm using the CC BEC Pro; set at 5.8v (using the castle link). I hope to stick with this BEC (if it pans out) when I go 12's.
-bobkat
T-Rex 600e – 12's – Full KDE upgrade – elogger – Spider gear – Align 610 cyclic's, 650/401 tail – CY 600 main 95 tail – CC HV85 – Scorpion 4025-630/6mm shaft - boca bearings - 700 main gear T-Rex 450SE – 430x – Align BL35X ESC – 401/S9650 tail – Hitec HS-65HB – Custom canopy – elogger – AR6200 – 3S1P 2250mAh 30C Trainer AMA Member - 937052 Last edited by bobkat; 10-28-2009 at 05:50 AM.. |
