Go Back   HeliFreak > R/C Helicopter Support > SAB Goblin 630/700/770
SAB Goblin 630/700/770 SAB Heli Division 630/700/770 - Goblin Helicopters Factory Support
Old 10-21-2011, 10:15 PM   #21 (permalink)
looks pretty amazing! It looks like it has a low amount of parts from the pics.
Goblin Urukay Competition
Align T-Rex 700 Nitro FBL
DJI Mavic 2 Pro
ntwaddell is offline        Reply With Quote Quick reply to this message
Old 10-21-2011, 10:28 PM   #22 (permalink)
How have you managed to get away with bearings on your pitch rods?
Compass 3D+ - OS55 Hyper/Hatori/Vbar
Atom 500
Tarot 450 Pro - AR7200BX
Spektrum DX8
Inverse is offline        Reply With Quote Quick reply to this message
Old 10-21-2011, 10:49 PM   #23 (permalink)
Hi,
The first stage of the transmission Goblin is a belt. This has the great advantage that there are not temperature problems. The belt used by us are OK up to 130 °.
The belt combined with the rigidity of the motor support of the Goblin does not necessitate the 3 rd bearing on shaft motor.
The shaft of the motor must be at least 26 mm.
In the pictures there are many parts prototype, and many parts not anodized.
The standard production will be high quality.
Goblin Helicopters.
goblinhelicopter is offline        Reply With Quote Quick reply to this message
Old 10-22-2011, 10:23 AM   #24 (permalink)
Goblin Helicopter You have posted you are using gigapower 38c 5200 packs at 795 grams have you flown lighter batteries in any of the SAB vidieos.And what is the RTF weight with Packs.
Magneto is offline        Reply With Quote Quick reply to this message
Old 10-22-2011, 10:25 PM   #25 (permalink)
The Goblin weighs with motor HK 4525-520 and Kontronik Jive 120HV, 3290 grams ready to fly.
The video of Tareq, in Alpine, we used 12S4500 60C, weight 760 +760 grams
Old 10-23-2011, 01:11 AM   #26 (permalink)
Just over 7 pounds???
Really?
The other 700 sizes I've been looking at are around 12 pounds(5443grams)
fusionsx00 is offline        Reply With Quote Quick reply to this message
Old 10-23-2011, 01:13 AM   #27 (permalink)
Default Thats
With out batts
TDR, Srimok N x 2, Banshee 31, Dune!
jhunter is offline        Reply With Quote Quick reply to this message
Old 10-23-2011, 01:24 AM   #28 (permalink)
3290 grams is ready to fly without battery.
Old 10-23-2011, 01:22 PM   #29 (permalink)
Just preordered from helidirect and trying to plan components.
1. What options are available for motor mounting?
a. 30mm X 4mm is assumed as this is 4525 mounting
b. 25mm X 3mm available?
2. Gear Ratios.
a. Stock Gear Ratio ?
b. What is the method for changing? (Pinion/Gears?)
c. What options included in kit?
d. I would be shooting for 2000 RPM on 500 Kv so would prob need lower than stock gearing, most likely on VBar gov.
3. Servos
a. I understand 8717's are what is tested. Do these provide for links that are parallel to the main shaft. Different servos have different geometry. Wondering which brand, JR or Futaba provide the best Geometry?
Thank You. We really appreciate you creating a thread for questions. Very smart customer service.
Synergy N5C sitting in Box...
Mystic3D is offline        Reply With Quote Quick reply to this message
Old 10-23-2011, 10:57 PM   #30 (permalink)
Hi,
30x4 and 25x4 are available in standard support. it is easy to make changes if necessary. Attack picture.
Stock ratio is 10.7. (20 tooth pinion)
To change the ratio only just change the pinion.
In the kit there is a pinion of 20 teeth.
For max 2000 rpm, 500 kv, is ok pinion 20 tooth, is perfect pionion 19 teeth
With size 20 mm servos there are no geometry problems.
Goblin helicopters.
Old 10-24-2011, 02:58 AM   #31 (permalink)
Just curious.
Atom 500
Spektrum DX8
Old 10-24-2011, 03:14 AM   #32 (permalink)
Really?
ok so 4810 grams?
thats still 633 grams less
i might have to get one
Old 10-24-2011, 12:26 PM   #33 (permalink)
What are the teeth counts...
1st stage belt: pinion and driven pulley
2nd stage gears: pinion and driven gear
Tail belt: drive pulley and driven pulley.
Thanks,
Ben
Mr. Ben is offline        Reply With Quote Quick reply to this message
Old 10-24-2011, 10:45 PM   #34 (permalink)
Originally Posted by goblinhelicopter View Post
Hi,
Goblin Helicopters.
Awesome.
How are you able to run bearings on your main grips and a solid shaft to your swash?
Doesn't the movement in the head and the fact you are using solid pushrods cause bad loadings in the grips and bearings?
Atom 500
Spektrum DX8
Old 10-28-2011, 09:35 AM   #35 (permalink)
When can we expect the exploded diagram
McCollister911 is offline        Reply With Quote Quick reply to this message
Old 10-28-2011, 12:32 PM   #36 (permalink)
Hi goblinhelicopter
Is it right that there also will be a 600 model available. Would be a nice match to my Logo.
Mikado Logo500 3D FBL
Low RPM long flying
edwinkoolen is offline        Reply With Quote Quick reply to this message
Old 10-28-2011, 04:06 PM   #37 (permalink)
Awesome.
Here's what happens during the rocking of the head (pic attached)...whether or not it's a good thing to have the ball position change back and forth, that I don't know. I'm sure the dampeners are extremely stiff on the goblin, so this drawing is a bit exaggerated to say the least.
Stuff
Rob Cherry is offline        Reply With Quote Quick reply to this message
Old 10-28-2011, 08:02 PM   #38 (permalink)
Nice drawing. The other axis might be problematic as it would be twisting whiile forcing the arm outward as an angle.
Old 10-29-2011, 02:30 AM   #39 (permalink)
I would like to know if the tail outputshaft is 6mm...
Regards from Denmark
.....happy flying....
Regards Janis
Vom Feinsten is offline        Reply With Quote Quick reply to this message
Old 10-29-2011, 05:22 AM   #40 (permalink)
Goblin 600 will be available in March 2012.
Output shaft is 6mm
Exploded diagram will be available in 2 weeks.
Goblin Helicopters
