Go Back   HeliFreak > R/C Helicopter Support > SAB Goblin 630/700/770
SAB Goblin 630/700/770 SAB Heli Division 630/700/770 - Goblin Helicopters Factory Support
Old 10-29-2011, 08:19 AM   #41 (permalink)
Mr goblin can i know whats the difference between the 660 , 700 and 770 goblin? I know the frame is still the same only difference is the boom length, blades and belt am i right to say that? Just to confirm thanks
dreamer82 is offline        Reply With Quote Quick reply to this message
Old 10-29-2011, 08:20 AM   #42 (permalink)
Also can you attach a picture of the confirm colour of the canopy that comes with the kit too as i have seen many different colours
Old 10-29-2011, 10:59 AM   #43 (permalink)
Originally Posted by Mr. Ben View Post
What are the teeth counts...
1st stage belt: pinion and driven pulley
2nd stage gears: pinion and driven gear
Tail belt: drive pulley and driven pulley.
Thanks,
Ben
Hi,
1st stage belt = 15 to 28 / 60
2st stage gear = 19/68
3st tail belt = 36/27
Goblin helicopters
goblinhelicopter is offline        Reply With Quote Quick reply to this message
Old 10-29-2011, 11:06 AM   #44 (permalink)
for now, Goblin 630 is different in:
boom
tail belts
tail pulley
damper
for now, Goblin 770 is different in:
boom
tail belts
tail pulley
main shaft
damper
The Goblin 700 production will be very similar to the picture attached.
Goblin helicopters.
Old 10-29-2011, 11:09 AM   #45 (permalink)
wow A1 respond thanks mr goblin
Old 10-29-2011, 11:19 AM   #46 (permalink)
Have any of u guys considering Kontronik PYRO 700-52L to power the goblin or scorpion hk4525?
Old 10-29-2011, 03:52 PM   #47 (permalink)
What are you using to level the swashplate in the V Bar setup menue?
Justin
Justin Harris It is better to measure 10 times and cut once, than to cut 10 times and measure once.
Sponsored by :
KONTRONIK, OPTIPOWER, PRC, CANOMOD
jhheli is offline        Reply With Quote Quick reply to this message
Old 10-29-2011, 07:20 PM   #48 (permalink)
Originally Posted by Inverse View Post
Awesome.
How are you able to run bearings on your main grips and a solid shaft to your swash?
Doesn't the movement in the head and the fact you are using solid pushrods cause bad loadings in the grips and bearings?
I'd like to know this too..
Also, this has probably been mentioned before but what's the main shaft size?
-Goblin 700: Crashed but re-building, still needing electronics
-Goblin 630: CC Ice 120HV, vBar
scoti333 is offline        Reply With Quote Quick reply to this message
Old 10-29-2011, 07:49 PM   #49 (permalink)
Default Mainshaft is 12mm
http://www.goblin-helicopter.com/index.php
Just scroll down the page. It's in Italian, but measures, weight and gear ratios are pretty logical to work out.
minicopter Diabolo, Henseleit TDR, X50e, X50n, Raptor 50
Futaba 2.4 GHz
DT75 is offline        Reply With Quote Quick reply to this message
Old 10-29-2011, 09:30 PM   #50 (permalink)
Justin
Sorry, I do not understand what information you ask. Could you repeat the question?
Old 10-29-2011, 09:36 PM   #51 (permalink)
This page is an old page.
In a few days will be on line the new website.
The shaft is 12 mm. Steel hardened and tempered.
Goblin Helicopters
Old 10-29-2011, 10:13 PM   #52 (permalink)
Which one do you use?
http://www.readyheli.com/LEVELER4-Lo...g_p_34924.html
http://www.readyheli.com/LEVELER5-T-...g_p_34925.html
Sponsored by :
Old 10-29-2011, 11:01 PM   #53 (permalink)
ok
We used a "Swashplate Leveler" done by us. No need to remove hub.
Probably will uprade in 2012.
The shaft is 12 mm.
This is ok.
Goblin Helicopters
Old 10-30-2011, 03:03 AM   #54 (permalink)
Originally Posted by csdstudio View Post
Here's what happens during the rocking of the head (pic attached)...whether or not it's a good thing to have the ball position change back and forth, that I don't know. I'm sure the dampeners are extremely stiff on the goblin, so this drawing is a bit exaggerated to say the least.
Hi,
I took your picture.
I edited the picture to see what happens.
The movement of the spindle in the Goblin is very low.
The drawing emphasizes.... The swashplate remains oriented correctly, because the two linkage go in the opposite direction. The two linkage are not infinitely rigid and then deform.
In practice, their rigidity is added to the rigidity of the damper.
The system was developed with many tests. We worked on the damper, on their preload, on the distances. The result is very good for us.
Goblin Helicopters
Old 10-30-2011, 04:53 AM   #55 (permalink)
Originally Posted by goblinhelicopter View Post
Hi,
The swashplate remains oriented correctly, because the two linkage go in the opposite direction. In fact, one goes forward, the other back. The two linkage are not infinitely rigid and then deform..
I think you mean the swashplate remains oriented correctly, because the two linkages go in the same direction. If they where going in the opposite direction we would have rotation in the swashplate instead of a slight deformation on the linkages. Your picture shows that correctly.
<<JR VIBE 50--LOGO 400--COMPASS 6HV>>
aris2024 is offline        Reply With Quote Quick reply to this message
Old 10-30-2011, 05:25 AM   #56 (permalink)
Yes, I meant that in the same direction.
thanks Aris
Goblin Helicopters
Old 10-30-2011, 06:20 AM   #57 (permalink)
Hi,
Yes, this is what I was suspecting, the original image was wrong and it wouldn't happen that way.
You saying your pushrods flex slightly?
Just interested in the mechanics behind it
Compass 3D+ - OS55 Hyper/Hatori/Vbar
Atom 500
Tarot 450 Pro - AR7200BX
Spektrum DX8
Inverse is offline        Reply With Quote Quick reply to this message
Old 10-30-2011, 12:34 PM   #58 (permalink)
Just wanted to say that it is very cool that you guys (SAB) started this technical thread and are staying on top of it to boot! I have one last question. Did you guys have any problems with the servos flexing vertically since they are mounted horizontally?
Old 10-30-2011, 11:35 PM   #59 (permalink)
Hi,
The servos are mounted with rubber but very tight.
In this way the servos very little flex.
Never any problems.
Goblin Helicopters
Old 10-31-2011, 03:53 AM   #60 (permalink)
Unless I missed it...
With the batches that HD is getting "WHAT" is the first run of Goblins color scheme going to be?????
