Go Back   HeliFreak > R/C Helicopter Support > Henseleit
Henseleit Henseleit Helicopters
Old 06-11-2012, 01:44 PM   #1
donskills
Default 3rd TT bearing and Vibes!
has anyone installed a third TT bearing to get rid of vibrations? and if so, what frequecies were your vibes at?
Henseleit TDR 2011,GT-5. BLS451/251, Pyro 700-52, Jive80HV, Radix 710FBL, Radix 110 tails.
Phoenix R/C, Futaba T14MZ
donskills is offline        Reply With Quote
Old 06-11-2012, 05:23 PM   #2
Vinger
Just build it strictly according to the manual and you will have no problem with vibes. Some TT tubes are about 1mm too long and this causes it to bow once fitted, so check that rather that adding anything.
TRex 250 BeastX, Trex 500-Vbar 5, Henseleit TDR, Banshee -VBar 5 All Kontronik ESC
Hyperion 1420, Mega Power Gemini Chargers! JR XG11
Old hand at Planks
Vinger is offline        Reply With Quote
Old 06-11-2012, 06:31 PM   #3
donskills
159 flights on it!
Old 06-12-2012, 04:58 PM   #4
richardmills
my kit came with a 3rd tt bearing (nov 2011) with instructions to fit it.
richardmills is online now        Reply With Quote
Old 06-13-2012, 11:48 AM   #5
mkovalcson
Mine came in March 2012 and had a page inserted in the ziplock bag.
Henseleit TDR, Synergy E5, MSH PROTOS 500, 300X
Jeti DS-16, Skookum, Kontroniks
mkovalcson is online now        Reply With Quote
Old 06-13-2012, 03:01 PM   #6
Vinger
Third bearing block, new style head etc was in the 2010 update and later. According to the info I have on the third bearing block, in my second kit, it was added due to changes on how they mount and material changes to the torque drive tube itself.
Never had a single problem with the TT on the TDR, so follow the instructions and it just works, vibe free..
Old hand at Planks
Old 06-14-2012, 01:13 AM   #7
swalko
Are you sure? Rocker head is from model 2010 but third bearing is update for year 2012.
swalko is offline        Reply With Quote
Old 06-14-2012, 03:35 AM   #8
Vinger
I stand corrected!
Old hand at Planks
Old 06-14-2012, 06:39 PM   #9
donskills
Correct! Got my kit on November 4th 2011 without the third bearing and holder. Still I will fly her as is as I am quite sure my vibs come from my flying!! Thanks again for all input guys!!
