RealFlight Flight Sim All versions of RealFlight Sim |
10-07-2016, 01:36 PM | #1 (permalink) |
Problem with Rf7.5
Been having these intermittent glitches while simming , I've tried to calibrating my controller again with no resolution of the issue. I'll be flying when all of the sudden I lose all control of the Heli I'm flying. The Heli will start doing the chicken dance. I tried cleaning the contacts of the Tx interlink cable but that didn't help. Been thinking my wired Tx interlink is taking a dump. No one sells just the interlink alone , let me know what you guys think.
10-07-2016, 01:41 PM | #2 (permalink) |
It's a common thing. I had to redo the USB cable to mine like many others. Your only other option is to send it in for repair. A temporary fix it using ty-wraps to affix the cable to the handle where it works.
10-07-2016, 05:02 PM | #3 (permalink) |
How do I repair it? I have the cable that lets you use your own Tx .
10-07-2016, 05:08 PM | #4 (permalink) |
You have to take it apart (remove the four screws on the back) and resolder/repair the intermittent USB wire depending on where it is in the cable. The other option is replacing the cable with a new one. Any USB cable will do.
Hooking up a transmitter to the back won't do any good if the USB cable from the Interlink is going bad. A standard USB cable has four wires. Two for data and two for power. Sometimes a charging only cable doesn't use the data lines for a device. |
10-07-2016, 06:43 PM | #5 (permalink) |
Thanks for your help , I'll take it apart when I get home.
10-11-2016, 01:49 AM | #6 (permalink) |
So I resoldered the two wires that go to the transmitter , got some nice shiny ,solid looking solders now . One of The wires seemed loose before, it seems to work better but I'll get some random glitching sporadically. Dunno might have to resolder the other 5 or so wires on the USB end.
