Old 10-15-2011, 09:34 AM   #1 (permalink)
Default Quick Uk Tail Or Original T-Rex 700E Tail With KDE Tail Upgrade V2?
I noticed i cant use the KDE Tail Upgrade V2 with the Quick Uk Tail, now i already have the KDE Performance Tail Control V2 assembly and id like to know if I'm better off using the original T-Rex 700E tail with the KDE Tail Upgrade V2 or is it better to use the Quick Uk Tail? Thanks
T-Rex 700E: Pyro 700-52 - Kontronik Jive 120+ HV - Cyclic JR 8717 - Tail BLS-251 - Fullsize V-Bar5.0 - Scott Gray Reactor X2 - Edge 693mm FLB Main Blades - Edge 115mm Tail Rotor Blades
Shape 9.0 Rigid: X-Era 4030-3Y 470kV-Jive 120+ HV
HackAttack is offline        Reply With Quote Quick reply to this message
Old 10-15-2011, 10:51 AM   #2 (permalink)
I guess that's up to you since the both accomplish the same thing. I just use the Quik UK tail on mine.
Sent from my Samsung Galaxy S II using TapaTalk
That wasn't a crash....It was an acrobatic landing!
AMA# 927891
Trex 550E 12s Stretch BeastX, Trex 700E BeastX
GlobalHawk is offline        Reply With Quote Quick reply to this message
Old 10-15-2011, 10:56 AM   #3 (permalink)
Ok, thanks, i guess one doesn't work better than the other
Old 10-15-2011, 11:46 AM   #4 (permalink)
TT
You might be better off using the Align V2 tail with the 0.1mm shim. The QUKs are nice...I used them on 3 700LEs and 1 700E. Right now I'm using Align plastic grips with the KDE upgrade. When they get sloppy I'm going to try the Align V2.
TT is offline        Reply With Quote Quick reply to this message
Old 10-15-2011, 12:53 PM   #5 (permalink)
+1 support V2 tail with extra shim
T-Rex 700E (700MX (BOCA #7) / DS610 & DS650 / 3GX / CC ICE 2 HV 120 / Radix 690 SB / Rotortech 105 / Nano-Tech 4500mAh 25-50C)
dvillijs is offline        Reply With Quote Quick reply to this message
Old 10-15-2011, 01:33 PM   #6 (permalink)
+1 on the V2 align tail grips.
AnythingHeli.com OWNER/ TEAM PILOT
GAUI X5 / X7 *
GOBLIN G380/R420/G500-x2/R580/G650/R700/G770 (and many others)* Swinging Rotortech Blades * OMP M1 & M2 * MSH Brain * * iX12*
akamullen is offline        Reply With Quote Quick reply to this message
Old 10-15-2011, 01:41 PM   #7 (permalink)
+1 Align V2
No need for plastic spacers like quick UK.
Hub is more robust.
Synergy N5C sitting in Box...
Mystic3D is offline        Reply With Quote Quick reply to this message
Old 10-15-2011, 05:37 PM   #8 (permalink)
what you mean as shim? can someone post a pic of the shim and where it goes? i was thinking of putting this on my 700
Trex 700E DFC V-Bar , Trex 600N , Logo 600 SE FBL V-bar, Logo 600/550 FBL V-bar,Logo 400 FBL V-Bar ,Goblin 500 V-Bar, Blade 130X , Blade MCPx , Blade 500X
celm is offline        Reply With Quote Quick reply to this message
Old 10-15-2011, 05:58 PM   #9 (permalink)
It would benefit you to read this:
https://www.helifreak.com/showthread.php?t=332838
stockman is offline        Reply With Quote Quick reply to this message
Old 10-16-2011, 10:39 AM   #10 (permalink)
PM me if you want a pair of the shims...
AMA 373608
K2Freak is offline        Reply With Quote Quick reply to this message
Old 10-17-2011, 02:56 AM   #11 (permalink)
What is the problem with using the KDE Performance Tail Control V2 together with the Quick UK tail rotor? I'm successfully using this combination and the only problem that had to be solved was the one described in this thread where the solution is also presented: https://www.helifreak.com/showthread.php?t=276966
T-Rex 700 E/FBL, 4525-520, CC ICE 120HV
jockew is offline        Reply With Quote Quick reply to this message
Old 10-17-2011, 09:10 PM   #12 (permalink)
What is the extra shim, and where does it go. Are we finding the V2 tail has problems?
Specter 700, Logo 700, Logo 690SX, Goblin 700, Trex 700DFC, Gaui X7, Trex600EFL Pro, Trex 600 ESP, Trex 500 ESP, DJI 550
Amain Hobbies Team Rep
rcflyerheli is offline        Reply With Quote Quick reply to this message
Old 10-18-2011, 12:32 AM   #13 (permalink)
This thread has all the discussions and at page 12 is where the most up to date answer is
https://www.helifreak.com/showthread...332838&page=12
u can read thread for background and kegerator made a nice drawing next page
Old 10-18-2011, 02:37 AM   #14 (permalink)
I did purchase the KDE tail control arms upgrade. But ill have to go back to the stock parts. When mounting , the one arm is to tight.
And also noticed that there is play at blade grips, bearing play. Anyone with same experience ?
Newer used, still building.
SA1000E . MiniVolt-500.CncEfects: K7-1000E K6-800E. K700E.K550-600
Align:2x Trex 450 Dominator 6s. 2x Trex 550E 4× BeastX- 3× Vbar- 3× Spartan VX1n- 1× Sk720
runesb is offline        Reply With Quote Quick reply to this message
