Old 09-13-2015, 07:02 PM   #1 (permalink)
Default Gpro won't connect to PC
Guys I'm trying to connect my Gpro to the pc through the USB connection but it won't connect!
Even the status led is not working as if the device is dead
Does anyone have a clue?
mswify is offline        Reply With Quote Quick reply to this message
Old 09-13-2015, 08:44 PM   #2 (permalink)
Do you have a battery plugged into the Gpro? It won't power up just by plugging in the USB cable. Also, I know it sounds stupid but make sure you have the cord plugged all the way into the Gpro. It can be tough to get it all the way in sometimes, but when you do it will look like this.
Gaui X3- Xnova, Hobbywing PP50AV3, Savox/MKS, MSH Brain
jmheath357 is offline        Reply With Quote Quick reply to this message
Old 09-14-2015, 11:56 AM   #3 (permalink)
Yes I'm connecting a 2cell battery and I pushed the cable all the way in but still nothing happens!!
What about the status led?? I think it should give any indicator when the battery is connected
Old 09-14-2015, 12:44 PM   #4 (permalink)
No, the light won't come on with just a battery plugged into it. Have you tried binding your satellite or whatever kind of receiver your using?
Old 09-14-2015, 01:55 PM   #5 (permalink)
Yes, I plugged 2 DSMX sat
Old 09-14-2015, 02:26 PM   #6 (permalink)
So when you plug the battery into the gpro and then plug the gpro into your computer, does your computer make a noise signifying you've connected something to it through the usb port? I just confirmed on mine that all you need is the battery plugged into it and then plug it into the computer and open the gpro software and then a few seconds after that it should say connected. But if you plug it into your computer and it doesn't recognize that you've plugged something in, it could be a bad usb cable. Believe it or not that was the exact issue I had when recently installing an MSH Brain on mine. Couldn't get it to connect on three different computers and it turned out to be the cable.
Old 09-14-2015, 02:28 PM   #7 (permalink)
Also, here's a link to a setup video from Align. It's good information except setting the neutral position for the rudder is wrong.
Align GPro Binding and Setup by Jeff Fassbinder (56 min 33 sec)
Old 09-14-2015, 02:48 PM   #8 (permalink)
In my thread GPRO info only I posted were myself and others had this problem. In my case I didn't have the plug all the way in the GPRO unit. It seemed like it was but it wasn't. The black insulation on the cable will be touching the unit when fully plugged in. Check that and see if that is the problem.
Wind Spirit is offline        Reply With Quote Quick reply to this message
Old 09-14-2015, 02:52 PM   #9 (permalink)
Sorry didn't see your post till after I posted.
Old 09-14-2015, 04:17 PM   #10 (permalink)
No problem. Good to have others join in to try and help.
Old 09-14-2015, 07:04 PM   #11 (permalink)
When I connect the battery and the USB cable my computer makes a beep recognizing that something is connected to the USB but the Gpro software shows that the device is disconnected
Old 09-14-2015, 07:06 PM   #12 (permalink)
Could it be a USB driver problem?
I'm using XP windows, does anyone knows where I could get the latest drivers?
Old 09-14-2015, 07:14 PM   #13 (permalink)
Wow, XP is pretty old now. That might be an issue. I would recommend going to aligns website and getting the latest software. Might have to contact them about the issue if you can't get it figured out. Have you tried connecting it to a more up to date system?
Old 09-14-2015, 09:15 PM   #14 (permalink)
not yet but will sure try another PC
Old 09-15-2015, 05:18 AM   #15 (permalink)
what voltage reading can you get on the battery if you have a way to test it?
Old 09-15-2015, 11:28 AM   #16 (permalink)
7.57v
Old 09-15-2015, 03:46 PM   #17 (permalink)
I tried connecting to another PC (windows 7) successfully, I think it was XP problem
Old 09-15-2015, 08:37 PM   #18 (permalink)
Awesome! Ya, when you said XP I was a little concerned seeing as that was out way before Gpro or most other FBL systems.
