Old 05-11-2013, 05:09 PM   #1 (permalink)
Default dual arm slider
any one have this unit ,if so do you know where to get the tail shaft ? as it is longer than the standard 450 shaft, i have not been able to locate it yet .
dogtooth is offline        Reply With Quote Quick reply to this message
Old 05-11-2013, 05:21 PM   #2 (permalink)
If you can take it apart and post the pic with measurements.
Looks solid
I found thus place, try to get in touch with them
http://www.alzrc-hobby.com/index.php...ort=20a&page=3
salrica is offline        Reply With Quote Quick reply to this message
Old 05-11-2013, 08:05 PM   #3 (permalink)
its 47 mm . the end of it thats in the box ,from the gear to the end is 8 mm . 5 mm longer than the original , im having trouble posting photos so you have to use your imagination , ha-ha
Old 05-11-2013, 10:30 PM   #4 (permalink)
Out of interest; what is this tail assembly from? It looks really nice.
Still Crashing, Still Learning
6HV-U, Logo550 & Protos all vbar
Bee_random is offline        Reply With Quote Quick reply to this message
Old 05-11-2013, 11:41 PM   #5 (permalink)
Chinese.
It would seem all the stock align sport/SE etc belt drive shafts are 41mm
The TT shaft is 47mm... I have one of each... they have the same pitch slider travel but the belt drive housing is more narrow.
The one in the picture is wider like the TT design and needs a longer shaft.
I have not managed to find a 47mm belt drive shaft... yet.
The sellers of this item do not seem to have spares for this unit listed.
I have sent a few emails... otherwise it's a problem.... does look nice though.
Geoff
Align trex based 450 dfc (6s) x 2 - 300x - mcpxbl - Aimdroix EVO - TBS Discovery - rctimer Spider - Flip Sport - QAV250 - ZMR250 - Warpquad 230 - Alien 4" - Alien 6">watch this space<
xpantz is offline        Reply With Quote Quick reply to this message
Old 05-12-2013, 06:51 AM   #6 (permalink)
"Out of interest; what is this tail assembly from? It looks really nice. " its an upgrade selling on ebay for the 450 , and yeah its very tight and well made. but for now ,cant find a shaft replacement , so once its bent the original housing cant be used . although you could take off the side plate and slider and mount that to a stock housing . by the way the shaft on the end has a sleeve /spacer that slides on to the end , the shaft is the same diameter . and the extra length is at the end opposite the slider , about 8 mm
Old 05-12-2013, 06:57 AM   #7 (permalink)
i would post some pics , but someone will have to tell me the secret to posting photos from other than a link , i have not been able to post one from "my pic " folder. cheers!.:]
Old 05-12-2013, 08:03 AM   #8 (permalink)
Yeah I see the problem.... I bought one before I realised it seems to have a custom shaft.
It only seems to be for sale on a few ebay sites... I've emailed them to ask about spare 47mm tail rotor shafts. I'll let you know if I get a reply.
Geoff
Old 05-12-2013, 08:11 AM   #9 (permalink)
xpants ,thanks , i sent a message two days ago - no response . and another just now . telling them no one will be interested in a product that has no replacement parts , maybe we will get some action . whats so hard about pumping out some extra tail shafts ?
Old 05-12-2013, 09:55 AM   #10 (permalink)
Click on "GO ADVANCED" button.
Scroll down aind the MANAGE ATTACHMENTS section and click on that.
Uploading from computer, click on "Choose File" button and it should take you to your photo file and choose a picture. When it returns back to the Choose File screen.. If so, scroll right to the UPLOAD button.
After it loads there is a button at the bottom, "Close this Window".
Should take you back to the original posting page to Submit Reply. . .
Häcksler is offline        Reply With Quote Quick reply to this message
Old 05-12-2013, 12:43 PM   #11 (permalink)
ok ,thanks hacksler . i have not taken it apart completely . , but you can see the end where its different
Old 05-12-2013, 12:53 PM   #12 (permalink)
here is one more the collar goes on the outside end , on the inside of the gear , the larger diameter is solid , not a spacer/collar
Old 05-12-2013, 05:30 PM   #13 (permalink)
Here are yer shafts, http://www.cnchelicopter.com/servlet...e-color/Detail ,
Used them when I built the same from align/tarot parts, get one of these to use the gear/belt pulley, http://www.cnchelicopter.com/servlet...400-CNC/Detail They also had just the pulley, but don't see 'em now.
Mine used, IIRC, a 1 mm shim on the rotor side, 4 mm on the other, as the pulley is wider to accommodate the grub screw, actually, both sides, I made my own, then found these, http://www.integy.com/st_prod.html?p...3#.UZAXKL7n-ic
That's all I got for ya, hope it helps...... Greg....
LotechGreg is offline        Reply With Quote Quick reply to this message
Old 05-12-2013, 06:55 PM   #14 (permalink)
Here is what U can do like mine, same shaft from CNC 48mm with the detachable gear, easy for replacing bent shaft or belt. Also the gear is positioned by a set screw so shims are no needed for the collar.
ID:	419913   Click image for larger version
ID:	419914   Click image for larger version
autosonline2002 is offline        Reply With Quote Quick reply to this message
Old 05-12-2013, 07:08 PM   #15 (permalink)
Thank you both.
I'm sure I'll get something done with those ideas.
Geoff
Old 05-12-2013, 08:28 PM   #16 (permalink)
+1 , great , now i can actually use it
Old 05-12-2013, 10:32 PM   #17 (permalink)
Hi autosonline,
Do you have a link on where to get that detachable gear.
TIA
__________________________________________
TREX 450 Sport V1 FBL, CX- 3X1000, Tarot Head
TREX 450 Pro FB
mCP X
joel0611 is offline        Reply With Quote Quick reply to this message
Old 05-13-2013, 01:42 AM   #18 (permalink)
Hi Joel, my friend in china got that gear for me, local store, no oversea shipping, I believe it was about $4 - $4.50, it was ship with some other personal items so no xtra shipping cost. U can also check this out, very similar, if u need help to get that gear, PM me.
http://www.cnchelicopter.com/servlet.../51/Categories
Old 05-15-2013, 06:57 AM   #19 (permalink)
Default Follow up on tail shaft
I emailed a couple of the ebay stores selling this part.
One store replied that they did not have the part.
The other for the listing below was more helpful.
http://www.ebay.com/itm/NEW-ALIGN-T-...:X:RTQ:US:1123
dear:
our tail rotor shaft for trex 450 sport etc is about 47mm total long.
we can offer you
pls tell us how many do you need,
then we will give you a best price.
best wishes!
Geoff
Old 05-16-2013, 04:13 AM   #20 (permalink)
Default Link to 47mm shaft
http://www.ebay.com/itm/251276126948...948%26_rdc%3D1
Geoff
