Go Back   HeliFreak > R/C Helicopter Support > 550 Class Electric Helicopters
550 Class Electric Helicopters 550 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Like Tree1Likes
Old 02-07-2011, 06:34 PM   #1 (permalink)
Default TRex 550e setups, specs and upgrades
This thread is dedicated to 550e setups, specs and upgrades. Please post up your 550e info and any additional info that could help both existing and new owners. Photos are fine if they are used to show mods and upgrades but please "Show off" your bird in the photo sticky.
Airframe
  • Kit: Stock FB
  • Blades: Align 520mm
  • Tail blades: KBDD 85mm
  • Paddles: Stock
  • Landing gear: 600n orange
  • Fins: Stock tail and 700n horizontal
  • Canopy: Fuzuno Infinite Fire
Power system
  • Motor: Scorpion 4025-630kv
  • Gearing: Stock 170T main gear, stock 16T pinion
  • ESC: CC Ice 60HV
  • RX power: Hyperion 2s 1700mAh LiFePO4
  • Main pack: Nano-Tech 25C 2650mAh packs in series as 12s pack
Electronics
  • Cyclic servos: Align DS610
  • Tail servo: Align DS620
  • Gyro: Spartan Quark
  • RX: Spektrum AR6200 (mod'd)
Specs (flight notes)
  • Flight style: Hard sport flying
  • Head speed: usually 2450rpm
  • Flight time: 5min w/ 1min reserve
  • Amp draw: 18A average, 60A spikes
Upgrades & mods
Aside from canopy, landing gear and fin, the frames have been modified to allow for larger motor and the 600e canopy spacers were installed. I plan to install the KDE 700 main gear hub and 700 main gear at some point.
My build article is here
https://sites.google.com/site/tjingu...s/rex550-build
- Chris
TJinTech heli...info...news...such
Helis: TRex 450 Pro - Protos - TRex 550e
Stuff: Spektrum DX7 - iCharger 208B - Hyperion G3
TJinGuy is offline        Reply With Quote Quick reply to this message
Old 02-07-2011, 11:37 PM   #2 (permalink)
good idea.
Airframe
• Kit: Stock FBL
• Blades: Align 550mm
• Tail blades: Align 92mm
• Paddles: Vbar 5.0
• Landing gear: RcCarbon 500 gear
• Fins: 700 veritcal, no horizontal (no advantage)
• Canopy: Fusuno, Canomod, Stock
• 600 Tail Boom and Belt – stock tt gear blew out 3 times, 550e stcok belt snapped after a dozen flights. 600 belt so far so good.
Power system
• Motor: Neu 19071y42n
• Gearing: 164 tooth 700 nitro mod.7 18 tooth pinion
• ESC: CC Ice 100 w/ Pro BEC
• RX power: BEC
• Main pack: Turnigy 6s 5000 40c
Electronics
• Tail servo: Futaba BLS251
• Gyro: Vbar 5.0
• RX: Spektrum AR7000
• Head speed: 2500
• Flight time: 4:30 - 5min
• Amp draw: 35-40A average, 230A spikes
Upgrades & mods
• *2mm Fusuno frames
• *KDE Head
• *KDE main shaft Thrust bearings
• *KDE Motor Mount
• *KDE Main Gear Hub
• *KDE Performance Tail Upgrade V2
• *KDE Rear Frame Stiffener
• *Quick UK Swashplate
• *Heim Joint Chinese tail grip weights
• *Aluminum/Carbon tail servo boom mount
• *Align 600 Silver Aluminum swash driver arms
• *Align 600 tail boom and belt drive installed
• *Align 600 Aluminum Belt Drive Tail Box
• *Align 600 Aluminum tipped carbon boom supports
• *Align Aluminum Tail pitch arm
• *Align Trex 700 Nitro 164 tooth main gear mod .7
• *Carbon Fiber tail pitch push rod
Build info here
https://www.helifreak.com/showthread.php?t=223311
may soon become a low budget camera ship with a logo 550 to replace it.
philipfrank is offline        Reply With Quote Quick reply to this message
Old 02-08-2011, 12:49 AM   #3 (permalink)
Here's my baby
Airframe
  • Kit: Stock FBL
  • Tail blades: Stock 90mm
  • Landing gear: Black Align 700
  • Fins: Fusano 2mm tail fin and metal lightweight tail clamp (no horizontal fin)
  • Canopy: Align stock (another in the future)
Power system
  • Motor: 600MX
  • ESC: Stock Align 70 esc (another in the future)
  • Main pack: Zippy flightmax 6s 5000mAh 30C
  • Bec: Hercules 10A HC bec @ 6.0 volt
Electronics
  • Tail servo: Align DS620 (another in the future)
  • FBL: BeastX V2.0
  • RX: Futaba FASST R6008HS
Radio and RX
  • Futaba T8FG
  • R6008HS
  • Flight style: Basic flying (I still have much to learn)
  • Head speed: About 2200rpm
  • Flight time: 10min
Upgrades & mods
  • Da Vinci flybarless turnbuckle control rods
  • Canopy stand-off
  • Qiuk uk metal lightweight tail clamp without a horizontal fin
  • KDE performance tail upgrade V2
  • RC Booya quick release canopy mounts
  • Metal vertical stabilizer mount Align
  • Metal anti-rotation bracket Align
  • Metal tail servo holder Align
  • Metal tail pitch slider Align
  • Metal tail bell crank Align
  • KDE metal battery mount upgrade
  • Carbon fiber tail servo push rod Align
  • Carbon tail boom Align
  • 2mm vertical tail fin fusano
We Men Need a Second Hobby, Besides Women
Futaba, Vbar, Kontronik, Align, IKON, 3GX, Vario, WR Hercules
Mikado, Scorpion, BeastX, Gens Ace, Goblin, Hyperion, JetCat Turbine, APS, BD3SX
www.modelhelicopter-review.nl
trexpro is offline        Reply With Quote Quick reply to this message
Old 02-08-2011, 01:38 AM   #4 (permalink)
Airframe
Kit:1: FB Built to FBL 2: FBL both stretched
Blades: 1: Edge 603 2: Align 520
Tail blades:1: Edge 95 2: Stock 90mm
Landing gear: 700 F3C
Fins: 1: yellow Fusuno 2: Stock No horizontals. turned the holder upside down(screws facing down) for sleeker look.
Canopy: Align stockers. + 2 Sponsorcanopies(stickered)
Power system
Gearing: 1: 170:15 2: 170:17
ESC: Castle Creations ICE HV80
Main pack: Turnigy 2650mAh 40C 6s *2
Bec: Turnigy 8-15A, Seperate 2200mAh pack
Electronics
Tail servo: 1: MKS BLS980 2: DS620(soon to be BLS980
FBL: 1: Fullsize regular 5.0pro 2: Blueline MiniV 5.0pro
RX: Futaba FASST R617FS
Radio: Futaba 7C
Flight style: Mild to wild 3D
Head speed: 1: 2250 2: 2700. Both govern'd
Flight time: 1: 4:30 2: 5:30
Upgrades & mods
Canopy stand-off's
KDE thrustbearing blocks on both.
1: beltdrive
1: Self designed one way hub, for accepting Sprague bearing.
Designing/Building the HEX Helicopters
Sponsored by Gens Ace Batteries, Gryphon Rotorblades, RCbearings.co.uk,
Nko15 is offline        Reply With Quote Quick reply to this message
Old 02-08-2011, 08:39 AM   #5 (permalink)
Airframe
  • Kit: Stock FBL
  • Landing gear: Stock
  • Fins: Align 700e tail fin no horizontal fin
Power system
  • Motor: 600M
  • ESC: Stock Align 70 esc (v2)
  • Main pack: Turnigy 5000mah 30C
  • BEC: CC BEC Pro @ 6.0v
Electronics
  • Tail servo: Align DS650 (Boom mounted)
  • FBL: SK-720
Radio and RX
  • TX: DX7
  • RX: None
  • Flight style: Sport and Light 3D (Learning)
  • Head speed: 2200rpm
Upgrades & mods
  • 600e Canopy stand-off's
550e FBL SK720
450Pro FBL SK720
250SE FBL SK720 +250SE FB
4G6, mCPX, mCPXBL, nCPX, mSR, mCX
Gadflyii is offline        Reply With Quote Quick reply to this message
Old 02-10-2011, 04:38 PM   #6 (permalink)
Airframe
  • Kit: Stock FB
  • Landing gear: White Align 700
  • Fins: Trex600N vertical fin,No horizontal fin
Power system
  • Motor: Scorpion 4025-1100kv with Boca ceramic bearing
  • Gearing: Trex700N 164T main gear, Revco 18T pinion
  • ESC: CC Ice100A
  • BEC: CC BEC Pro @ 6.0 volt
  • Main pack: Turnigy 6s 5000mAh 40C
Electronics
  • Tail servo: Futaba BLS 251
Radio and RX
  • JR 11X
  • AR 9000 with 2 satellites
  • Head speed: 2100-2600
  • Flight time: 6 mins
Upgrades & mods
  • Fusuno frames
  • Finishing caps all around
  • Braids all around to protect wires
  • Trex600N canopy stand off
  • Metal canopy mount
  • KDE main gear case
  • KDE Anti rotation bracket
  • KDE motor mount
  • CC quick connect
  • ABEC3 one-way bearing
  • ABEC3 bearings all around
  • QiukUK CF tail pushrod guidless
  • QuickUK round tail servo horn
  • Sonix CNC tail servo mount
  • Microheli CNC horizontal fin mount
  • Trex600 metal tail case, belt driven
  • Align metal tail control arm
Trex 600E Pro FBL with V-bar,600MX-510KV,HW 70A HV ESC,
CC BEC Pro,Align DS610,Futaba BLS251,
JR11X with Hyperion LifePO4,
Icharger 306B with Meanwell 1000W 24v power supply.
Helis4me is offline        Reply With Quote Quick reply to this message
Old 02-27-2011, 08:32 AM   #7 (permalink)
Default HELP 550e flybarless
I have set up and flown a 450 and a lot of smaller stuff. I am having issues with the flybaless sensors. I am using a brand new dx8 on the stock kit and everything works till i plug in the flybarless electronics. At that point the lights blink green on the controller then i get a red blinking light. As the instructons that come with the copter are rather brief, maybe sonone has run into this problem. The only plug that is questionable is the plug that is on the rudder pigtrale that is for the sensivity. HELP please
gwweber is offline        Reply With Quote Quick reply to this message
Old 02-27-2011, 03:03 PM   #8 (permalink)
Did you perform DIR setup yet? That's a must do right away.
bad007 is offline        Reply With Quote Quick reply to this message
Old 02-28-2011, 01:50 PM   #9 (permalink)
Default T-Rex 550
Airframe
• Kit: Stock
• Tail blades: Align 90mm
Power system
• Motor: 4025-630kv
• Gearing: 170T 16T mod 0.7
• ESC: hobbywing platinum 70A HV
• RX power: BEC Align + 1000mah lipo 2S
• Main pack: 2x nanotech 25-50C 2650mah(backorder)
Electronics
• stock
• RX :ar6100
• Gyro: spartan quark
• Flight style: sport flying
• Head speed: soon!
• Flight time: soon!
• Amp draw: soon!
fabricio is offline        Reply With Quote Quick reply to this message
Old 03-08-2011, 12:21 AM   #10 (permalink)
Airframe
  • Kit: Stock FBL
  • Blades: Fun-Key 560mm
  • Tail blades: Align 85mm
  • Landing gear: Standard
  • Fins: Standard
  • Canopy: Standard
Power system
  • Motor: Align 600M
  • ESC: CC Ice 100A
  • BEC: CC Bec Pro 2
  • Main pack: Align 40C 5200mAh (6s)
Electronics
  • Gyro: Align 3G
Radio and RX
  • Futaba 10CHG
  • R617FS
  • Flight style: Sport flying
Upgrades & mods
  • Frame strengthen with CNC parts
  • Align CNC tail servo mount
  • Double torque tube bearing
  • Align CNC vertical fin holder
T-REX 700E FBL
T-REX 600E FB
T-REX 550E FBL(SOLD)
Futaba 8FG Super
ealt is offline        Reply With Quote Quick reply to this message
Old 03-08-2011, 03:09 AM   #11 (permalink)
550E Flybar Super Combo. All align and doin fine.
CC PRO BEC added.
Crash549 is offline        Reply With Quote Quick reply to this message
Old 03-27-2011, 12:04 AM   #12 (permalink)
Default Hulk project
Airframe
* Kit: Stock FBL
* Blades: Edge 553mm
* Tail blades: KBDD 85mm
* Fins: FUSUNO Carbon Fiber Vertical Fin (2mm) FUP-064
* Canopy: Canomod Shrek Airbrush Fiberglass Canopy
Power system
* Motor: Scorpion 4025-740kv
* Gearing: Helical 188T main gear, Helical 16T pinion
* ESC: CC Ice 80HV
* RX power: HK 650mAh 3S Lipo
* BEC: INTEGY E2043 5 amp BEC 7v.
* Main pack: Voltz 35C 2650mAh packs in series as 12s pack
Electronics
* Cyclic servos: Align DS610
* Tail servo: Align DS620
* Mini V 5.0
* RX: Spektrum Satellite
ID:	217729   Click image for larger version
ID:	217730   Click image for larger version
ID:	217731   Click image for larger version
Ludagad likes this.
integy2 is online now        Reply With Quote Quick reply to this message
Old 04-04-2011, 08:15 PM   #13 (permalink)
Deleted
Old 04-04-2011, 08:16 PM   #14 (permalink)
Deleted
Old 04-11-2011, 10:03 AM   #15 (permalink)
ds610's
620 tail
ice 100 gov. 1900,2300,2450
pro bec 2
min V blue pro 2 sats- awesome
523 edge blades
1907h 1y-off for sevice awesome power!!
600mx-17t
170 main gear
micro heli tail control arm
kyosho 10x19x5 main bearings
kbdd green dampers
JR 9503
x4 voltz 6s 5100 35c
2s 1800 receiver pack
Team... WinMor
Team... Epbuddy
Travis@epbuddy.com
Winmorknlz@aol.com ...Winmorkennels.com
winmorknls is offline        Reply With Quote Quick reply to this message
Old 04-12-2011, 10:33 AM   #16 (permalink)
I have recently made a decent number of changes to my 550e, here is the new setup (updates in red)
Airframe
  • Kit: Stock FB, upgraded to FBL
  • Paddles: N/A
Power system
  • Gearing: 700e mod1.0 115T main gear, 11T pinion
  • ESC: CC Ice 60HV
  • Main pack: Voltz 2600 35C 6s & TP 2700 45C G6 6s packs, pair of each in series as 12s pack
Electronics
  • Gyro: Mini VBar
  • RX: Spektrum satellites (2)
  • Head speed: usually 2250rpm
  • Amp draw: 20A average, 80A spikes
Upgrades & mods
Aside from canopy, landing gear and fin, the frames have been modified to allow for larger motor and the 600e canopy spacers were installed. KDE 700e main gear conversion hub installed. The gear is pretty noisy but works fine. I will probably go to the 164T mod0.7 main gear at some point. A FBL head is installed. I used the KDE FBL main rotor housing, Align silver 600 grips and swash driver, and a Mini VBar.
- Chris
Old 04-28-2011, 08:54 AM   #17 (permalink)
Default Newbie with a 550e build question.
I am a newbie in the early build stages of build a 550e and I have a question I could use some help with.
There is a frame cross support that can be installed in two different positions, high or lower mid frame.
I do not understand the benefits of either position.
Can anyone help me determine which position would be best given my lack of experience?
Thanks in advance for any advice.
Have been searching the forum for the answer and have not been successful yet.
Bill
DILLIGAFF is offline        Reply With Quote Quick reply to this message
Old 04-28-2011, 10:59 AM   #18 (permalink)
This thread is dedicated to 550e setups, specs and upgrades. Please post questions in the 550e forum as a new thread.
- Chris
Old 04-29-2011, 02:17 PM   #19 (permalink)
Airframe
  • Kit: Stock FBL
  • Tail blades: KBDD 92 mm
  • Landing gear: 550
  • Fins: Stock tail and no Horizontal : Quick UK Carbon Pushrod
  • Canopy: Fusuno
Power system
  • Motor: Viper VSH6013
  • Gearing: Align
  • ESC: YGE 120
  • RX power: CC BEC Pro
  • Main pack: Flightmax 5000mAh 40C
Electronics
  • Tail servo: Futaba - BLS 251
  • Gyro: Beast X
  • RX: Spektrum 6210
Blade mCP-x
Trex 450 Pro FBL - ESC YGE 60 - Viper VSH4535 - BeastX - MKS DS 95i + DS 95 x 3
Trex 550 FBL - ESC YGE 120 - Viper VSH6013 -BeastX - BLS 251 - DS610 x3 - CC BEC Pro
Henseleit TDR ordered
Gasoil4ever is offline        Reply With Quote Quick reply to this message
Old 06-10-2011, 04:51 PM   #20 (permalink)
Default My 550E
Airframe
  • Kit: Stock FB converted to FBL
  • Blades: Edge 520 FBL
  • Landing gear: 550
  • Fins: Stock
  • Canopy: Align Red
  • Carbon Fiber Tail & Pushrod
Power system
  • Motor: Align 600MX
  • Gearing: Stock Align
  • ESC: Kontornic Jive 80HV
  • Main pack: Align 5200mAh 40c
Electronics
  • Gyro: Beast X
  • RX: Spektrum 8100
  • Radio: Spektrum DX8
  • Telemetry: Spektrum TM1000
Upgrades
My biggest upgrade was adding the Kontronics Jive 80 HV. This upgrade REALLY increased the power of my 550e (What feels like almost double the power from the stock ESC) I converted my FB to FBL using the stock Align head with the Microbeast. Added Edge 520 FBL blades. Upgraded the tail and tail pushrod to carbon fiber. Other than that... all stock. This 550e is a monster!
joshheli is offline        Reply With Quote Quick reply to this message
