Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > mCP X Brushless Mods
mCP X Brushless Mods Blade Micro CPx Brushless Mods and Conversions
Old 05-18-2015, 04:01 PM   #281 (permalink)
Throttle change rate was used seldom and was removed to make room for the oneshot feature and the bootloader.
For the most recent Revision of BlHeli Setup see my blog.
4712 is offline        Reply With Quote Quick reply to this message
Old 05-21-2015, 11:46 AM   #282 (permalink)
Default Optimization for large motors/props
I am looking for a hint how to tweak my large Hexa with pixhawk.
Symtom: motors are vibrating and the output is oscillating.
Hardware:
Arris 5010 12 pole motor with 18" props
Skywalker Platinum Pro opto 30A
Blheli 13.2 with default settings: Demag low/Pwm:High/Timing:medium
Does anyone has an idea where to start?
With the huge props I am not sure if its the right way to enable damped light?
Because of only 12 poles I left the timing on medium.
Or maybe the motor is running softer with demag compensation on high?
Hope it is the right place here to ask about recommendations?
Cheers Gregor
Gregmaan is offline        Reply With Quote Quick reply to this message
Old 06-14-2015, 09:09 AM   #283 (permalink)
Hello,
I have BLHeli 13.1 Multicopter loaded on 4 Afro 20A Slims. How do I tell the PWM frequency when the firmware has labels as High, Low and Damped Light? Is it ESC dependent? Thanks.
Spektrum & µBeast / Devil 480, Tarot 650 Ironman Pixhawk
lasakro is offline        Reply With Quote Quick reply to this message
Old 06-15-2015, 04:49 AM   #284 (permalink)
read the manual please:
https://github.com/bitdump/BLHeli/bl...%20Rev13.x.pdf page 8.
High pwm frequency is around 16kHz, and low pwm frequency is around 8kHz.
One benefit of using a low pwm frequency is that the step from almost full power to full power becomes smaller. On the other hand, 8kHz is in
the audible frequency range, and also there is a step in power when the motor rotation frequency is equal to the pwm frequency.
Pwm damped light mode adds loss to the motor for faster retardation. Damped light mode always uses high pwm frequency.
Old 06-15-2015, 06:16 AM   #285 (permalink)
Thanks 4712.
Old 06-16-2015, 04:15 AM   #286 (permalink)
Default blheli
Does anyone know where we can download blheli firmware version 14?
willyfph is offline        Reply With Quote Quick reply to this message
Old 06-19-2015, 03:42 AM   #287 (permalink)
I think it's a secret because no one will tell me either
Hello My Name Is Joe
Blade 130X - Lynx EOX / Blade 300x - AR7200BX, 2213-3585 / Trex 500ESP DFC - AR7200BX, 500MX / Trex 550e DFC - AR7200BX, 600MX / TSA 600e Pro - AR7200BX, 700MX / TBS Discovery FPV - APM, Sunnysky 980kv/ DX8
jabu32 is offline        Reply With Quote Quick reply to this message
Old 06-19-2015, 05:14 AM   #288 (permalink)
My guess would be that you can get it from the same place you got 13.1...
But you'll need to wait until it's published
Old 07-12-2015, 07:19 AM   #289 (permalink)
BLHeliSuite 14.0.0.0
Old 10-23-2015, 03:16 AM   #290 (permalink)
I asked this in the Blade 230s forum before I realised that this is the right place...(sorry for cross posting )
Can the Blade BL1517 Dual ESC be programmed and/or flashed with BLHeli?
I flashed almost all the ESC's I have with BLHeli because I love the adjustable soft start and governor.
If it doesn't fit, you need a bigger hammer
nano CPX - nano CPX BL - 2 x MCPX V1 BL - 2 x MCPX BL - 230S - MQX - Gaui 330X - 4G6V-FBL - 4G6V - cX450pro - T450pro - T500 DFC - Gaui EP550 FBL
xs4reak is offline        Reply With Quote Quick reply to this message
Old 12-09-2015, 05:13 AM   #291 (permalink)
Anyone able to install this latest version of BLHeli? I am getting a couple corrupt file errors. I am trying to get my old MCPx BL conversion back up.
Scorpion Power Systems
Michaelinpr is offline        Reply With Quote Quick reply to this message
Old 12-09-2015, 05:22 AM   #292 (permalink)
I am now trying to download it to another computer and Chrome has said the file is Malicious and blocked it. Says the site may have been hacked.
Old 12-09-2015, 06:24 AM   #293 (permalink)
http://www.rcgroups.com/forums/showp...postcount=4160
Or try another browser...
HTH
Old 12-09-2015, 06:54 AM   #294 (permalink)
Thanks. I will try that now. I did use the green download button as mentioned. I will post back with my findings.
Old 06-13-2016, 10:01 AM   #295 (permalink)
Please can anyone tell me which paramater changes the low voltage cut off setting on the rc timer blheli version esc i'm running 14.6 blheli version
spinzer is offline        Reply With Quote Quick reply to this message
Old 06-13-2016, 01:25 PM   #296 (permalink)
can anyone tell me what firmware i can load to get to be able to change the lvc ? or is there better firmware than blheli firmware for my rctimer 40 amp esc ?
the use will be multirotor.
Old 08-21-2016, 04:44 AM   #297 (permalink)
Hi guys, I think someone here might be able to help me out.
I have a mcpx bl with an external main esc (HobbyKing 10A) and I installed it 18 months ago. I have programmed it using blheli by then.
Now I wanted to change some settings but when I connect it, the program says there is a connection issue/no connection.
I soldered the female plug on the little esc myself and it worked perfectly 18 months ago. But now it seems something have happened that the connection can't be established.
I also have the same esc type for the tail (same heli) and I soldered the plug exactly the same way, but this works well with immediate connection, which means there are no issues with the programming stick or anything.
The main 10A esc runs the main motor very well and I just need to change some setting to try increase flight time a bit.
Does anyone have an idea or saw this problem before?
Thanks a lot in advance!
Cheers!
Sent from my iphone using Tapatalk
T-Rex 450L Dominator | T-Rex 450PRO DFC
MCPX BL heavily modded | DX9... and a lot of effort and passion!
LEORITY is offline        Reply With Quote Quick reply to this message
Old 08-21-2016, 06:38 AM   #298 (permalink)
Sure, just resolder the connection.
OR
If you had bad luck like me the solder pad for the positive connection ripped off. In that case make another connection to one of the positive power wires.
Good luck and happy landings.
daveapplemotors is offline        Reply With Quote Quick reply to this message
Old 08-21-2016, 07:51 AM   #299 (permalink)
I might try this.
Is the positive the red one? See pic.
Thanks!
Old 08-21-2016, 01:12 PM   #300 (permalink)
IDK It probably is if that is a jpg from the HF pages that have the little circles to point out solder points on each Silabs ESC.
Tags
blheli, blheli-setup
