Go Back   HeliFreak > R/C Electronics Support > YGE
YGE YGE ESC Support and Discussion
Old 06-01-2012, 01:07 PM   #1
joe1l
Default Futaba TX + YGE ESC NEW Throttle Endpoint programming method!
This should be made sticky.
First let me say this currently only applies to Futaba TX with YGE ESC's plugged in directly to a Futaba RX or CGY750 THe (throttle port). It does not apply to Vbar gov or SK720 gov.
The issue causes a mis-alignment of TX Throttle % to the actual ESC throttle %.
The misalignment causes a non linear power increase based on throttle position. This is most noticeable when comparing RPM change from 60% to 80% and 80% to 100%.
To fix the issue you should re-program your motor stop/motor full using this modified instruction subset:
1.) Programming your TX Endpoint Range with YGE plugged into CGY750
The process for programming your YGE ESC with PROG CARD using a Futaba TX is identical to the original YGE instructions with the exception of the TX throttle curve used for programming the YGE MOTOR STOP and FULL SPEED. In your TX set a temporary linear throttle curve where low stick =1% and high stick is =99%. Using YGE Programming card Set YGE MOTOR STOP at low stick (1%) and FULL SPEED at high stick (99%).
Calibrating your Endpoints
Calibrating YGE Endpoints (necessary for External Gov)
2.) Once Programming is complete you wlll need to calibrate your low and high endpoints to ensure throttle accuracy necessary for future External gov operation.
Set the same linear throttle curve used during programming with low stick =1% and high stick=99%.
a.) Low endpoint calibration: Make sure ESC is powered down and throttle cable plugged into RX/FBL throttle channel. Set stick to low position (1%) Go to TX Endpoint menu and reduce low enpoint to 50%... Leave TX in Endpoint menu and power up ESC with lipo. (ESC will initialize lipo count but should not of armed yet). Slowly increase Low endpoint 1 point at at time untill the ESC audiably arms. Once ESC is armed...stop increasing endpoint on TX( no buffer endpoint necessary)... Disconnect power on ESC. Low endpoint is now calibrated... (set low throttle back to 0%).
b.) High Endpoint calibration. must be done on bench without blades or motor pinion. Power up ESC and increase throttle to 99% and go to TX endpoint menu. IF ESC LED is off...decrease the High Endpoint until LED turns back on. 99% throttle = Last endpoint where ESC LED is still lit.
YGE instructions have always suggested that with some transmitters the range would need to be adjusted.
The speed controller has a fixed throttle curve setting, so
that with all usual transmitters the stop and full power points
are linearly connected. With all programmable transmitters,
the throttle range should be set to default (±100%), the
center point set to zero and throttle trim enabled.
Nevertheless, with some transmitter types the range needs
to be adjusted. For that the throttle endpoints have to be set
so that one notch before lowest stick position the motor is
stopped and that one notch before full power the motor is
actually at full power. Full power is indicated by the LED that
is completely turned off.
Gaui X7 MSH Brain YGE160HV Xera4035-480 X475 FES MSH Brain YGE120 Xera4020 Gaui X5 MSH Brain YGE90HV Xera 4025
Gaui X6 vbar silver 5.3 YGE120HV 700mx
ElektroRC.com field rep (YGE, MSH, LAHeli)
joe1l is offline        Reply With Quote
Old 06-02-2012, 05:06 PM   #2
Steve Evans
Hi Joe,
I've just wired up my heli so I can easily plug in the ProgCard (such wiring is normally hidden) and I've negotiated use of the kitchen table tomorrow for bench testing, so I'll do some logging and post the throttle response curves for normal calibration using full range and your method. It makes sense to plot battery voltage, S.Bus THR channel, ESC PWM and headspeed during ESC programming, Tx calibration, and some test runs to plot response. Any special requests?
Steve
Trex 450SEv2/HS65-MGs cyclic/Spartan Quark/DS520 tail
Trex 450ProV2 DFC/CGY750 FBL/DS410s cyclic/DS520 tail
Trex 500ESP DFC/CGY750 FBL/YGE-120LV ESC/DS510s cyclic/DS650 tail
Futaba 8FG 2.4GHz
Steve Evans is offline        Reply With Quote
Old 06-03-2012, 09:30 AM   #3
Steve Evans
Deleted due to doubt over if I disabled gov mode before running my tests. I spent hours yesterday doing this and I was convinced I'd disabled the gov, but now Joe has asked me about it I can't claim to remember actually doing so. The peak RPM when I ran gov. store at the end of the procedure was higher than the peak RPM measured during the testing, so I think I probably disabled the gov, but I can't be sure enough to use the results to cast any doubt over Joe's finding.
Apologies for any potential confusion caused. I shall have to repeat this when I've a few spare hours.
Steve
Futaba 8FG 2.4GHz
Last edited by Steve Evans; 06-04-2012 at 11:38 AM.. Reason: Potential cock up during testing
Old 06-03-2012, 02:18 PM   #4
Steve Evans
See above.
Futaba 8FG 2.4GHz
Old 06-18-2012, 11:36 AM   #5
beans07
What do you do if plugged into a vbar but not using the external vbar gov? (using YGE gov)
Synergy E7 ~ Logo600SX + 600SE ~ Synergy E5 ~ Synergy N5C ~ Mini Protos ~ Futaba 14SG
beans07 is offline        Reply With Quote
Old 06-18-2012, 04:42 PM   #6
Steve Evans
In that case I don't think it matters. When using gov. store mode the throttle input is constant, so dynamic response doesn't matter. When calibrating gov. store (on the first spool up after enabling it) the YGE spools up to the max RPM you allow, and thereafter you just set it to a percentage of that. Joe's method was addressing the response for dynamic operation with an external gov.
Steve
Futaba 8FG 2.4GHz
Old 07-31-2012, 07:29 AM   #7
aviator493
Thannks for posting this. I am about to setup my first YGE 160 with a 8FG trans andCGY750 and would have never done this had I not seen your insructions!!! How did you make the 1%-99% linear? I'me guessing you INH everything in between 1% and 99%? I tried doing it mathematically and the controller won't give me that many decimal points! lol
One other question, what happens if I don't do your method? Will the governor act weird or will I just notice a non linear RPM change as I'm trying to find a perfect HS? I ask because ALL 3 of my flight modes NOR, IU1 and IU2 are ALL linear aka 3 Gov HS settings.
aviator493 is online now        Reply With Quote
