250 Class Electric Helicopters 250 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
06-19-2015, 12:51 PM | #1 (permalink) |
Fear the Spork!!
trex 250 pro ESC
is the stock esc good enough for this heli? I have a feeling the bec is not up to task. what about the Talon 15 ?
Trex 450L, OMP M2, Futaba 14SG |
06-19-2015, 01:38 PM | #2 (permalink) |
The stock ESC can struggle with FBL systems, but the Talon 15 works great.
I'm flying a Talon 15 with a 16t pinion and up to 4500rpm for 3D flight, its had several hundred flights without so much as a hiccup :-)
Helis: Oxy 4 Max (day + night), Gaui X3 380, Oxy2 FE 215, Oxy2 Sport 190 Radio & FBL: Spartan Vortex, MSH Brain, Jeti DS-14, Spektrum DX8G2 Sims: RealFlight & AccuRC |
06-19-2015, 03:13 PM | #3 (permalink) |
Like myxiplx I too am running Talon 15, but a higher head speed of 4701.
If the stock ESC you are talking about is the blue one, it works just fine but if it’s the yellow I would advice you to change it. The governor on the Align is not very good, but V or flat curve on the blue ESC is fine.
T-Rex 550E V2 Spartan VX1n, T-Rex 250 PRO DFC Spartan VX1n, Blade 130X. Futaba T8FG Super |
06-19-2015, 03:15 PM | #4 (permalink) |
I put a YEP in mine and its been flawless.
Current favorites... Oxy 3, Goblin 380, Logo 480Xx, Goblin 500, TBS Gemini, 250 FPV Quad Racers, bunch o' Planks, etc.. |
06-20-2015, 03:14 AM | #5 (permalink) |
My stock (blue) esc failed on the 97th flight causing the first crash on this heli. Replaced it with a Talon15 with gov setup and I couldn't be happier.
Allan TREX 250 PRO,Talon15, GPRO, Zeal ----TREX 500 EFL PRO, GPRO, RAILS ----2x TREX 450PRO V2, 1xGPRO&1xBRAIN, Talon35, RAIL , Zeal ---- SAVOX powered TREX500 EFL in Roban scale UH1-N ---- TREX 600 EFL PRO, GPRO, RAILS ---- DX9 ---- |
08-22-2015, 03:45 PM | #6 (permalink) |
My yellow esc failed (brown out) and i upgraded to Talon 15, works perfect!
Align T-Rex 700N DFC w/Brain (Redline 100H) SAB Goblin 500 w/Brain (Scorpion 4025-1100) |
08-22-2015, 08:39 PM | #7 (permalink) |
I had tried CC25, Talon 15, YEP 18 and Talon25. They all worked great. CC25, Talon15 and Talon25 internal governor works greats.
Nano CPx, Hirobo Quark 250 SE, Pro Upper Frame, Talon25, KDE, KST215, DS95i, Mini Vbar 450 Pro (6s), KDE, Lynx, Tarot, RJX, YEP40, KST215 & 515, SK540 465 (6s), Align DFC, HW50AV3, KST315 & 8910A+, SK720BE |
