Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > X5
X5 Discussion and support of the Gaui X5
Old 04-05-2016, 11:07 PM   #1 (permalink)
Default Which dampers for 2000-2300 w/ FBL, sport flying?
It is my understanding that different dampers like different head speeds. I'm using 2000, 2150, 2300 for IU1, 2, 3. I spend most of my time at 2150.
I've got RJX energy blades and a Spirit FBL. I read somewhere that with an FBL I should be using really stiff dampers, because the FBL is making many small corrections and will do better with a crisper head. Is that true?
I'm currently using th stock black dampers and they appear ok to me, I don't think they're worn yet. I don't get much wiggle when I try and move the blade grips up and down. But I'll need some new ones eventually, so I thought I would start looking now.
If it matters, it's the FES head, not the formula head.
Heli-X, Gaui X3 & Gaui X5 w/ Spirit FBLs, Quads with BetaFlight, Various FPV Fixed Wing w/ ET Vector FC, FrSky QX7S w/ OpenTX, FMA DPL 8x2
kirby_ is offline        Reply With Quote Quick reply to this message
Old 04-06-2016, 01:02 AM   #2 (permalink)
When I had that head, the lime green dampers worked great.
GAUI R5 V2,RAW 700, GLOGO690, RAW580, RAW420all VBAR
VControl, DX9, DX7s
Accurc and RealFlight 8
C #773
Heli$ is offline        Reply With Quote Quick reply to this message
Old 04-10-2016, 12:26 PM   #3 (permalink)
+1 on the lime green.
Softer for sport flying like built in expo, and harder for 3D.
Softer with lower headspeeds, and higher HS for harder dampers.
Most Gaui dampers have a hardness shown , so compare with what you have now.
Gaui X7 FZ, Gaui X7 Formula, Gaui X5v2 Formula , Gaui X3 6S ,
Trex 800 DFC, Trex 700E, Trex 600N,
Goblin 700 Tri-oblin, Goblin 570 Freedom Edition #19
.... MSH Brain, Spektrum, MKS, Xpert, Scorpion, Kontronik, KDE, Helix, VTX
Chigoe is offline        Reply With Quote Quick reply to this message
Old 06-28-2016, 06:29 PM   #4 (permalink)
By the time you need new dampers, the conversation may be very different. I wouldn't spend too much effort on this when other parts are much more likely to need replacement sooner.
Logo 600 (VBar Neo), Gaui X5 FES (BD3SX), Warp 360 (MiniVbar), Trex 450 Pro FBL (Spirit Pro), OXY 3 stretch (Spirit), OMP M2 Explore, two 180CFX (one uSpirit), 130X, XK110, Nano CPX
PassinThru is offline        Reply With Quote Quick reply to this message
Old 06-29-2016, 03:37 PM   #5 (permalink)
Use the hardest ones for your flying style,
Red may have heli wobble during spool up but work well
Green kbdd
black little too soft and wear out fast
Diabolo 700, Oxy 5 Nitro, OMP M2, Futaba
DanMcN is offline        Reply With Quote Quick reply to this message
Old 08-02-2016, 09:25 AM   #6 (permalink)
I just switched to the blue dampers from the lime green (LG). I'm spinning between 2700-2800 RPM's and get much less flutter/chatter than the lime. Also, I had put a lot of flights on the LG and when I went to take them out there were like mush. I've had no wobble and feel that things are much more crisp than before. I've also switched from the RJX Energy blades to the SAB which I prefer much more. They are slightly heavier and stiffer and better balanced. If you are considering bumping up your head speed, just something to think about.
XL V2, Soxos 7.1L - Previous: Kraken 580, Nimbus, Protos 380, Kraken 700, Diabolo 700, Oxy 5/2, Logo 600 / 550SX, Protos 700, Synergy 516, Velos 880, Gaui X7 / X5, Goblin 380, Blade 120SR/180SR/ mcpx BL/300X/450XL, Align 700X/150/Leap 3D
gtruk is offline        Reply With Quote Quick reply to this message
Old 08-09-2016, 05:49 AM   #7 (permalink)
I use the red ones and I fly IU1 2300 and IU2 2450. Quite happy with how it feels, but I can notice a small wobble/shake at around 2100.
ronaldst is offline        Reply With Quote Quick reply to this message
Old 08-11-2016, 10:14 AM   #8 (permalink)
ronaldst, same here but no big deal.
Old 08-19-2016, 10:52 AM   #9 (permalink)
Which engine/pinion do you use?
2700-2800 is immensely high on the X5 isnt it?
Old 08-19-2016, 02:45 PM   #10 (permalink)
Nah, it can handle it. I'm flying 12S with an XNova motor 4025-560kv. Take a look at the 12S thread and you'll see some guys flying at 2900 regularly.
Old 08-28-2016, 02:30 PM   #11 (permalink)
I would like to get the kbdd lime green ones but cant find them anywhere..maybe someone has a link
tonys-heli is online now        Reply With Quote Quick reply to this message
Old 08-28-2016, 04:15 PM   #12 (permalink)
I hear that kbdd lime has hardness between black one and red one... Hope this help
Quality3011 is offline        Reply With Quote Quick reply to this message
Old 08-28-2016, 04:39 PM   #13 (permalink)
it does..a little bit..thats what im looking for but I still need to find a place that has them in stock. must be a hot item.
Old 08-28-2016, 04:56 PM   #14 (permalink)
First link... Try this http://www.scaleflying.com/Damper-Se...on_p_2763.html
Old 08-28-2016, 05:27 PM   #15 (permalink)
yup..that worked..thanks for helpin a fellow jersey guy out
Old 08-28-2016, 06:32 PM   #16 (permalink)
Actually, lime green are about as soft as you can go. They're rated a 65 and black is 75. Blue should be 85 and red 95.
