Skookum Robotics Skookum Robotics SK-360 SK-540 & SK-720 Digital Flybar |
10-02-2015, 07:42 AM | #81 (permalink) |
the honeymoon is over , second flight today and it did it again. I am going to check to see if there is a log but it will have to wait until I get home from work . wonder if it has anything to do with me plugging in and changing a few things last night?. I changed roll and flip rates and dead band
Anthony
Anthony raw 500, xl power nimbus 550,Tron 5.8 heritage, Tron Dnamic, cgy760-r, futaba |
10-02-2015, 09:39 AM | #82 (permalink) |
=] my last Ace was to turn logging to Off and/or Gov Overdrive to zero %, in any order, ironically we need to see the logging!!! SK 22 syndrome.....
10-02-2015, 12:26 PM | #83 (permalink) |
I am starting to think its software related and also something to do with logging . I did send a file to art but haven't heard anything back yet
Anthony
10-02-2015, 04:06 PM | #84 (permalink) |
Georgi has a direct line to Art, I hope...
2 X X7 | Scorpion 4525 Ultimate 4+6T YY / Xnove 4530 525 | scorpion Tribunus 200II ESC | Edge 713 | Logo 690SX | Pyro 440 7+8T YY | Castle 120HV | X3 | 4S | HW 50A V2 ESC | Scorpion 2221 2050KV 9T D | SK540 / Brain2 | Mks |
10-02-2015, 04:56 PM | #85 (permalink) |
so I checked tonight and there is a log so it seems its related, should I try turning the log off now that its back on and see what happens
Anthony
10-03-2015, 05:21 AM | #86 (permalink) |
=] Yes, logging off, then not too many other changes at once, I think you have it in the bag??
10-03-2015, 09:21 AM | #87 (permalink) |
so this morning another 3 flights , first flight logging off , glitched half way through the flight then when I was landing another glitch, so I decided to check with the lcd if logging was on or off, it was off , so I turned it back on and formatted the internal memory, my thinking was even though the logging was off , maybe the information is still being written to the sk memory and once it was full then the glitch happened, (this is still my thought actually) so next flight I was thinking would be fine and the last flight it would glitch , as the memory would be full, second flight (with logging on ) no glitch third flight (still with logging on) no glitch , that set me thinking, is it possible that the memory in the 540 was either corrupt or full and couldn't wipe itself when powered up ? formatting the memory got rid of the corruption and allowed the unit to clear itself on power up or does that not make any sense at all?
Anthony
10-03-2015, 10:21 AM | #88 (permalink) |
=] just for clarity Ant, this is a second 540 in play here on the same heli? I agree, something is corrupt and causing this, I just can't figure if it's the input (S-Bus) or output (SK) side.
when you determine consistent results ie, logging on/off etc I will follow it thro' with SK. I also would suggest resetting the log counter to zero..... You ought to get on the testers list, well deserved work going on here!!
10-03-2015, 11:19 AM | #89 (permalink) |
same heli different sk540 , it was the one from my warp , which I also flew today and it behaved itself, so I understand what you are saying , that something could be corrupting the sk from the futaba side of things ,(possibly) when it first started I changed my sbus lead just to rule that out , other than that , in the very beginning I had to change the receiver because of a known issue with the sbus 2 protocol that the x4ii was using originally , the receiver on the warp the x2 and the x4ii are the same now
Anthony
10-05-2015, 07:35 AM | #90 (permalink) |
so far I've had 11 flights I think with no gov issue, I did try changing logging from off to on and also the alarm from off to limit throttle and all without an issue, I did have one thought, when I was setting up my tail with the new servo I used my lap top which has a loose usb port , so occasionally it would disconnect and then reconnect , could be that one of the times it disconnected it was in the middle of writing something and corrupted the memory, that is the only thing that I can think of that might have been an issue as it seems like as soon as I formatted the memory with the lcd the problem went away , now I think it really is case closed
Anthony ps thank you both for all your help and patience
10-11-2015, 09:25 AM | #91 (permalink) |
haven't been able to fly lately (rain) so today was the first time out in a while , 3 flights, third one the heli spooled up then went lower headspeed for a bit then picked up and halfway through the flight the usual slowdown and pickup, when I got home I tried to load the log but windows is telling me that the file is unreadable and/or corrupt.error code 0x80070570x: hmmm
Anthony
10-11-2015, 02:40 PM | #92 (permalink) |
Art...
10-11-2015, 06:39 PM | #93 (permalink) |
emailed him a while back with a log but haven't heard anything yet . maybe Georgie can contact him about my little problem,
the only thing I did differently on this flight was at the beginning while in th I adjusted the rudder gain in the gyro menu so that I could re-centre the knob took maybe 15 seconds at most , maybe this had something to do with it?(clutching at straws now!)
10-12-2015, 08:41 AM | #94 (permalink) |
case re-opened, 3 flights this morning and it happened all 3 times, actually it happened on spool up , when the sk took over it slowed down , I hit th and spooled back up , first flight it did it at the beginning and the end , second flight at the beginning and halfway through and last flight I didn't hit th just let it slow down and pick back up and it only did it at the beginning, I didn't try formatting the drive and I will have to check later if there is a log , apart from that its flying nicely
Anthony
10-12-2015, 09:22 AM | #95 (permalink) |
=] on it! ........ will feedback.
my only last suggestions being, drop the overdrive to zero, and logging to off. then we will have the full package.....
10-12-2015, 02:32 PM | #96 (permalink) |
=] quick response from SK says voltage drop to the Rx will cause this.....
10-12-2015, 05:39 PM | #97 (permalink) |
well here's the last log , voltage drop right at the beginning of the flight? do I need to check my wiring
Anthony
10-12-2015, 05:41 PM | #98 (permalink) |
ok logging off and overdrive set to zero , will see tomorrow what happens
Anthony
10-13-2015, 06:26 AM | #99 (permalink) |
He has no voltage drops in the logs i have seen
