Go Back   HeliFreak > R/C Electronics Support > Futaba Radios and Electronics > 2.4G Futaba Radios
2.4G Futaba Radios Futaba 2.4G Radio Help and support forum
Old 08-04-2014, 03:00 PM   #1 (permalink)
Default Futaba 14SG and 2s lipo
Hey can the Futaba 14SG work on 2s lipo or do I have to use life 6.6v if I want to upgrade the battery.
Karim
KBaksh is offline        Reply With Quote Quick reply to this message
Old 08-04-2014, 03:28 PM   #2 (permalink)
I would recommend the 6.6v LiFe pack, remember that the 2S Lipo when fully-charged is 8.2v.
I did have a compacted-list for all the different LiFe's that were available (somewhere, I think it's over-on the otherr-site) but I do have these (2) listed in this thread-link ;
https://www.helifreak.com/showthread.php?t=562048
Here's the list ;
Turnigy 2S 2100mAh (specific for the T14SG, check for in-stock status in the US Warehouse)
Hyperion 2S 2100mAh (have read that this one fits but may be a little-tight)
Hyperion 2S 2080mAh (supposed to be a little-better fit than the 2100mAh model)
http://media.hyperion.hk/dn/fg3radio/
Hobbico 2S 1900mAh (Tower Hobbies)
Pro-Tek 2S 2100mAh
http://www.amain.com/ProTek-R-C-LiFe...100mAh/p165091
Hope that Helps !!
T-Rex 250CF MiniCopter Joker V1 Mikado Logo 600 3D VBAR Henseleit TDR RIGID
Futaba 14SGH FASST / FASSTest
HilliHeli is offline        Reply With Quote Quick reply to this message
Old 08-04-2014, 04:12 PM   #3 (permalink)
I have a couple of spare LiFe packs but the standard NiMh packs run the 14SG for so long I rarely need to bother, much easier to charge the NiMh packs in the Tx anyway with the basic power pack.
similis vobis fugere eam furatus
"The beatings will continue until morale improves."
-- William Bligh
petedee is offline        Reply With Quote Quick reply to this message
Old 08-04-2014, 06:09 PM   #4 (permalink)
I was told by one user that the Hyperion 2S 2080mAh LiFePO4 pack could be charged with the stock Futaba charger (utilizes a low charge-rate and the pack has an overcharge-protector).
I'm still getting great results from my stock-pack (NiMh) at this point as well
Old 08-05-2014, 08:35 AM   #5 (permalink)
http://www.lifesourcebatteries.com/hcam6436.html
can this work with my 14SG, also charge with stock charger.
or do I need this.
http://www.lifesourcebatteries.com/chargers.html
Karim
Old 08-05-2014, 05:01 PM   #6 (permalink)
KBaksh,
I believe that the LifeSource 2S 6.6v 1900mAh pack is a better-fit than the larger 2100mAh pack (double-check the pack dimensions, I know that the 1900mAh pack was the one that was recommended (specifically for the T14SG) on the Tower Hobbies site).
I'm not for certain that you can use the stock Futaba wall-wart charger as I don't see anything in the description that indicates that there is an over-current protector included as part-of the pack.
You don't necessarily need the LifeSource specific charger to charge LiFePO4 type packs, if you already have a good charger set-up it's possible it will charge LiFePO4 packs (I know that my iCharger 3010b has this option).
Old 08-08-2014, 09:20 AM   #7 (permalink)
If the 14SG is anything like the 8FG power consumption wise, I run my 8FG with a 2S, 2500 mAh LiPo without any problems for two years already. LiFE will get you close to Nicad voltages but there are plus and minus for LiFE (as well as LiPo) packs.
Llama v3, EXI 450 Pro, Nano CPX, 130X, Protos 500, various planks
Futaba 8FGH, Spektrum DX7s
18-channel scratch built tugboat controlled by modified Futaba Tx
R/C junkie for the past 25 years and counting...
kingmeow is offline        Reply With Quote Quick reply to this message
Old 08-08-2014, 09:35 AM   #8 (permalink)
http://www.ercmarket.com/lithium-2s-...g-t6j-t8j.html
Here is the Robbe lipo battery for Futaba T14SG
ug6gkg is offline        Reply With Quote Quick reply to this message
Old 08-08-2014, 03:14 PM   #9 (permalink)
From some-of the feedback that I have read (and my own use) the T14SG doesn't seem to be as power-hungry as the T8FG.
Almost everyone that I know that has / or had an 8FG replaced the stock-pack with a Lipo.
I haven't really heard / read any input on the Robbe Lipo that ug6gkg posted the link to but I have read of a few T14SG owners that were running a Lipo (7.4v) in theirs.
I'm just a little-concerned that a fully-charged 2S 7.4v Lipo is too-much voltage for a TX. that was running a fully-charged NiMH pack at 6.9-7.0v right from the factory (but that's just me).
I'm not trying to knock the Robbe Lipo-pack, I wouldn't mind having a Lipo (instead-of the LiFEPO4).
Is there a reason that the Robbe Lipo-pack should be charged at only a 500mAh-rate (?)
Old 08-08-2014, 10:33 PM   #10 (permalink)
In Europe the 14 SG is selling with Robbe lipo battery
Old 08-09-2014, 07:35 AM   #11 (permalink)
Well there you go! A 2S lipo is fine for the 14SG.
Old 08-09-2014, 10:48 AM   #12 (permalink)
The 14SG also has a voltage alarm setting for 2cell LiPo packs.
-Doug
dvelez3 is offline        Reply With Quote Quick reply to this message
Old 08-13-2014, 02:25 PM   #13 (permalink)
They also say the supplied lipo has a buildin voltage stepdown
-TT E700 V2-vbar-mks950-980-Kosmik 160HV-Pyro 700 rewound by PD / Voodoo 600 -PD-MX700-470kv--BLS255hv-VBAR 5.3+- Gaui X3+Spirit Pro
velocity90 is offline        Reply With Quote Quick reply to this message
Old 08-14-2014, 07:04 AM   #14 (permalink)
I would measure the voltage at the leads with a meter.
Old 08-14-2014, 09:12 AM   #15 (permalink)
I plug a 2s 2500 pulse lipo in my and use it for about and hour to test it, It shows 8.2v on the screen and then later drop to 7.9v something like that. I am not sure about long term use.
Karim
Old 08-14-2014, 09:20 AM   #16 (permalink)
This Pulse ?
http://www.helidirect.com/plurx-2550...es-p-26537.hdx
Thanks in advance
Align 800e PRO DFC // KRAKEN Yellow // RAW Nitro // Align 700N DFC // RAW Yellow // 2x Goblin 420 // RAW 420 // RealFlight 7.5 // neXt // AccuRc // Tribunus - Vbar Control Touch - Vbar Neo
msallua is offline        Reply With Quote Quick reply to this message
Old 08-17-2014, 07:14 AM   #17 (permalink)
I bet it will stay around that 7.9V for a long time before it moves down again. Take a look at a typical lipo discharge curve and there's a sweet spot where the voltage doesn't change for a while.
Old 08-18-2014, 08:51 AM   #18 (permalink)
Originally Posted by msallua View Post
No it does not fit, I try it by just plugin it in.
Karim
Old 08-26-2014, 12:16 PM   #19 (permalink)
This is the only lipo that my lhs had that would fit my 14sg http://www.trakpowerusa.com/batterie...cks/index.html
Synergy806 + 686 + E7 Se + E5 + 516s
Synergy N7 + N5c. N556
Vcontrol touch + vbar neos
Synergy Field Rep The Nation 267
Superior is offline        Reply With Quote Quick reply to this message
Old 08-28-2014, 07:48 PM   #20 (permalink)
I got this lipo in link below to work and fit perfect.
http://www.amain.com/ProTek-R-C-Li-P...Fc1i7AodjWcAbw
Karim
