Outrage Fusion 50 Outrage Fusion 50 Electric Helicopter Factory Support Forum |
12-27-2013, 06:32 AM | #21 (permalink) |
Yes it would be nice for outrage to come back. I've had mixed luck i had a v50n2 that was nothing trouble out of the box but I love my fusion and am trying to a buy a few more for parts and maybe a stretch project. I don't fly hard 3d, some mild and mostly big air stuff so I think it would be fun to try this. I have v90n2 kit which came with two tails, one old one new so if the boom works I've got all the stuff.
12-27-2013, 09:27 AM | #22 (permalink) |
I've been looking into this more since v1 v90 tail booms are hard to find. The gaui x7 tail boom is plenty long (868mm) and is the right diameter. You need a ~767mm boom to work with the outrage v90 TT. Unfortunately I didn't get an exact measurement when I was building it.
I also am not sure if the v90 v1 tt or v2 tt is the one we need to fit the fusion splines, I might order some soon to find out. The TT I had fit the new style Fusion spline.
Protos Max Leggero 700, Logo 600SE, Blade 230s DX9 |
12-27-2013, 10:05 AM | #23 (permalink) |
I believe its the v2. The gaui TT has pretty thick walls. I'll measure the TT ends insert this afternoon to be sure.
Chad
Gaui X7 JR 11x | Revolectrix | Protek & RJX Servos | Skookum SK720BE | Scorpion HK4530-450 LE| Rail Blades www.barotors.org |
01-05-2014, 03:59 PM | #24 (permalink) |
Just received my v1 v90 tt, they aren't right for F50 retro splines. I have a couple splines that fit, they must be from an original v90 because old F50 splines don't fit either.
V90 v2 tts were out of stock so can't check it.
03-20-2014, 08:41 PM | #25 (permalink) |
Well I stripped a set of retro front TT gears in flight... luckily managed to auto down perfectly. I'm sure it didn't help the plastic to fly in 30°F weather though. It lasted 10 flights with 1850 head speed although the first 4 of them were with Rail 116 tails so that probably didn't help. I use 105 edge tails now.
It was flying so nice too... I have one more set of retro gears so I will give it another chance. I also think I will lower my head speed to 1800. If it strips again I will have to ditch the Fusion as a light low head speed 700 and get something else. I'm thinking the Raptor E700. Based on what I've read, the airframe is only 100-200g heavier than my stretch Fusion airframe. I'd just swap everything over from the Fusion.
