Go Back   HeliFreak > R/C Electronics Support > Futaba Radios and Electronics > 2.4G Futaba Radios
2.4G Futaba Radios Futaba 2.4G Radio Help and support forum
Old 09-14-2014, 05:49 PM   #1 (permalink)
Default 14SG and Voice Telemetry
Does the 14SG have voice alerts for telemetry?
Helicopters Don't Fly - They Beat The Air Into Submission
Logo 500SE
Minicopter Diabolo 700
Banshee # 45 700 LE and 850
jcflyer is offline        Reply With Quote Quick reply to this message
Old 09-14-2014, 08:20 PM   #2 (permalink)
Member
I believe it does. I just set mine up for Rx pack voltage, but set it for Vibe alert only. There have been one or two firmware updates I skipped that involved voice features that I didn't feel I would use. But when I was setting up the alarm today, I saw that there was a voice option. I just left it Inhibited.
Let us know how you make out.
Old 09-14-2014, 08:42 PM   #3 (permalink)
Mine tells me external batt voltage, rx pack voltage and timer minutes.
Team Rail blades,
Team Scorpion motors,
V-Team
ClubCRASH is offline        Reply With Quote Quick reply to this message
Old 09-14-2014, 08:58 PM   #4 (permalink)
The Capi
Is it loud enough ? I find the futaba radios ive flown with (my own and ppl who ask to try their machines) that they aren't loud enough to hear unless you are flying way out.
Old 09-14-2014, 09:30 PM   #5 (permalink)
Member
I don't know about voice, but the timer beeping isn't nearly loud enough.
Sent via phone
Old 09-14-2014, 09:52 PM   #6 (permalink)
Which firmware do I need to activate the voice option?
Logo 500SE
Old 09-14-2014, 10:14 PM   #7 (permalink)
Member
Not sure, but here is the latest:
http://www.futaba-rc.com/software-updates.html
Sent via phone
Old 09-15-2014, 07:08 AM   #8 (permalink)
The audible alarms are certainly not loud enough alone without assistance, and I know most guys want to hear their craft, but the audio outlet jack in the back of the transmitter will allow an earphone or similar, and I have found this works quite well if you are so inclined, and it is quite fun.
Regards,
Andy
AndrewJHawes is online now        Reply With Quote Quick reply to this message
Old 09-15-2014, 10:04 AM   #9 (permalink)
So I think I firmware 2.0 currently in my Tx, is this the correct firmware to activate the voice?
Logo 500SE
Old 09-15-2014, 04:00 PM   #10 (permalink)
TX. Software should be 4.0v then you can load the 2.0v Sound Function.
Possibly yours is already up-to-date (?)
If you do need to update make sure that you only load the ENGLISH version(s).
T-Rex 250CF MiniCopter Joker V1 Mikado Logo 600 3D VBAR Henseleit TDR RIGID
Futaba 14SGH FASST / FASSTest
HilliHeli is offline        Reply With Quote Quick reply to this message
Old 09-15-2014, 08:15 PM   #11 (permalink)
I use to use head phone (Iphone type) therefore I'd hear it correctly. Now I've installed a small speaker on the TX and hear it great.
Team Rail blades,
V-Team
Old 10-03-2014, 09:03 PM   #12 (permalink)
Is there a manual on how to set up the voice stuff? I updated my firmware, and then installed the sound stuff, but haven't been able to get it to talk at all. I went into my telemetry stuff, changed it from INH to on, but then it's like it wants a switch assignment. Not sure what to put there. I also went into my timer, and from what I read, it would count off the minutes, but all it does is beep at me. Lost.
Grimmy is offline        Reply With Quote Quick reply to this message
Old 10-04-2014, 06:16 AM   #13 (permalink)
Yes it's on line.
http://futaba-rc.com/downloads/manuals.html#air
http://futaba-rc.com/software-updates.html
Team Rail blades,
V-Team
Old 10-04-2014, 12:56 PM   #14 (permalink)
I've read through that and well it's not very clear and most of it was just changes in the new version. I did see a video on youtube where he had to hit a switch to get it to talk, as long as the switch was actuated, it would talk. Maybe that's what I need to do as well. I'd like like it to tell me how much time I have left on my timer, and well if my telemetry goes off (receiver voltage and flight pack voltage) I wish it would read off what it is, so I know which one it is. Most of the time it would be my flight pack, due to having a low reading on certain maneuvers as I always check my electronics pack and if it's less then 8V, I change it out and charge it.
Old 10-05-2014, 06:22 AM   #15 (permalink)
That is exatly what it does.
Team Rail blades,
V-Team
Old 02-15-2015, 11:36 PM   #16 (permalink)
Which speaker are you using?
Logo 500SE
Old 02-18-2015, 12:35 PM   #17 (permalink)
This is my setup, works quite good. Search for "clip on speaker" in amazon or google.
Futaba 14sg telemetry speech (0 min 35 sec)
Cheers
Rod
rodm is offline        Reply With Quote Quick reply to this message
Old 02-18-2015, 10:47 PM   #18 (permalink)
Hey Rod I found a speaker that I think will work pretty good if not, I will try the one like yours. Tell me when you activate the switch does it just go in order voicing all the ones you have activated?
Logo 500SE
Old 02-19-2015, 04:17 AM   #19 (permalink)
Hi Jcflyer
I'll need to check on the order that the speech playback is done. However, I have found that too much information while flying does affect my concentration so I inhibit some of the features. I use switch SF to switch on sound and RD to control the volume.
The vario tones can be really distracting so I control the volume of this using the right slider switch.
I think the Vario tones will be very useful when I am out with my glider searching for thermals.
Using a speaker, I am finding it to be a bit of a nuisance, and it also requires batteries to power the speaker amplifier. I may use an earpiece instead of the speaker. I have tried it and it doesn't prevent me from communicating with other pilots on the flight line.
If only Futaba had built the speaker into the tx case.
Cheers
Rod
Old 02-25-2015, 08:22 PM   #20 (permalink)
Rod how do you control the volume? What version firmware do you have?
Jay
Logo 500SE
