Heads and Rotor Blades Heads and Rotor Blades Discussion |
03-29-2015, 03:36 PM | #1 (permalink) |
Searching for swashplate
Looking for suggestions for a readily available swash plate for my turbine airwolf build. Need a swash that fits 12mm shaft, 4 servo, 45 degree offset. The Vario swash is tapped for 3.5mm bolts (weird). I want to use heim joints in lieu of standard ball links, and most are drilled for 3mm bolts. Prefer a swash from a company that doesnt take 6 months to respond to emails, LOL!
Thanks! |
03-29-2015, 04:47 PM | #2 (permalink) |
Swash Plate
Airstar has a Swash Plate that does all the positions , I have one of the them ,, they use 3 mm balls , , Great quality too ,, I have mine at 45 degree Offset
i had the same problem with Vario Swash Plate , 12 mm shaft uses 3.5 mm balls , crazy ,, Gary |
03-30-2015, 09:41 AM | #3 (permalink) | |
Thanks Gary. Airstar seems to be hit or miss at the moment, so I think I am going to steer clear of them. |
